Darats Posted September 17, 2015 Posted September 17, 2015 The same rotation step you should add for my parts as the stl export has not the same orientation as default ldraw one. Quote
Dilvish Posted September 18, 2015 Posted September 18, 2015 How long do renders take generally in Sunflow? Longer than POV-Ray? Quote
Pedrollane Posted September 18, 2015 Author Posted September 18, 2015 Sunflow is faster than PovRay Quote
___ Posted September 18, 2015 Posted September 18, 2015 How long do renders take generally in Sunflow? Longer than POV-Ray? This question is meant to be a joke, right? LEGO project that would take to render several days nonstop (!!!) in POV-Ray would probably take 1 or 2 hours in SunFlow yet the quality is very comparable and in some (many...or even most) of the cases even better (...and I am speaking from my own experience)! P.S.: I see and understand you are new here so you could not know but anyway I on the other hand could not help myself to answer this question in a way I did - I hope you did not take offence cos it was not meant like that (if you did then sorry, my friend ) Quote
nickless Posted September 18, 2015 Posted September 18, 2015 Is there something like a short guide on how this program is supposed to work? I downloaded the archive, extracted it and the program is starting but none of the buttons seem to do anything. I could set the input file and the library paths, but that's it. Any hints? Quote
Dilvish Posted September 19, 2015 Posted September 19, 2015 (edited) A tutorial would be good. Also, can sunflow do orthographic renders? Edited September 19, 2015 by Dilvish Quote
___ Posted September 19, 2015 Posted September 19, 2015 (edited) A tutorial would be good. Also, can sunflow do orthographic renders? It can be done but it is not in SunFlow original code (actually msx80 added such option to it for BlueRender) Edited September 19, 2015 by bublible Quote
Dilvish Posted September 20, 2015 Posted September 20, 2015 (edited) I am trying to render a model. It appears properly in the preview window. But it won't render. Here is the console log: E:\Programs Windows\LDraw\LDraw2Sunflow_d>java -XX:MaxDirectMemorySize=512m -Xmx 1024m -Djava.library.path=./native/ -jar Ldraw2Sunflow.jar Sep 20, 2015 12:00:42 AM java.util.prefs.WindowsPreferences <init> WARNING: Could not open/create prefs root node Software\JavaSoft\Prefs at root 0 x80000002. Windows RegCreateKeyEx(...) returned error code 5. Sep 20, 2015 12:00:42 AM org.ldraw2sunflow.ui.Ldraw2Sunflow <init> INFO: en_US Sep 20, 2015 12:00:51 AM org.ldraw2sunflow.converter.LdrawConverterMulti2 genera teMesh INFO: Parsing D:\Datsville\datsville\building_007_firecompany.ldr Sep 20, 2015 12:00:51 AM org.ldraw2sunflow.converter.OneMeshGenerator parseFile INFO: Parse : stud.dat Sep 20, 2015 12:00:51 AM org.ldraw2sunflow.converter.OneMeshGenerator parseFile INFO: Parse : 4-4cyli.dat Sep 20, 2015 12:00:51 AM org.ldraw2sunflow.converter.OneMeshGenerator parseFile INFO: Parse : 1-4cyli.dat Sep 20, 2015 12:00:51 AM org.ldraw2sunflow.converter.OneMeshGenerator parseFile INFO: Parse : 1-4cyli.dat Sep 20, 2015 12:00:51 AM org.ldraw2sunflow.converter.OneMeshGenerator parseFile INFO: Parse : 1-4cyli.dat Sep 20, 2015 12:00:51 AM org.ldraw2sunflow.converter.OneMeshGenerator parseFile INFO: Parse : 1-4cyli.dat Sep 20, 2015 12:00:51 AM org.ldraw2sunflow.converter.OneMeshGenerator parseFile INFO: Parse : 4-4disc.dat Sep 20, 2015 12:00:51 AM org.ldraw2sunflow.converter.LdrawConverterMulti2 genera teMesh INFO: # Processing time : 0.11 seconds ok LDraw2Sunflow preview 3.0.0b! Sep 20, 2015 12:00:52 AM org.ldraw2sunflow.util.Shader logShaderError SEVERE: Shader compile error : Sep 20, 2015 12:00:52 AM org.ldraw2sunflow.util.Shader logShaderError SEVERE: Shader compile error : Sep 20, 2015 12:01:09 AM org.ldraw2sunflow.converter.LdrawConverterMulti2 genera teMesh INFO: Parsing D:\Datsville\datsville\building_007_firecompany.ldr Sep 20, 2015 12:01:09 AM org.ldraw2sunflow.converter.OneMeshGenerator parseFile INFO: Parse : stud.dat Sep 20, 2015 12:01:09 AM org.ldraw2sunflow.converter.OneMeshGenerator parseFile INFO: Parse : 4-4cyli.dat Sep 20, 2015 12:01:09 AM org.ldraw2sunflow.converter.OneMeshGenerator parseFile INFO: Parse : 1-4cyli.dat Sep 20, 2015 12:01:09 AM org.ldraw2sunflow.converter.OneMeshGenerator parseFile INFO: Parse : 1-4cyli.dat Sep 20, 2015 12:01:09 AM org.ldraw2sunflow.converter.OneMeshGenerator parseFile INFO: Parse : 1-4cyli.dat Sep 20, 2015 12:01:09 AM org.ldraw2sunflow.converter.OneMeshGenerator parseFile INFO: Parse : 1-4cyli.dat Sep 20, 2015 12:01:09 AM org.ldraw2sunflow.converter.OneMeshGenerator parseFile INFO: Parse : 4-4disc.dat Sep 20, 2015 12:01:09 AM org.ldraw2sunflow.converter.LdrawConverterMulti2 genera teMesh INFO: # Processing time : 0.0 seconds Sep 20, 2015 12:01:10 AM org.ldraw2sunflow.converter.CommonPieceWriter writePiec e INFO: Parsing stud.dat Sep 20, 2015 12:01:10 AM org.ldraw2sunflow.ui.impl.RenderPanel print INFO: Module API : Unable to find a suitable parser for: "D:\Datsville\datsville _sunflow\building_007_firecompany" What is wrong? Edited September 20, 2015 by Dilvish Quote
