falconluan Posted October 12, 2015 Author Posted October 12, 2015 (edited) Probably the last update before final version: Only 2 doors, 4 seats and engine hood are unfinished. My BL orders will arrive soon and after that, I can get rid of the color jungle completely. Thanks for watching. Edited October 12, 2015 by falconluan Quote
Edwin Korstanje Posted October 12, 2015 Posted October 12, 2015 (edited) Great work so far Edited October 12, 2015 by VFracingteam Quote
zux Posted October 12, 2015 Posted October 12, 2015 It easily recognizable right now and looks great! Glad you left roof white. Quote
Jeroen Ottens Posted October 12, 2015 Posted October 12, 2015 That is 6 #3 red connectors you'll be needing on the doors? I still love this model, but now the colours are smoothing the looks, some details caught my eye: I'm not sure I like the structure below the mirror of the front door. It's very bulky and detracts from the clean lines you have. Can you find a less bulky attachment method? I'm also not sold on the thick doorstyles (the stacks of black 2L liftarms). I'd either remove them (and use a stack 2L axle connectors instead), or maybe use an axle-axle connector at the top instead of #6 connector and make the stack all the way to the top. Finally the curve of the front fender is ending too far behind the wheel. The fender should be a half circle, but the rear quarter is more egg-shaped. I know it can be difficult to fix this without having the front wheel rubbing it when turning, but it would look so cool if you manage to pull that off. Do you plan to convert some pieces to white on the roof still? It could use them in the front corners I think Other than that, it is still an amazing Did you testdrive it already? Quote
falconluan Posted October 13, 2015 Author Posted October 13, 2015 (edited) That is 6 #3 red connectors you'll be needing on the doors? I'm afraid yes... I'm not sure I like the structure below the mirror of the front door. It's very bulky and detracts from the clean lines you have. Can you find a less bulky attachment method? It is easy to fix and it's done. The mirror base of the real car is kind of thick, I tried to reflect that but over killed it I think. However, I think the new solution is a little too slick, so maybe should still keep the base 2L wide, what do you think? I'm also not sold on the thick doorstyles (the stacks of black 2L liftarms). I'd either remove them (and use a stack 2L axle connectors instead), or maybe use an axle-axle connector at the top instead of #6 connector and make the stack all the way to the top. I used the 2L beams to reflect the black central frame of the window. However, I have to separate the front and rear doors by 1L to make enough room for the rear door to open, so the whole part looks a little weird. I'll try the axle connector to see if it looks better. Finally the curve of the front fender is ending too far behind the wheel. The fender should be a half circle, but the rear quarter is more egg-shaped. I know it can be difficult to fix this without having the front wheel rubbing it when turning, but it would look so cool if you manage to pull that off. You are right, it is like that because of the turning room, I'll try improving that, but a quick recheck shows that the wheel does need that much room to turn... Do you plan to convert some pieces to white on the roof still? It could use them in the front corners I think Pity that I can not find white 32250 easily Did you testdrive it already? Sorry, it does not drive very well... The major problem is front suspension, the CV joints are very easy to pop out, changing them to U joints leaded to lots of geometry problems, which a complete redesign of the whole structure. So I decided to give up the front wheel driving function and make it rear wheel drive only. Also, many thanks for your suggestions, to be honest, after months of works on this project, I'm a little tired and wanted to end it sooner. Your comments give me lots motivation to keep on improving it. Edited October 13, 2015 by falconluan Quote
agrof Posted October 13, 2015 Posted October 13, 2015 Nailed it! Don't be afraid to disassemble the front suspension, and start a new way to solve the issue... this is what I've learned in my moc. And finally the 15-16th version worked! Quote
Rockbrick Posted October 13, 2015 Posted October 13, 2015 Shame Lego never did the bent 3 x 5 lift arm 32250 in trans-red.... Quote
2LegoOrNot2Lego... Posted October 13, 2015 Posted October 13, 2015 Impressive build with realistic looks! Quote
falconluan Posted October 13, 2015 Author Posted October 13, 2015 Shame Lego never did the bent 3 x 5 lift arm 32250 in trans-red.... Agreed and I did not realize that until wanted to used that as its tail light. Quote
