Posted September 18, 20159 yr Hello all Bricknerd has linked me to this amazing Y-Wing MOC and the builder has provided instructions and a parts list! Does anyone know a quick and easy way to get this parts list directly into Bricklink so I can buy all the bits! Thanks! /ben
September 24, 20159 yr copy the xml bit (the parts with tags like <INVENTORY> around it into the UPLOAD part of your wanted list in bricklink. Unless you want to edit <ITEM> into <ITEM><WANTEDLISTID>xxxx</WANTEDLISTID> by search/replace-all, then everything will go into your MAIN wanted list. The BL link is http://www.bricklink.com/wantedXML.asp
June 5, 20168 yr copy the xml bit (the parts with tags like <INVENTORY> around it into the UPLOAD part of your wanted list in bricklink. Unless you want to edit <ITEM> into <ITEM><WANTEDLISTID>xxxx</WANTEDLISTID> by search/replace-all, then everything will go into your MAIN wanted list. The BL link is http://www.bricklink.com/wantedXML.asp Thank you so much!