nickless Posted September 20, 2015 Posted September 20, 2015 So, I did manage to get some renders out of this. Speed is very good, but I'm underwhelmed by the quality, it's nowhere near of what I'm getting out of POV-Ray. Are there any plans to make the light sources configurable? What's also missing is the possibility to adjust the look-at point (already mentioned, but this is really important) and support for external submodels. Quote
Pedrollane Posted September 21, 2015 Author Posted September 21, 2015 (edited) @Dilvish I download Datsville, I make some test and I tell you where is the problem. Edit : INFO: Module API : Unable to find a suitable parser for: "D:\Datsville\datsville _sunflow\building_007_firecompany" Sunflow use the file extension to find a parser.You must had .sc to the output file. You can make Orthographic render with Sunflow but by default some parameters (fov, aspect ratio, focus) could not be change. I change this when I have some time. @Nickless Actually you can't configure source light in the application you need to open sc file. You can read bublible tutorial for Bluerender. In the preview direction arrows move the look-at point up down Y axe, left right X axe no Z axis in this version ... Edited September 21, 2015 by Pedrollane Quote
Pedrollane Posted September 21, 2015 Author Posted September 21, 2015 (edited) New version of LDraw2Sunflow : Basic support of Darats files How to use : Download LGEO Library - Darats on Darats topics Extract archive. Create obj directory near LGEO Parts and STL Parts directory Use Poseray to convert all STL Parts in obj files Download primitives extract archive into obj/primitives directory You need to configure LGEO Darats directory in Ldraw tab Command line You can use command line to change logger level or clear saved preferences LOGGER=FINE -> more log LOGGER=INFO -> default log clearPref -> clear saved preferences I need to go, I hope you can use it with my very short explications Edited September 24, 2015 by Pedrollane Quote
Dilvish Posted September 21, 2015 Posted September 21, 2015 (edited) @Dilvish I download Datsville, I make some test and I tell you where is the problem. Edit : INFO: Module API : Unable to find a suitable parser for: "D:\Datsville\datsville _sunflow\building_007_firecompany" Sunflow use the file extension to find a parser.You must had .sc to the output file. Thanks. That worked. @NicklessActually you can't configure source light in the application you need to open sc file. You can read bublible tutorial for Bluerender. In the preview direction arrows move the look-at point up down Y axe, left right X axe no Z axis in this version ... I would like to edit the SC file as well, and then render it. How do i do that? Edited September 21, 2015 by Dilvish Quote
Pedrollane Posted September 24, 2015 Author Posted September 24, 2015 I would like to edit the SC file as well, and then render it. How do i do that? I have udpate the last version you can redownload here. -Extract archive and move into the lib directory If you use a JDK : JDK_PATH\bin\java -Xmx1G -server -jar sunflow.jar If you use a JRE JDK_PATH\bin\java -Xmx1G -jar sunflow.jar -server option is faster than default -client Quote
Dilvish Posted September 25, 2015 Posted September 25, 2015 (edited) Thanks. Is there any documentation for all the different scene file commands? [edit] Here's my first test render. I circled some problem areas. The tops of the circled bricks are the wrong color. I don't know why. [edit] You can also see some miscolored details on the yellow door. Edited September 28, 2015 by Dilvish Quote
Pedrollane Posted September 28, 2015 Author Posted September 28, 2015 @Dilvish The only documentation on Sunflow is the old wiki dump I have fixed bugs color on doors and barrier You can download the new version here Quote
Dilvish Posted September 30, 2015 Posted September 30, 2015 (edited) Could you make it so that there is an option to only create the model objects? That way I can include the models in a separate scene with lights, camera, etc.. Thanks. Edited September 30, 2015 by Dilvish Quote
