As promised last week, here are a few shots of the SSD Executor I MOC'd back in 2011/12.
I started with the 'Starship Battles' game model as my reference point and after creating the frame work, after a few months had an 80% completed model.
However, something just didn't look right to me so I researched more thoroughly and after finding photographs of the origninal movie model, set about redesigning the back end (and all associated sub frame etc.)
I had tried to get it ready (on request) for a Lego Space display at the Leicester Space Centre, in July of 2011, but was faced with too much work to be done and an increased workload at work, so the ship didn't get close to completion until early 2012. Sadly, funds were running low, and I was being pressured (by a somewhat unsupportive and unsympathetic spouse) to finish it and clear it away, so didn't spend as much time on engine detail as I would have liked to.
Anyway, here are a few shots of the finished model.
18078782338_a8e5bc7b6b_c.jpgIMG_2672 by [/url]
Length approx 7 foot / 2.15m
Over 6000 bricks
Weight approx 44lbs / 20kg as I recall.
Edited by NNOPMOC
Wow, thats crazy!
Looks fantastic! Is the underside as detailed as the top? Let's have a look at the engine section, then!
Looks absolutely massive. Is it all Lego or is there a steel beam or something in there to keep it stable?
Looks like he was just going with pure technic beams as structure, which is pretty decent at that size. It is just a shame about the unsympathetic support :sad:
Much much better improvement over the first completed picture though,, much nicer looking rear end!
Thanks NNOPMOC, it's most impressive! :wub:
I never get tired of looking at MOC Executors, it just shows how good the official UCS version could have been! Do you have any photos of the underside and engines? If you don't mind me asking did you sell this on Ebay a couple of years ago, I seem to recall seeing something very similar?
Exactly right, Fuppylodders. :classic:
All lego. No glue or rubber bands (or sellotape).
The underside and engines were not quite as detailed as I would have liked, due to lack of finances and a need to get it finished, but also, practically, it's not the sort of thing you can pick up and "zoom" around (not that I didn't try - successfully :wink: ) so underside detail seemed a little less important.
Not bad for a first MOC (if you don't count my MF when I was 11).
Yes, Lobot, I did sell it on eBay. To someone in Scotland, as I recall. I never did hear if they managed to build it okay. Since then a doctor in the US (friend of a close friend) has asked if I will build another one for her husband. I'm going to try and design it on LDD first . . . probably
Lego Fett, I used some dark grey behind the greebling, to give it the impression of more depth, but other than that I wasn't sure where to place it so stayed with a light grey exterior. Again, this is something I will revisit on the 'next' one.
Time constraints also prevented me from building a few, in scale, Star Destroyers. That will also be remedied next time. Not likely to happen until next year though, because of all the other MOC projects I have in the pipeline.
Thanks everyone for your supportive comments.
  • 7 months later...
NNOPMOC, just wanted to check on your LDD progress so far. I LOVE the 13' SSD that Fox Hound designed, but I feel the lack of modularity and the fact that it has never actually been built put it outside my desired risk threshold. Your 7' model is much more feasible, if you can say that. So I just wanted to see if you've started your redesign yet. :)
  • 5 weeks later...