Jeroen Ottens Posted October 13, 2015 Posted October 13, 2015 I'm afraid yes... It is easy to fix and it's done. The mirror base of the real car is kind of thick, I tried to reflect that but over killed it I think. However, I think the new solution is a little too slick, so maybe should still keep the base 2L wide, what do you think? I used the 2L beams to reflect the black central frame of the window. However, I have to separate the front and rear doors by 1L to make enough room for the rear door to open, so the whole part looks a little weird. I'll try the axle connector to see if it looks better. You are right, it is like that because of the turning room, I'll try improving that, but a quick recheck shows that the wheel does need that much room to turn... Pity that I can not find white 32250 easily Sorry, it does not drive very well... The major problem is front suspension, the CV joints are very easy to pop out, changing them to U joints leaded to lots of geometry problems, which a complete redesign of the whole structure. So I decided to give up the front wheel driving function and make it rear wheel drive only. Also, many thanks for your suggestions, to be honest, after months of works on this project, I'm a little tired and wanted to end it sooner. Your comments give me lots motivation to keep on improving it. The mirrors are much better now. I don't think you should change them anymore. In the real car it is a smooth wide base, as soon as you start to stack pieces together the seams in the stacking will detract the eye and destroy the effect you are trying to achieve. Check your PM as well ;) Quote
falconluan Posted October 17, 2015 Author Posted October 17, 2015 The mirrors are much better now. I don't think you should change them anymore. In the real car it is a smooth wide base, as soon as you start to stack pieces together the seams in the stacking will detract the eye and destroy the effect you are trying to achieve. Check your PM as well ;) I modified both the mirror and the window frame per your suggestion, and I think you are RIGHT again, it now looks much better than previous version . The whole thing is about to finish finally, and only the back seats as well as the front suspension left to be done. During the cross checking the final look with the real car, I found that the lower front bumper part is missing... Luckily, it was fixed easily. As to the driving performance, I think I'm pleased enough, since it drives pretty well on the highest gear on flat surface. Hope you like it and please comment below. Thanks for watching. Quote
legotechnicus Posted October 17, 2015 Posted October 17, 2015 Beautifull! love the red with the white. Great job Quote
allanp Posted October 18, 2015 Posted October 18, 2015 very nice! I really like the suspension and overall look Quote
falconluan Posted November 10, 2015 Author Posted November 10, 2015 Has been a while since last update. Finally, it is nearly finished now. Modular building is lots of fun and make the whole design much easier. Different parts got their own iteration without interfering each other. Thanks to agrof's encourage, I made another iteration of the front suspension and finally fixed the toe in issue. I put the steering rack before the front axle, it is different from the real thing but it can negate the toe in problem, so I can live with it . The final look without panels. Made a video to show its performance. The U joints still like to pop out in the FWD mode, but they are OK in the AWD mode. AWD mode is used during shooting the video. More photos and videos will come out soon. Thanks for reading. Quote
agrof Posted November 10, 2015 Posted November 10, 2015 Great to see, that You found a way to pleasure all of us. Quote
falconluan Posted November 21, 2015 Author Posted November 21, 2015 Please moderators help to remove the "WIP" from this topic name, thanks Quote
Blakbird Posted November 23, 2015 Posted November 23, 2015 Please moderators help to remove the "WIP" from this topic name, thanks Done. Quote
Aliencat Posted November 23, 2015 Posted November 23, 2015 Really cool to see this finished, awesome MOC! You've nailed the shape perfectly, and it's cool to follow the WIP process on this. Quote
2LegoOrNot2Lego... Posted November 24, 2015 Posted November 24, 2015 Really cool to see this finished, awesome MOC! You've nailed the shape perfectly, and it's cool to follow the WIP process on this. Agree for 100% Quote
falconluan Posted November 24, 2015 Author Posted November 24, 2015 Done. Thanks, And thank you guys above for your kind words. Quote
