THERIZE Posted June 13, 2015 Posted June 13, 2015 I was building a steinwinter truck and I realised that the whole underside was a mix of blue,red,grey,white,black while the whole model is yellow. I'm realising that I'm using rainbow colours when you won't see it. Is this my own building techic or do more people use this? Quote
dr_spock Posted June 13, 2015 Posted June 13, 2015 It's been done before by others. I've used it for mock ups. LDD is ok but it doesn't tell you how your MOC is going to hold up physically under load. Quote
THERIZE Posted June 13, 2015 Author Posted June 13, 2015 It's been done before by others. I've used it for mock ups. LDD is ok but it doesn't tell you how your MOC is going to hold up physically under load. i like your carrier! Or how those things are even called. Quote
SweetiePie88 Posted June 14, 2015 Posted June 14, 2015 I heard its not uncommon to use cheap colors for fillers though other things like clone brand parts, discolored/cracked, and even duplo are common options. Quote
Master_Data Posted June 14, 2015 Posted June 14, 2015 LEGO does this in their own sets. If it won't show, they'll use any color. Quote
alanyuppie Posted June 15, 2015 Posted June 15, 2015 i'm in a dilemma when I decided to tuck in "other" colored parts inside my MOCs because I fear I might have future uses for them . I usually sneak in ageing parts for this purpose (especially discolored white parts). Quote
alois Posted June 15, 2015 Posted June 15, 2015 I had the same problem. I used a lot of plates in primary colours under my roadway, and now sometimes I am in need of just a simple 2x8 plate in blue... Quote