msx80 Posted October 1, 2015 Posted October 1, 2015 Hi there, sorry i missed this thread :) Good to see an LDraw Sunflow render too! I've seen you started from the "bluesunflow" version fo the renderer, which is great. There are already a lot of different forks of the program, we could try to keep a single one for "Lego related renderings" to add up our improvements :) As soon as i have some time i'll take a look at your changes and add them to the repository. I'm super busy lately :( Quote
Pedrollane Posted October 2, 2015 Author Posted October 2, 2015 Could you make it so that there is an option to only create the model objects? That way I can include the models in a separate scene with lights, camera, etc.. Thanks. Sorry, actually I'm busy but thre is a solution. If you use the button "Convert to SC file" application does not launch the rendering. It's always possible edit generated SC file remove all before # START Ldraw color and all from camera. @msx80 I publish my code when I have more time :) Quote
Dilvish Posted September 18, 2016 Posted September 18, 2016 (edited) Any progress? I am interested in orthographic perspective, as well as the ability to build scenes in a text editor like you can in POV-Ray. Edited October 23, 2016 by Dilvish Quote
Dilvish Posted January 31, 2018 Posted January 31, 2018 (edited) I am playing with this program again. Right now I am trying to convert a model, but the conversion seems to be stuck in the "preview model" phase. It is taking a long time. Also, not all configuration options are visible on the third tab of the program. The error is: ... ... ... Exception in thread "Thread-4" java.lang.UnsatisfiedLinkError: no lwjgl in java. library.path at java.lang.ClassLoader.loadLibrary(Unknown Source) at java.lang.Runtime.loadLibrary0(Unknown Source) at java.lang.System.loadLibrary(Unknown Source) at org.lwjgl.LWJGLUtil.loadLibrarySystem(LWJGLUtil.java:337) at org.lwjgl.Sys.<clinit>(Sys.java:29) at org.ldraw2sunflow.lwjgl.PreviewOpenGL.run(PreviewOpenGL.java:160) at org.ldraw2sunflow.ui.impl.RenderPanel.convertFile(RenderPanel.java:11 7) at org.ldraw2sunflow.ui.impl.RenderPanel.access$000(RenderPanel.java:61) at org.ldraw2sunflow.ui.impl.RenderPanel$1.run(RenderPanel.java:85) Has anyone come across this yet? [edit] I am now unable to open the converter any more. I get an error: Jan 31, 2018 3:27:49 PM java.util.prefs.WindowsPreferences <init> WARNING: Could not open/create prefs root node Software\JavaSoft\Prefs at root 0 x80000002. Windows RegCreateKeyEx(...) returned error code 5. Jan 31, 2018 3:27:49 PM org.ldraw2sunflow.ui.Ldraw2Sunflow <init> INFO: en_US Exception in thread "AWT-EventQueue-0" java.lang.StringIndexOutOfBoundsException : String index out of range: -1 at java.lang.String.substring(Unknown Source) at org.ldraw2sunflow.util.PartFinder.loadColor(PartFinder.java:274) at org.ldraw2sunflow.util.PartFinder.setLDRAWDIR(PartFinder.java:172) at org.ldraw2sunflow.ui.impl.LDrawPanel.initPreferences(LDrawPanel.java:122) at org.ldraw2sunflow.ui.impl.LDrawPanel.<init>(LDrawPanel.java:47) at org.ldraw2sunflow.ui.Ldraw2Sunflow.<init>(Ldraw2Sunflow.java:80) at org.ldraw2sunflow.ui.Ldraw2Sunflow.lambda$main$10(Ldraw2Sunflow.java:114) at java.awt.event.InvocationEvent.dispatch(Unknown Source) at java.awt.EventQueue.dispatchEventImpl(Unknown Source) at java.awt.EventQueue.access$500(Unknown Source) at java.awt.EventQueue$3.run(Unknown Source) at java.awt.EventQueue$3.run(Unknown Source) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(Unknown Source) at java.awt.EventQueue.dispatchEvent(Unknown Source) at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source) at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source) at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source) at java.awt.EventDispatchThread.pumpEvents(Unknown Source) at java.awt.EventDispatchThread.pumpEvents(Unknown Source) at java.awt.EventDispatchThread.run(Unknown Source) Here is my command line: "C:\Program Files\Java\jre1.8.0_161\bin\java.exe" -Xmx1G -jar "E:\Programs Windows\LDraw\LDraw2Sunflow_f\ldraw2sunflow.jar" [edit] I tried again as admin, and experienced the same problem. The program runs once, but then will not work a second or third time, and spawns the above error. Also, I tried again with "LDraw2Sunflow_d" and experienced the same problem. This is odd because it worked fine for me in 2015. [edit] When I delete "HKEY_USERS\S-1-5-21-2113055238-2099637611-63920502-1003\Software\JavaSoft\Prefs\org" using regedit, the program will start again, but the stored file and directory paths are missing again when I restart the program too. Here's what my registry looks like: Edited February 1, 2018 by Dilvish Quote
