Posted June 3, 20159 yr Hello there, Anyone knows when next double VIP points will be available? October maybe?
June 3, 20159 yr How exactly does VIP points work? I always thought it was 1% of your total purchase. However, when I ordered the Detectives Office I got 5 VIP points (equivalent to $5), then when I ordered Palace Cinema I got another 5 VIP Points. I figured I would only get like 1.5 VIP points. So could someone explain this?
June 3, 20159 yr Do they only give you the $5 once you get the 100 points only? I actually should probably be up to 10 Points now then: - $159 for DO - $149 for PC Thats $308, so that should be a total of 15 points correct?
June 3, 20159 yr Do they only give you the $5 once you get the 100 points only? I actually should probably be up to 10 Points now then: - $159 for DO - $149 for PC Thats $308, so that should be a total of 15 points correct? It's one point per dollar spent on the item (not including tax) as stated above: 159 points for DO, and 149 for PC, so 308 points total which means you should have $15 worth of rewards.
June 3, 20159 yr Author So, back to topic: Anyone knows when next double VIP points will be available?
June 3, 20159 yr October, they only do it in March and October, so you have a bit of a wait...sometimes they will do double points on a certain theme though
June 4, 20159 yr If you are interested in Jurassic World, the Raptor Rampage and T-Rex sets will be double VIP points during this month. Quite often, select sets are eligible for double VIP.
