Posted July 11, 20159 yr Hello Eurobrickers! Simply a Hot Rod without Power Functions. The Hot Rod has steering, folding roof and opening doors, hood and trunk, and working piston engine length: 36 studs width: 17 studs height: 15 studs weight: 531 grams BS gallery (after public) Edited July 11, 20159 yr by legosamigos
July 11, 20159 yr I like, that it has so much open/close parts/panels. It looks not so much as hotrod, maybe because of tire size, and hot rods have bigger wheels at back. Maybe You don't have anything. I could also try to make roof horizontal when lowered, or maybe do so, that it hides in boot/trunk. It looks pretty possible. Bu thats just my ideas, when i see it.
July 11, 20159 yr Author Maybe you have right, that is not hot rod. It would be a better pick-up. I thought to build the roof as well as in the 42022 set, but is too high
July 11, 20159 yr you should emble the pics and have some more text about it because now many people will just quit the topic
July 11, 20159 yr you should emble the pics and have some more text about it because now many people will just quit the topic Indeed, I dislike topics with such little images. When I see it, I mostly close the topic. It's so annoying.. Try to upload your pictures on Flickr or Bricksafe. It allows you to choose a good resolution for deeplinking. Your creations are awesome, I envy your building skills, but please: take your time to post with normal images, and you'll attract even more people... Fresko
July 11, 20159 yr Author More text? This is only a simple model :) without PF and suspension. Usually I use Brickshelf, but sometimes there is a problem with BS Edited July 11, 20159 yr by legosamigos
July 12, 20159 yr More text? This is only a simple model :) without PF and suspension. Usually I use Brickshelf, but sometimes there is a problem with BS More text is not necessary, at least for me. You probably use thumbnails to put in your images, but it makes them way to small. I really recommend Bricksafe, it is much cleaner and easier to use. Brickshelf is somewhat outdated.
