Posted October 8, 20159 yr Hello, yesterday I encountered a strange problem when importing a .ldr file into LeoCad. It simply wouldn't show my 2 x 3 plate with hole, ldraw part 3176.dat. The part renders fine in MLCad, LDCad, LDView and the like, but it shows only the 4 studs in LIC (instruction creator) and LeoCad's part window, while not showing at all in the rendered models using the latter two. You can see the difference in the two images attached. My question is - is this a known phenomenon? Are more parts affected than just this one? How can a part like this be used in LeoCad or LIC? Thx m.
October 8, 20159 yr No problem here with LeoCAD. What versions of LeoCAD / LDraw library do you use? What OS?
October 8, 20159 yr Are you sure Leocad is using the 2014-02 LDraw library as that part depends on it.
October 13, 20159 yr Author LeoCad is using the same version of lDraw as the other programs, from what I can see it's dating from 2014. It's the Linux version of LeoCad, I may add. And as said, LIC has the same problem... strange. Edited October 13, 20159 yr by mfeldt
October 15, 20159 yr It draws correctly for me on Linux, I'm thinking this could be a filename case problem.
October 16, 20159 yr Author Actually i started thinking along the same line - maybe its related to the fact that it's a Linux version while lDraw is a windows version in a .wine directory on an ext4 filesystem. I'll need to check if something is special with that particular part.
