Mordep Posted December 29, 2015 Posted December 29, 2015 Fabulous! I've a 5571 and know I have a new project to make!! Quote
juggleryoder Posted January 31, 2016 Posted January 31, 2016 (edited) Hi Mnpumar!! I have the 5571 set and I always told myself that if ever a trailer was made for it, I would want to get it. This seems like a great way for me to get back into the lego hobby I used to enjoy as a kid. I bought this set years ago when it first came out and is my biggest set in my collection of sets. Are the special parts for the trailer hard to get? If I went to a lego store would I assume I would be able to get most of the pieces, but would I be able to order the parts I need through the lego store or would it be best to just order them online? And where can I buy the 68.8 tires? Seems like they will be hard to find. Edited January 31, 2016 by juggleryoder Quote
Yannick1988 Posted April 24, 2016 Posted April 24, 2016 (edited) Wow! Very cool!! I thought I was the first person to ever build this trailer because the person I got the instructions from said he never built it. I had to make a lot of modifications to get the back end of the trailer to fit together properly, especially on and around the doors. Also the original design could not support the weight at the wheels and they kept popping off on me before I fixed it! I'm curious if you ever updated the instructions to include those fixes? I'm also curious how you fixed them. The pneumatics seem okay but I guess there is always room for improvement :) Hello, I'm selling instruction for alternate models of Model team on my bricklink shop http://www.bricklink...p?p=Yannick1988 I'm the person who made the instruction of the trailer and I sent the instruction to mnpumar as bonus. I'm happy to see it's possible to build it. I made it only on computer (10 years ago) and never built it. It was based on pictures of "Salocin" and a modification of the truck from "Darats". I share the mpd file (to use with Ldraw + Lpub). If someone wants to modify it ;) If I can get a set with all parts needed I will maybe build it (finally...) 5571 was the best lego kit ever made :D Link : http://www.filedropper.com/camionetremorque ++ Edited April 24, 2016 by Yannick1988 Quote
bonox Posted May 17, 2017 Posted May 17, 2017 Yes, a thread necro, but the OP requested followup from others making this build and hopefully i've got something to contribute. I wanted more of a realistic frame, so this is based on the working trucks around here, where you have the frame of the trailer, plus some toolboxes, spare wheel racks and a supplementary diesel tank. I also prefer dual wheels and triple axles as we typically run here due to a lot of these being used on poor roads (including dirt). Of course, it's only after posting these that I see i've left the headlights off the prime mover Also, unlike the original plans, this one is quite structural - there are 1x16's crossing the floor of the trailer at loadpoints - the king pin, the supports and two sets over the axle assembly. Consequently you can really pack this one with sand (well, tin cans of food at least) if you want to without causing it to flex too much. Very happy with the colour scheme too - it sits next to Grazi's tow truck in it's original black, so I wanted something a little different. Quote
mnpumar Posted May 17, 2017 Author Posted May 17, 2017 (edited) 6 hours ago, bonox said: WOW!! That is some incredible work! I always wanted to build it in white too but I never had the time. Thank you so much for sharing. Do you have a part list or instructions? I will definitely be building that when I have the time. Edited May 17, 2017 by Blakbird : Removed many quoted images. Quote
bonox Posted May 17, 2017 Posted May 17, 2017 Hi mnpumar I've just been fiddling so no parts or instructions at present. I'll also probably keep fiddling with it for a while and it'll be busy in the next month going for public display. If there are bits you want photos of i'm happy to oblige. I originally just swapped all the black bits for white and red for blue. The red for blue works perfectly, subject to availability of parts for the truck. The white for black though needs more thought - the underbelly, mudguards and suspension of the trailer, plus the belly and radiator plus insides of the truck are much better off in my opinion remaining black. I also tried trans-clear bricks behind the radiator and I wanted you to get a peek at the stuff under the bonnet, but i wasn't pleased with the outcome. I may revisit this at some point though. And I really should put those headlight dishes on as well :) The axle assembly of the trailer use to have the same rocking/pendular suspension as the original design in this post, with some panhard rods to control the twisting and springs to control the fore-aft rocking, but it was complicated and didn't steer very well on a hard surface. I found a basic rigid box unit works very well which is what you see here. I also got some performance benefit out of putting the middle axle centreline one plate lower than the other two. It looked pretty much the same, but all the load went on the centre axle only and the other two sagged a bit to look like they were on the ground. Well mostly. It steered very nicely, but i ended up not liking the look and i mostly build static models. The final thing is that I built it where I could from light gray parts as that's what the original 5571 uses and i wanted to keep it all in line, but the wheels will probably always be an issue in that regard. Maybe i'll leave a set of rims in the sun for a year and see if I can get them to darken like that last 6x16 plate under the rear deck. Quote
