9v system Posted July 22, 2021 Posted July 22, 2021 On 7/20/2021 at 9:08 PM, Ankoku said: They are selling the files created by Akiyuki himself as well. i saw that as well, i found this site through one of the copied sets instructions which one of my friends sent to me On 7/20/2021 at 5:04 PM, djm said: Given that website is using LEGO as part of its name, you may want to consider informing LEGO itself - they do not take kindly to misappropriation of their name as part of a website. David yea i was thinking of the best way to get it taken down, this might be a good option Quote
9v system Posted July 31, 2021 Posted July 31, 2021 has anyone got an MPD file of the planets and invisible lift? i need them for a layout plan im doing in stud.io thanks Quote
Ankoku Posted August 5, 2021 Posted August 5, 2021 @9v system, @Berthil, @dunes: Just as a heads-up, LEGO Brick & Pieces has black bushes in stock. Quote
9v system Posted August 25, 2021 Posted August 25, 2021 is @Courbet still active here? i need to get a file from him for the screw type 3 but not sure if he is still around Quote
Ankoku Posted August 26, 2021 Posted August 26, 2021 If you mouse over his name, he last visited 8 hours ago :P If you click on his name you can see what he has been posting. Quote
9v system Posted August 26, 2021 Posted August 26, 2021 (edited) 5 hours ago, Ankoku said: If you mouse over his name, he last visited 8 hours ago :P If you click on his name you can see what he has been posting. his last post was from 2020, thats why i thought i would ask, i really want to do the V2 version of the screw type 3 as its missing from the project, would be great if i can get the file of the V1 so it makes it easier for me. i will PM him also have you been able to finish the ball factory? im currently building the V2 of it as i have the V3 version, what were some of the major changes you made to make it more reliable? Edited August 26, 2021 by 9v system Quote
Ankoku Posted August 26, 2021 Posted August 26, 2021 The original v2 is fundamentally wrong. So basically, I changed everything. If you look at the v3 thread, you can see many of the changes which were done because they were either wrong, or done because the entire thing was set at the wrong height. Quote
9v system Posted August 26, 2021 Posted August 26, 2021 3 minutes ago, Ankoku said: The original v2 is fundamentally wrong. So basically, I changed everything. If you look at the v3 thread, you can see many of the changes which were done because they were either wrong, or done because the entire thing was set at the wrong height. thanks, i will have a look at the changes Quote
Ankoku Posted August 26, 2021 Posted August 26, 2021 Slider = Completely wrong. Bob = Little bit wrong. Wheel = Wrong height. Drop tower = Wrong height and the slide left to right is wrong.Also, how the counter weight and pull down mechanism is done is completely wrong. Buck lifter = Wrong, which makes it have an odd motion. This requires changing to both how the gears are position and the lifting mechanism. Pistons = Wrong. Unload Tower = Different in design. Bucket grabbing pieces = wrong. That is a quick summary. Quote
9v system Posted August 26, 2021 Posted August 26, 2021 6 minutes ago, Ankoku said: Slider = Completely wrong. Bob = Little bit wrong. Wheel = Wrong height. Drop tower = Wrong height and the slide left to right is wrong.Also, how the counter weight and pull down mechanism is done is completely wrong. Buck lifter = Wrong, which makes it have an odd motion. This requires changing to both how the gears are position and the lifting mechanism. Pistons = Wrong. Unload Tower = Different in design. Bucket grabbing pieces = wrong. That is a quick summary. thanks just read through all the changes you did, i have already done the chain drive mod with the extra 1x3 thin liftarm, does the height of the bucket wheel cause a many issues? i found my older factory i built in 2015 didnt have any issues in this area. Quote
Ankoku Posted August 26, 2021 Posted August 26, 2021 Well, the entire factory needs to be 1 plate higher. The wheel height is just changed accordingly. Basically, it is one of those things where I never would have been able to fix it, if it wasn't for the original work done. Would have been too daunting for me. That said, the mistake with the height had ripple effects across the whole thing. The slider was wrong because there was no way to see it. I managed to work out most of it via slow motion screen grabs etc. but in the end got photos and confirmation from Akiyuki. So that one was mission impossible. Quote
