Bering Posted July 3, 2015 Posted July 3, 2015 Hello, I am building the LDD model of the 8858 Rebel Wrecker. However, when i want to connect a technic beam to a connector the align tool doesn't work. Does anybody know how to solve this? And another question, how do i get the truck horizontal again? It's at a different angle right now. I enclosed the LDD file and a screenshot. Thanks a lot in advance! Quote
Nachapon Lego Posted July 3, 2015 Posted July 3, 2015 (edited) You can move key parts relate to the alignment aside before use hinge align tool (for simplify the alignment structure). then put it back. To get the truck horizontal again, simply place a new brick then move the car to connect to the new brick. Fixed LXF: http://www.brickshelf.com/gallery/nachapon/94UCSSSD/15_8858_ldd.lxf Edited July 3, 2015 by bbqqq Quote
Bering Posted July 3, 2015 Author Posted July 3, 2015 You can move key parts relate to the alignment aside before use hinge align tool (for simplify the alignment structure). then put it back. To get the truck horizontal again, simply place a new brick then move the car to connect to the new brick. Fixed LXF: http://www.brickshel...15_8858_ldd.lxf Many thanks for your quick help and the tip to get the model straight again. Now i can continue. :-) Quote
Bering Posted July 4, 2015 Author Posted July 4, 2015 ^ You are welcome :) Sorry to bother you again, but i'm stuck again. :-( I removed all the parts as you said, but the connectors just don't click together. Can you please try again and explain how you solved it this time? 8858 wip.lxf Quote
Nachapon Lego Posted July 4, 2015 Posted July 4, 2015 (edited) ^ I am glad to help :) The fixed LXF file below include 16 cloned brick I grouped then cloned aside before use hinge align tools. http://www.brickshelf.com/gallery/nachapon/94UCSSSD/14_8858_wip.lxf Steps: - group key parts relate to the alignment (this case 16 bricks) - clone the group aside - use hinge align tools to auto connect - remove non-align parts (trans red +blue) form main model - replace with hinge aligned parts (green) Trick when hinge align tool not working by Nachapon S., on Flickr Edited July 4, 2015 by bbqqq Quote
Bering Posted July 4, 2015 Author Posted July 4, 2015 ^ I am glad to help :) The fixed LXF file below include 16 cloned brick I grouped then cloned aside before use hinge align tools. http://www.brickshel...14_8858_wip.lxf Steps: - group key parts relate to the alignment (this case 16 bricks) - clone the group aside - use hinge align tools to auto connect - remove non-align parts (trans red +blue) form main model - replace with hinge aligned parts (green) Thanks a lot again for your detailed instructions. Now i get the idea and i won't bother you again about the align tool. ;-) Good weekend! Quote
