Dear moderators, please rename this topic to [MOC] Trophy Truck "Double Trouble"
Hi everybody!
Video is available, enjoy and comment!
Here comes double trouble. Twin powered double trouble :devil: True liftarm energy!
This is my new Moc. And it is ready: I am working on photo/video.
UPDATE
Here is some photos and info while you wait for video.
Specs:
  • Soft long travel suspension.
  • Front independent with postive caster
  • Rear live axle with built in Buggy motors.
  • Rear wheel drive
  • Self made stickers
  • Tires RC4WD Dirt Grabber 1.55 (74 мм) - thats a copy of real BF Goodrich AT tires
  • Spare tire RC4WD Mickey Tompson Baja MTZ 1.55 (83 мм)
  • Weight is 1100 gr
Electrics:
  • Steering SERVO,
  • Flying Propulsion 2x Buggy motors
  • Fueled by 2xLiPo
  • 3xLED lights
  • Controlling thru 2xSBrick
Internal space is filled with electronics. Unfortunately there is no free space for cockpit.
Love this suspension, its articulation is great for me. I am happy seeing how it works)
Suspension travel is about 4L. I will drop down and show it on video later.
You know, LEGO suspension is always jerky, so you cant make big mocs drive straight, especially when it is fast and big.
Positive caster helps to return wheels in center postition and fights with steering system backlash. It also makes shock absorbers work smoother and softer, IMHO.
I dont like demonic "Monster" theme that is everywhere now...but this is good)
Very good and realistic tires. Sad that there is no similar proportions tires in LEGO assortment. These are 75 mm with wide almost equal to medium 43 mm racing wheel.
Spare tire is another type, cause I dont have 5-th Dirt Grabber. These 83 mm tire also fit in the arches, but they are bigger and harder for LiPos to rotate without stress...
Model is driving fast enough for its weight and even drift donuts indoor, but outdoor shows the the weakest part - LiPo. I should try to lock differential thermistor for insane driving.
After "baja" outdoor drive I replaced all damaged wheel axles and going to film its indoor's donuts and at asphalt outdoor to reach maximum speed. I hope it can reach at least 10 km/h.
So "why double trouble"? - it is hard to fuel buggy motors. And here we have double of them.
Here is full photo album
http://www.bricksafe...rm8/BajaTruckDT
  • Replies 51
Thanks for attention.
Truck "Double trouble"
This truck was a real trouble for me from the start. I planned it as a fast single motor powered truck with suspension and 56 mm tires (as PiterX did). But I placed motor not vertically, but horizontally. Additional angle bevel gear = less performance. Truck was fast with soft suspension, but I was disappointed with 1-motor performance, no drift = no fun...
Next step was increasing number of motors to 2 pcs with almost the same scale size. I have enough space to put a second LiPo in the cockpit. But then I decided to make wheels larger - 62 mm. After model was enhanced, I surprisingly found that it grow up and asks for larger tires than 62 mm and positive caster..
Gone filming....
Edited by rm8
Can't wait to see it running! I've been working on something similar but I'm afraid it grew too heavy to drift or jump and it seems impossible to drive straight, even with SBrick. Yours is looking so good and promising, I'm not feeling like filming mine as much as before. Anyway, I'll try put my sh*t together, some day. Meanwhile I really can't wait to see your truck in action :blush:
Hi,
Yesterday I have filmed sandy outdoor. I did some nice looking footages with Gopro onboard. Sadly, I destroyed all driving axles (sand dust+ fast rotating). I am glad that I did not used wheel hubs - too expensive to destroy in 15 minutes:)
I can't reach max speed on sand. So today I ll try to film if on flat and clean surface.
Edited by rm8
Dear moderators, please rename this topic to [MOC] "Double Trouble" Trophy Truck
Specs:
Rear wheel drive
Self made stickers
Weight is 1100 gr
Electrics:
Steering SERVO,
Fueled by 2xLiPo
3xLED lights
Controlling thru 2xSBrick blocks
watch update in the head of this post!
Edited by rm8
Now that looks awesome! Each buggy motor has it own LiPo battery pack and Sbrick. Do you need two smart phones to work this or just the one.
Thank you.
No, only one phone, and only one button/slider for that. You just need to link ports of SBrick's that are connected to Buggy motors to one control button/slider. You can easily connect one button to all ports of one/many SBrick devices. Thats easy!
Edited by rm8
awesome MOC rm8!! but why you want to modify legoBB if you can power the sbrick with normal RC lipo batteries? :3 waiting for the video!
-EDIT maybe using only one Sbrick and no light you can gain some ma/h more...
Edited by PKW
Thank you.
I can say more, 2 of 4 my LEGO LiPos have too early protection enabling. I even marked them to not to use them in powerful MOCS. May be there is a difference in thermal resistors characteristics or they are damaged by extensive use or charging with 12V 3rd party transformer (usually I do it with 9V, but I did it with 12 V sometimes). One AFOLS told me he tested modified LEGO LIPO with different load configurations including 2 Buggy and 6 XL motors - everything works fine.
I don't want to use Rc lipos, cause I don't have Rc and don't want to buy Lipo+ charger now.
LEDs have too small consumption.even 10
LEDs don't eat too tiny amount of power comparing to loaded M motor.
Edited by rm8
Thank you.
I can say more, 2 of 4 my LEGO LiPos have too early protection enabling. I even marked them to not to use them in powerful MOCS. May be there is a difference in thermal resistors characteristics or they are damaged by extensive use or charging with 12V 3rd party transformer (usually I do it with 9V, but I did it with 12 V sometimes). One AFOLS told me he tested modified LEGO LIPO with different load configurations including 2 Buggy and 6 XL motors - everytnong works fine.
yes, lipos are expensive, And I also noticed that My lipo BB has The same problem of yours, i think lego should find a more stable Way To protect their electronics
about The led:') some years ago I made some tank wars (to win You have To destroy all opponent's track fighting on a carpet with some obstacles put under it) and after every match I don't Power off The batteries, every time My friend says "you think that it is ONLY a small led(the one of The BB) But it is A small led" (some times i lost The battle because o discharged batteries) so when You has a 750mah protection if You lost 50-70 mah with one sbrick and the leds it is more or less The 10%, it is not a really small amount of Power
Edited by PKW
Holy cow I really can't wait! I've been working on a very similar project for the last ~9 weeks, and your specs tell me this is gonna be... what I wanted to do, damn well done.