BigBrick88 Posted November 25, 2019 Posted November 25, 2019 On 5/17/2017 at 5:29 AM, bonox said: Yes, a thread necro, but the OP requested followup from others making this build and hopefully i've got something to contribute. I wanted more of a realistic frame, so this is based on the working trucks around here, where you have the frame of the trailer, plus some toolboxes, spare wheel racks and a supplementary diesel tank. I also prefer dual wheels and triple axles as we typically run here due to a lot of these being used on poor roads (including dirt). Of course, it's only after posting these that I see i've left the headlights off the prime mover Also, unlike the original plans, this one is quite structural - there are 1x16's crossing the floor of the trailer at loadpoints - the king pin, the supports and two sets over the axle assembly. Consequently you can really pack this one with sand (well, tin cans of food at least) if you want to without causing it to flex too much. Very happy with the colour scheme too - it sits next to Grazi's tow truck in it's original black, so I wanted something a little different. I realize this is an old thread, but I really would love some more details on this trailer.... Quote
bonox Posted November 29, 2019 Posted November 29, 2019 hi bb88 what in particular would you like to see? Happy to help, but i'm not sure there's much more that isn't in these photos Quote
BigBrick88 Posted November 29, 2019 Posted November 29, 2019 11 hours ago, bonox said: hi bb88 what in particular would you like to see? Happy to help, but i'm not sure there's much more that isn't in these photos I would love some more info on the changes you made to the axles and frame. Do you by chance have a parts list or instructions? I just finished my Cabover 5571 Quote
bonox Posted December 2, 2019 Posted December 2, 2019 neither i'm sorry, but i'll dig it out of storage and take the wheels off to show a bit more for you Quote
BigBrick88 Posted December 3, 2019 Posted December 3, 2019 17 hours ago, bonox said: neither i'm sorry, but i'll dig it out of storage and take the wheels off to show a bit more for you That would be great. Thank you Quote
bonox Posted December 5, 2019 Posted December 5, 2019 (edited) Hope this is of some use. As far as a parts list, I would start with 200 headlight bricks, 50 6x16 plates and 300 1x8 bricks or variations thereof. The leading 1x16 bricks across the frame inside the box provide lateral support over the king pin. The trailing lateral structure is two stacks of four 2x16 plates between the axles. Longitudinal structure is the traditional technic technic bricks separated by two plates and periodic pinned support between the rails. Is your cabover a special design of yours or a 5563 body on the 5571 chassis? Edited December 5, 2019 by bonox Quote
BigBrick88 Posted December 5, 2019 Posted December 5, 2019 (edited) 3 hours ago, bonox said: Hope this is of some use. As far as a parts list, I would start with 200 headlight bricks, 50 6x16 plates and 300 1x8 bricks or variations thereof. The leading 1x16 bricks across the frame inside the box provide lateral support over the king pin. The trailing lateral structure is two stacks of four 2x16 plates between the axles. Longitudinal structure is the traditional technic technic bricks separated by two plates and periodic pinned support between the rails. Is your cabover a special design of yours or a 5563 body on the 5571 chassis? Thank you for the extra photos! They should help me come up with a trailer. I bought instructions from Yannick1988. http://www.bricklink...p?p=Yannick1988 My dad have a few cabovers over the years. They have a special place in my heart. I would upload a picture, but I haven't figured out how to make the image size smaller. Edited December 5, 2019 by BigBrick88 Quote
MT5571 Posted May 2, 2020 Posted May 2, 2020 Hello everybody ! I’m very happy to see this topic. I’m 35 years old and owner of the mythic model team 5571 black cat since 1996. It was dismantled since 20 years and stocked in my garage without any attention. While this difficult period of no working cause Covid 19, I answered myself to do something fun. Maybe destiny but I found hazardously in a plastic pocket the black cat ! Some parts are missing for sure and the other are dirty. I decided to clean all the parts, and make a list of missing parts. I have finally 95% of the truck and I found the missing parts on the web. I was very very surprise to see the price of complet set or simply chrome parts !! It’s crazy ! I quickly understood that I had a little gem at home and that I should take great care of it now. The black cat truck is finish now and is very nice like I was a kid. But I watch some video on YouTube and what ? Surprise ! Someone show his black cat with a huge trailer !! I said immediately I want built it ! Some searches on the web and I’m here. I have now ordered all the parts to make this beautiful trailer. The only thing who not going to do identically is the pneumatic stand. I'm thinking about something with gear and linear teeth. Some pictures will come when all will be done. MT from France Quote
come2me Posted May 2, 2020 Posted May 2, 2020 Yes ! It's the most beautiful model team ! The trailer is incredible. With the other model team sets it's more impressive i think ! Quote
MT5571 Posted May 12, 2020 Posted May 12, 2020 You can find here : Brick link CAD black cat & trailer the blackcat and his trailer build with stud.io software if someone need the complete CAD file send me an MP. enjoy Quote