9v system Posted August 26, 2021 Posted August 26, 2021 11 minutes ago, Ankoku said: Well, the entire factory needs to be 1 plate higher. The wheel height is just changed accordingly. Basically, it is one of those things where I never would have been able to fix it, if it wasn't for the original work done. Would have been too daunting for me. That said, the mistake with the height had ripple effects across the whole thing. The slider was wrong because there was no way to see it. I managed to work out most of it via slow motion screen grabs etc. but in the end got photos and confirmation from Akiyuki. So that one was mission impossible. yea i saw the slider changes, looks like it should work well now with very little issues, one of my friends was having some issues with the bucket placer so i was able to help him out Quote
Ankoku Posted August 26, 2021 Posted August 26, 2021 This highlights the height difference: This shows the gear position difference: I think it was the wall on the right of the render which made me realise the height of everything was out, as there was either a reasonable photo of video screenshot of it, where you could distinguish the individual bricks. Quote
9v system Posted August 26, 2021 Posted August 26, 2021 @Ankoku interesting changes, does the new linkage that pulls the pulls the shiffer in and out still have issues with binding? also is the 1x14 technic brick needed in front of the pistons? or is it just extra support? Quote
Ankoku Posted August 26, 2021 Posted August 26, 2021 In both images, they aren't my mods. They are what Akiyuki has on the latest iteration of his Ball Factory v2. I am basically, apart from adding of a few tiles, just replicating his exactly. A lot of changes have occurred since 2015. I have never had the slider bind to be honest. There is extra bracing to stop bending. You can see what he has done here:https://bricksafe.com/pages/Ankoku/akiyuki-shifter Quote
9v system Posted August 26, 2021 Posted August 26, 2021 13 minutes ago, Ankoku said: In both images, they aren't my mods. They are what Akiyuki has on the latest iteration of his Ball Factory v2. I am basically, apart from adding of a few tiles, just replicating his exactly. A lot of changes have occurred since 2015. I have never had the slider bind to be honest. There is extra bracing to stop bending. You can see what he has done here:https://bricksafe.com/pages/Ankoku/akiyuki-shifter ah ok, i also had issues with the ball dropper binding on the axles and it took forever to get it working right, it used to keep pulling the axle out of the connector sometimes, did you have this issue too? Quote
Ankoku Posted August 26, 2021 Posted August 26, 2021 Nah, the dropper is super smooth. Basically the mechanism for moving it left to right was wrong. Which produced a lot of unnecessary torque. I fixed that and it made it run without any issues. e.g. you run it by rotating the axle earlier in the drive chain and it doesn't really offer any resistance. That was before replacing the runner axles having tested them with the axle straightness tester. When I say "Fix", I just mean make it the same as the Akiyuki one. Quote
9v system Posted August 26, 2021 Posted August 26, 2021 4 minutes ago, Ankoku said: Nah, the dropper is super smooth. Basically the mechanism for moving it left to right was wrong. Which produced a lot of unnecessary torque. I fixed that and it made it run without any issues. e.g. you run it by rotating the axle earlier in the drive chain and it doesn't really offer any resistance. That was before replacing the runner axles having tested them with the axle straightness tester. When I say "Fix", I just mean make it the same as the Akiyuki one. i noticed it has an extra plate behind the lever that rotates 180 degrees, does that extra plate layer reduce some of the strain on that part? Quote
Ankoku Posted August 26, 2021 Posted August 26, 2021 Some of his photos for one part of the dropper:https://bricksafe.com/pages/Ankoku/akiyuki-ball-dropper They key issue was that this piece: Was the wrong way around. I will take a photo of how it should be in a bit. Quote
Ankoku Posted August 26, 2021 Posted August 26, 2021 (edited) This should be correct in respect to the top part of the dropper. Back: The main thing with the ball factory is to try and keep all the components disconnected and hand crank everything. To make sure the resistance is minimal. Edited August 29, 2021 by Ankoku Images had a piece the wrong way round! Quote
Ankoku Posted August 26, 2021 Posted August 26, 2021 The bottom section. As you can see, there are a lot of height changes. I am literally doing this as we post here, which is why it is a bit drip feed. Quote
9v system Posted August 27, 2021 Posted August 27, 2021 @Ankoku thanks for the photos, will help me when i get to this part in my build of the factory. Quote
9v system Posted August 29, 2021 Posted August 29, 2021 On 8/27/2021 at 6:53 AM, Ankoku said: This should be correct in respect to the top part of the dropper. i think that piece is around the wrong way in this render. Quote
