MilkPls69 Posted December 26, 2015 Posted December 26, 2015 Been working on some new rear exhausts so they have that pink effect like the t-65 Link to the LXF file would appreciate some tips to fix the nose or add the new one oh and have done my best to stop loose bricks. http://www.mediafire.com/download/u4penmcq4pxd7to/T-70+XWing.lxf Quote
MoppeW40k Posted December 26, 2015 Posted December 26, 2015 (edited) Hi there, hijacking the topic of "All in the Reflexes", the LDD file of "Pcm979", the Wing Folding Mechanism of Mike Psiaki and some of the ideas of the other members replying to this topic i present a work in progress of the T-70 with a more durable Wing Folding Mechanism Wings by Dr John Zoidberg, auf Flickr https://www.dropbox....6_1900.lxf?dl=0 Edit: To lower the part count my PC had to handle, I changed to the TLG version of the Engine Intakes. Planning to change back to the design version of All in the Reflexes later Best wishes Sebastian Edited December 26, 2015 by MoppeW40k Quote
MoppeW40k Posted December 26, 2015 Posted December 26, 2015 Hi, Sorry for the double post. Surprisingly I had some time to edit the LDD file a little bit further. I added and modified the original fuselage of "All in the Reflexes", his cockpit solution with part 4474 and the nose with landing gear of "Pcm979" Attack Position by Dr John Zoidberg, auf Flickr Folds nicely into cruise mode Cruise Mode by Dr John Zoidberg, auf Flickr I maybe pass the relay staff to someone else now ;-) https://www.dropbox....6_2100.lxf?dl=0 Kind regards Sebastian Quote
Pcm979 Posted December 26, 2015 Posted December 26, 2015 Link to the LXF file would appreciate some tips to fix the nose or add the new one oh and have done my best to stop loose bricks. Unfortunately, both of your T-70s have all of the loose brick issues that I've mentioned before, and the black one in particular- Somehow the nose is now in twelve unconnected pieces! I- I have no idea how to fix that; I suggest you delete the black one, apply my loose parts fixes to the white one, copy and paste it, and recolour it. I noticed two problems with your T-65 as well. On the backs of the wings, the parts I've highlighted in purple aren't connected to the rest of the ship: There are multiple ways of fixing this, but the strongest way would unfortunately involve losing those black and white stripes on the wings. Meanwhile, these parts on the nose don't attach properly. I don't know if that's a problem with LDD or not, and therefore I can't tell how to fix it. Speaking of the nose, I can't help you with adding the new nose, because I didn't move the new nose to my old model; I redid all the alterations from the old model onto the new one. Hi, Sorry for the double post. Surprisingly I had some time to edit the LDD file a little bit further. I added and modified the original fuselage of "All in the Reflexes", his cockpit solution with part 4474 and the nose with landing gear of "Pcm979" Wow, I'm honoured that you added my alterations! I see you haven't been able to solve the loose parts problem on the nosecone; I'm starting to think that having a nice-looking folding front landing gear on this version of the model is impossible.Speaking of loose parts- how on Earth did that become my specialty? -I noticed that some of the rear blocks got loosened when you changed the wing mechanism. Here's an unmodified one next to your modified one, with the wings removed so we can get them in the same shot. You can see that a 1x4 Plate is missing. Unfortunately, it won't fit without making some room. You need to remove these parts: And this part: Then it'll fit. Luckily, cleaning up the resulting asymmetry is easy. Quote
MilkPls69 Posted December 27, 2015 Posted December 27, 2015 Unfortunately, both of your T-70s have all of the loose brick issues that I've mentioned before, and the black one in particular- Somehow the nose is now in twelve unconnected pieces! Meanwhile, these parts on the nose don't attach properly. I don't know if that's a problem with LDD or not, and therefore I can't tell how to fix it. Thanks for pointing out the loose parts and with the normal X-wing it is a LDD thing that stops those front parts from connecting and I will do what you suggested for the black one. Quote
MoppeW40k Posted December 30, 2015 Posted December 30, 2015 (edited) Hello again, thank you for helping with the loose parts! The front landing leg was the next task (and i think the last for me) on the list. 6 hours into fiddeling i had the idea to move part 2413 backwards by one or two studs. 5 noses later ... Noses by Dr John Zoidberg, auf Flickr i'm satisfied. LandingLeg by Dr John Zoidberg, auf Flickr It retracts smoothly. Retracted by Dr John Zoidberg, auf Flickr Anyone who wants to take a look: https://www.dropbox....0_2300.lxf?dl=0 kind regards Sebastian Edit: To complete the mashup, i added "MilkPls69" wing stripes Edited December 30, 2015 by MoppeW40k Quote
