I'm just installed LDD 4.3.8 on my pc, then I found that I have black bar on top of the tools section.
Check Picture Here : http://upic.me/i/uh/pblac.png
ps. don't know how to post it
And second, the program not run in full screen if you look at bottom right you'll found the filter section half showed.
I have to use this program for final project or anyone have another program please help me
My Rigs
CPU - Intel i3 3.40 GHz
GPU - Nvidia GT 630
Ram - 8 GB
OS - Window 10
Thank You All
Edited by top2541top
Well, first of all, your screenshot does not show up here, only "Posted Image".
Next, Win10 is still sort of beta and LDD not tested on Windows 10 nor approved for it: See the "Operating System" paragraph in the "Minimum System Requirements" at http://ldd.lego.com/en-us/download . Thus you can't expecet LDD to work seamlessly, if you try to run it on Windows 10 nonetheless.
Moreover, it seems that a Geforce 630 GT is not really supported to run under Windows 10 Preview, since there are no suitable drivers available (http://www.nvidia.co...nd.aspx?lang=en ), not even beta drivers.
So please do use a system that meets the minimum requirements: Use a supported Windows or MacOS and a graphic card with appropriate drivers compatible to at least OpenGL 1.1.
Thanks to tell me
You can check here : http://upic.me/i/uh/pblac.png
Second I'm found if I'm adjust Compatibility Mode Level to max I can run it with full screen but make me lag as hell.
anyway thanks to reply me :D
I think too that the problem is probably related to your video card driver.
Is the driver up to date?
Anyway I had and have no problem to see the image. :wink:
Driver just update to version 349.90 a few day ago, anyway I think LDD maybe not support Window 10.
Thanks to reply :D
