Posted June 21, 20159 yr Hi, I have been displayed my version of the Battle of Hoth at shows in Ireland over the last few years. It's mostly using models from sets, but each time I try to add some new custom details. For the latest incarnation, I've added the medical lab, complete with Luke thawing out... Echo Base Medical Lab by James Shields, on Flickr Echo Base Medical Lab by James Shields, on Flickr This shot shows the complete model: Echo Base Medical Lab by James Shields, on Flickr Here's a view from around the back. showing how it's held together: Echo Base Medical Lab by James Shields, on Flickr Here's the rebellion's newest recruit: Echo Base Medical Lab by James Shields, on Flickr The lighting is a set of 50 LED lights powered by 3 AA cells. It set me back €3 in my local discount store. In addition to the medical lab, here is the latest version of the command centre. I've tried to do this a couple of times, but never really felt I captured the atmosphere of the movie. I think there's still room for improvement, but I'm much happier with the latest version, below: Echo Base Command Centre by James Shields, on Flickr Echo Base Command Centre by James Shields, on Flickr Echo Base Command Centre by James Shields, on Flickr This is on display in Athy in Ireland tomorrow. I'll post photos of the whole display soon.
June 21, 20159 yr I love this Echo Base so far. I can tell you worked really hard on it, and the LED lighting is superb!
August 4, 20159 yr Author Hi, So I never got around to posting... My plan is to construct the rebel hanger as a series of connecting modules. The interiors I posted earlier are part of the first one, here: The Snowspeeder hangers are under the medical lab and command centre. Here's a close up of one: Here's the front view of the whole module: The scaffolding to access the upper level is not from the movie, and is only a temporary feature. This is the first of several to accommodate all the snowspeeders, with more parts of the rebel base upstairs. More to follow... James
August 4, 20159 yr Author Last weekend I was working on the second module of the Echo Base hanger, and I aimed to fix some the things I wasn't completely happy with in the first module. Here's an early WIP shot: The only thing holding the front wall up was my hand out of shot! This time I wanted to incorporate lighting under the floor, and especially the floodlights that were lining the hanger in the movie. It cheap €3 set of LED lights from a discount store seemed good for the job, especially as each LED neatly fits in a Technic hole. I wanted the front wall sloping inwards, like in the movie, but I wasn't going to construct it entirely from slopes, so I found an alternative solution of attaching the wall with clips. The inner walls of the base also slope inwards and are connected to the front wall by Technic pins. The same thing from a slightly different angle: Here are the first and second modules side by side. I plan to rebuild the first one to match the second. Finally, I built a copy of the Rebel personnel transporter, as designed by Louise Dade: James
August 5, 20159 yr Looks great! I love the idea of this. The lights are executed perfectly, and make the model so much better. The sloping wall is just the icing on the cake. Details like that make models great. The dioramas above are amazing too. Keep up the great work!
August 5, 20159 yr Author Thanks Guy! I came across the light sets in a discount store and thought they were worth trying. I feel slightly bad using a non-LEGO solution, but there was no way I could afford to put enough power function lighting in. The sets are slightly tricky to use as there's about 10cm (4") between lights, so some planning of the route they take around the model is needed. But they fit neatly in a Technic hole, so work well. I'm pleased with the floor lighting, though it does require building the raised floor. I suspect I'm going to regret this when I get to building the floor of the main hanger to house the Millennium Falcon, which will require six 48x48 baseplates. The whole project is likely to take me a few years. James
August 5, 20159 yr Author A quick addition tonight... This is work in progress on the service gantry that appears in the background in the hanger of Echo Base. I had the gun barrel pieces in mind for the legs for a while, and when I combined them with Technic angled axle connectors, it came together very naturally. I still have to add ladders and hand rails, and some other details, but I like the direction it's going. Now I'd better get on with it or health and safety will have a field day...
August 6, 20159 yr Author Cheers, Guy, The gantry will go in front of the x-wing bay, which will be a similar module to the snowspeeder bays, but with a larger bay. James
August 6, 20159 yr Author I first took part in a collaborative Hoth display around 2005, and there have been several incarnations of it over the years. Usually these involved arriving with a big box of white bricks and building the front wall of Echo base in-situ, and breaking it down after. It was only last year I decided to build it as a permanent MOC, in sections to allow it to travel between displays. It was always going to be a long term project. Generally, I'l spend an hour or two on a section at a time. Often there will be test builds, to try something out, find it doesn't quite work the way I want, so it will be dismantled to try something else. Once I find a design I like, I'll often have to wait to order parts to complete it. The gantry was a surprise. I picked up a bag of the gun barrel pieces and a bag of the angled Technic connectors, and wondered if they'd go together, and less than an hour later I had the gantry above. I still need to get the right flex hose pieces to give it a handrail. So, many hours tinkering, but generally only a couple at a time. Hope this answers your question. James
August 6, 20159 yr It did. Obviously it's many hours over a period of time. I'm struggling to even find time to build one set. I've got a 10 month old who doesn't sleep. So I'm never sitting down.
August 6, 20159 yr Author Ah, well I can see that would make things tricky... priority 1: baby, priority 2: sleep, priority 3: LEGO... At least you can start Duplo in a few months. James
August 6, 20159 yr Duplo! When he turns 1 I'm told he will experience a Duplo shower, from the family.
August 7, 20159 yr Author I wasn't happy with the last photo, so here's a better one. Echo Base Service gantry, now with handrails. I tried a bunch of different options to get the double handrail, but wasn't satisfied with any of them, until t realised you can slide flex house through the hole in the side of the "evil robot" arms. James
August 8, 20159 yr Author I am very bad at deciding a project is finished. There's always something that can be improved! I will keep posting progress, but there may never be a "final" version. James
August 9, 20159 yr This looks really nice and I'm really excited to see how this compares to the one TLG will be releasing
August 10, 20159 yr Author Yeah, I'm interested to see what the UCS Hoth set is like. I doubt they can do anything on this scale, but hopefully it will contain some interesting ideas and parts, and force me to up my game. :-)
August 10, 20159 yr Author A couple of test builds for the Hoth base to share today... First, I've been trying out motorised doors. I suspect this is very basic stuff for Technic builders, but an area I only venture into occasionally. I have a series of axles running the length of the blast doors. Under the middle, a set of gears reverse the direction the axle turns, so if the left half turns clockwise, the right will turn anticlockwise. A series of worm gears are spaced along the axles to move a gear rack on each door. It works well in small scale, so I have to scale it up now. The second test is for the ice walls at the front of the base. The first version of this was just built out of bricks, but I want something a little better, so I'm looking at slopes. The technique uses sections of 1x2 and 1x3 slopes, connected with hinges to give a greater variety of angles. I'm pleased with it so far, but it's going to need a lot of white slopes. James
August 11, 20159 yr Author Here is the base last time I displayed it... I plan to rebuild the front wall using the above techniques. James
