  • Replies 1k
Posted Images
I don't "seam" to understand. Literally. :look:
Using the Mod?
Unpack the zip
Cut, copy however you want. Move them into the smae folder you run bluerender out of. Let it overwrite any files it wants to.
Then run Bluerender as usual.
Using the Mod?
Unpack the zip
No, what is it? What's it do? It looks the same.
Edited by CM4Sci
No, what is it? It looks the same.
Without the mod, you can't see any spaces between bricks of the same color, like the hood of your car. It also lets you do some other stuff as detailed in bublible's topic.
Ah, I see. I'll get it then, thanks! I seriously love this program! Wish I could figure out how to add my old custom decos, though. . .
Just go to that topic of mine that Umbra-Manis gave you: all is there well written in full detail, just read, read and read... :wink::laugh:
Among other things you will also get logo-on-studs, proper rubber material, proper metallic materials, slope brick grains, custom decors, replacable LDD decors, brick seams and much more! :wink:
Edited by bublible
I have been wanting to use this program for a while on my Mac, but I have not been able to get it to work despite the instructions. Is there any tutorial out there that explains how?
How far did you get? What error message are you getting?
Bluerender is amazing... I like how simple and fast it is!
This may help to tell the differences with the SlowFlow MOD... I did a comparison image of a little house I designed in LDD.
The MOD adds faint lines, LEGO logos on studs, clearer "glass" and brightens up transparent pieces (among lots of other things!)
It adds a bit more detail to help with the realism of the rendering.
Edited by shannanigan
For those having problems getting it to run on Mac:
I just installed on BlueRender on a second Mac running Yosemite. What I did instead of uninstalling Java / installing the Java JRE via Homebrew I just installed the Java JDK directly from Oracle: here: http://www.oracle.com/technetwork/java/javase/downloads/index.html
(Installing the JRE did not work on my system, not sure why, it seemed like it didn't register with the OS, I couldn't run the Java command from the terminal)
Just follow the rest of the instructions from the first post in this thread and you should be good to go.
I'm a new/returning-after-several-years member of this site, and I'm having some issues getting Bluerender to work. I had been able to use it on my previous computer, running Windows 7, but it was at the end of its life and I had to get a new computer running Windows 10. I transferred my files over to the new computer, installed Java 8 and LDD, but when I try to launch Bluerender I get this error screen: http://i.imgur.com/FYEA29x.png
I had tried to fix this on my own by uninstalling and reinstalling both LDD and Bluerender, but I continued to get the error message. I looked in the folder where I had installed LDD, and I can't find the database file where the wiki says it should be. At one point, Bluerender prompted me to locate where the db.lif file was, and not finding it anywhere, I mistakenly clicked on the Assets.lif. I've continued to get the earlier error screen since then, and I'm worried I messed myself up at some point along the way. I tried checking the FAQs and reading through some of this topic, but I didn't find anything describing my problem.
Any help would be greatly appreciated.
Just discovered this software today and it's fantastic for sharing digital designs!
I have one small issue I could use some help with:
This is the resultant output of one of my steam locomotives using the default scene settings. I was wondering if anyone had some suggestions for scene file settings I could use to perhaps bring out more of the details in this all black locomotive.
Sure, go HERE, please read it first completely and then make use of it - it will DEFINITELY IMPROVE your rendering output image! :wink::thumbup:
I just installed on BlueRender on a second Mac running Yosemite. What I did instead of uninstalling Java / installing the Java JRE via Homebrew I just installed the Java JDK directly from Oracle: here: http://www.oracle.co...oads/index.html
I know it's possible to bundle jar with a JRE in a "native" OSX App. Would be way easier. I'll try to setup a VM on my Mac for some tests.
If you specified the wrong database file, you could manually edit the configuration files. Should be a hidden file called ".bluerender.ini" in your home folder. Open with notepad and edit the line starting with "db.location"
Edited by Malou
I just registered to share how to get this running with Java from Oracle on Mac (10.11 tested):
  • Get the Java Runtime Environment for OSX on http://www.oracle.co...oads/index.html
  • Install it
  • In your terminal, type: export JAVA_HOME="/Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Home"
  • java -version now gives you java version for ex. "1.8.0_66"
That's the cleanest way I found to install the latest JRE.
You can add the export JAVA_HOME line in your .bashrc to have java permanently in your Terminal:
echo export JAVA_HOME=\"/Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Home\" >> ~/.bashrc
Now enter the following command: java -cp "bin/*" bluerender.BlueRender
Below example was rendered on OSX:
Edited by M2m
@M2m might be coincidence. Didn't worked on my freshly installed 10.11 VM... Or I'm the coincidence lol. I believe if I find out why it doesn't work on the VM, I might be able to bundle it in a native OS X application...
Tests-Mac:Bluerender0005 test$ java -cp "bin/*" bluerender.BlueRender
# A fatal error has been detected by the Java Runtime Environment:
# SIGSEGV (0xb) at pc=0x0000000000000000, pid=1149, tid=18179
# JRE version: Java(TM) SE Runtime Environment (8.0_66-b17) (build 1.8.0_66-b17)
# Java VM: Java HotSpot(TM) 64-Bit Server VM (25.66-b17 mixed mode bsd-amd64 compressed oops)
# Problematic frame:
# C 0x0000000000000000
# Failed to write core dump. Core dumps have been disabled. To enable core dumping, try "ulimit -c unlimited" before starting Java again
# An error report file with more information is saved as:
# /Users/test/Desktop/Bluerender0005/hs_err_pid1149.log
# If you would like to submit a bug report, please visit:
# http://bugreport.java.com/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
Abort trap: 6
Edited by Malou
@Malou: try to close LDD, before starting bluerender. Otherwise LDD may block some critical resource files.
No that's not it.
EDIT: Must be something wrong with OSX. Doesn't work with Homebrew either.
EDIT 2: Mac users can test this. It does work on my Macbook and iMac, but not on freshly installed El Capitan virtual machine using Parallels. Let let know if it work for you or not. It's quite heavy because it include the necessary java JRE. http://dl.bbqsoftwares.com/LDD/Bluerender.zip
Edited by Malou
