Hi guys,
A week ago I decided to build something with LEGO.
My idea at first was to build a trail truck style tatra.
Later that day I saw the TC8 competition and I thought I'm going to make a tatra with a crane (see pic below for a global idea).
Functions:
Drive (xl motor)
Steering (m motor)
Outriggers (manually)
Turning crane (manually)
Extending boom (manually)
Lifting boom (pneumatic)
Still not sure which body I should use, but need to finish the chassis first.
I will post pictures a.s.a.p.
  • Replies 60
  • Views 10.4k
seems very good, i am fan of tatra trucks, and i love how they perform in rough terrain and the drivetrain system is amazing, if i was you, i would make the most advanced version of tatra you are able to recreate (i would like the t 815-7), and maybe the crane could be some kind of heavy folding cranes, or just make something like your picture, however good luck in your project.
The promised pictures!
At this point it is still a early version and I will change a couple of things, but for now this will do.
Cheers
Edited by legotechnicus
That suspension setup is neat! I really like the old technic look it has about it but is realised using modern pieces! Top stuff :thumbup:
Thanks, it's a pretty simple system. I didn't want to use springs in the rear because of the weight of the crane.
I will make instructions for a base model, this means the cab and chassis only (different setups, like 4x4, 6x6 and 8x8).
I'll also make a LDD file for the crane as well.
This way you can choose what you want to build, a model or a trial truck.
legotechnicus,
it looks good! Can you upload the bottom photo? I'd like to see your Tatra concept solution - central backbone and semi-axles... Thx!
Max...
Edited by MaxSupercars
Very, very nice. And I have to agree with MaxSupercars - I would love to see the bottom of this bricky-beauty. :)
Here are some pics of the bottom of the truck.
I still need to order some parts to make the axles final.
This is a very nicely built model with a good blend of old and new technic. One question though, what motor are you using?
Thank you! The motor I'm currently using is a xl motor for the drive and a m motor for steering
I am very much liking the rear suspension, not that it's something no one has said before :classic: . I also like the idea for the outrigger feet, very smart using a ball joint and wheel :wink:
Legotechnicus very nice... I thought that you used this method... thanx for sharing... this MOC got nice technical details... :)
Max...
Tahnk you for the photos of it's belly. Does not the connectors (2 pinholes, with perpendicular axlehole) crack under load? in my trial Tatra they used to, when I used this setup.
No problem. At this time no
Little update from today's progress.
Started making a cab for the Tatra. Be my guest and try to guess the model :wink:
I'm not sure if im going to keep the color, but for now I like it.UPsykCN.jpgmM1cEzg.jpgoKozAMJ.jpg
maybe you could try to make it red or blue i case you would change the black, because most of the civil tatras that i have seen are of that color, also, nice work with all the functions, the transmission is amazing, its better than i could expect, and so far it looks very good, looking forward for more progress and good luck.