MilkPls69 Posted December 31, 2015 Posted December 31, 2015 After seeing what Moppew40k did with adding the new nose (which is some top notch work btw) I took his design and added the retro thruster design from the original T-70 that started this thread and I think I am finally happy with how it looks accuracy wise. Not sure how it will hold up IRL but with a few bricklink orders I am sure we will find out! Quote
Dameronian Posted December 31, 2015 Posted December 31, 2015 I truly admire and appreciate the teamwork guys! Awesome! Quote
Pcm979 Posted December 31, 2015 Posted December 31, 2015 Wow, I honestly thought that it couldn't be done! Great work! On my Loose Parts Watch, your changes to the nose dislodged the pilot's console. It's an easy fix, though. Simply remove the highlighted parts and replace them with the assembly shown, which is just a 2x2 plate on top of a 2x2 brick: There are also those parts you set off to the side, but I'm assuming that they're over there for a reason. One thing I noticed while I was messing with your design is this detail around the Psiaki wing mechanism you added: I'm not familiar with the mechanism, so I hope you don't mind if I ask, is that enough clearance for them to open? Quote
Dameronian Posted December 31, 2015 Posted December 31, 2015 BTW, I keep forgetting to ask: How exactly do the rear landing skids fold away? Quote
Rishab N Posted December 31, 2015 Posted December 31, 2015 Great collab project! Hopefully this model can be built in bricks Quote
MoppeW40k Posted December 31, 2015 Posted December 31, 2015 (edited) Hi there, On my Loose Parts Watch, your changes to the nose dislodged the pilot's console. It's an easy fix, though. Simply remove the highlighted parts and replace them with the assembly shown, which is just a 2x2 plate on top of a 2x2 brick: There should be a 1x2 plate in front of two red and yellow plates connecting to the headlight bricks in front. Thank you, i don't know that plate got missing. There are also those parts you set off to the side, but I'm assuming that they're over there for a reason. There are two reasons. When the wings are folded, part 42610 of the lower wings conflict withe a wedge plate (highlighted green in the next picture) of the upper wing. I think in real life there should be enough "wiggle room" that part 42610 can stay attached. I added them in the LDD file to not forget them while ordering the parts. ClosedWingsPartConflict by Dr John Zoidberg, auf Flickr Second: there are three parts 6558 that will replace a long red technic axle on the real model in the wing folding mechanism. On previous versions of the LDD file i lay aside some parts in case i did not want a rear landing gear. One thing I noticed while I was messing with your design is this detail around the Psiaki wing mechanism you added: I'm not familiar with the mechanism, so I hope you don't mind if I ask, is that enough clearance for them to open? It has enough clearance. The parts you higlighted do not interfer with the opening of the upper wings. OpenWingsTop by Dr John Zoidberg, auf Flickr The parts that restrict the movement of the upper wings are not visible from the top. The movement is either restricted by some plates in the inner workings of the fuselage or these green highlighted tiles on the lower wings, time will tell on the real model ;-) OpenWingsBelly by Dr John Zoidberg, auf Flickr BTW, I keep forgetting to ask: How exactly do the rear landing skids fold away? The model is now with 100 percent more retractable rear landing gear, they did not retracted in the last version. OpenWingsBellyLG by Dr John Zoidberg, auf Flickr Great collab project! Hopefully this model can be built in bricks Not sure how it will hold up IRL but with a few bricklink orders I am sure we will find out! I hope so, too! I just placed my first order on Bricklink today for this project. I truly admire and appreciate the teamwork guys! Awesome! None of this could have happend without "All in the Reflexes" first releasing the LDD file of his MOC and all the others also releasing the modifications as LDD file. And on this bombshell: The last version of my LDD file ;-) https://www.dropbox....1_1700.lxf?dl=0 Kind regards Sebastian Note on the LDD file: Anyone who finds a dark green tile 1x6. It should be a 1x6 plate, but LDD would not let me rotate the rear landing gear without a tile. But, the engine nacelle depends on a plate. In real life the retracted landing rear should snap in place, hold by on stud of the 1x6 plate. EDIT: the console was not attached by my fix as i would have thought. It was still loose. Fixed LDD: https://www.dropbox.com/s/v7rg2392us50fz6/T-70%20XWing%20MOD_151231_1900.lxf?dl=0 Edited December 31, 2015 by MoppeW40k Quote
All in the Reflexes Posted December 31, 2015 Author Posted December 31, 2015 Well I've been away for a while and this has seemed to become a beast all of its own Quote
MilkPls69 Posted December 31, 2015 Posted December 31, 2015 I just noticed something none of us have even thought about. The lower mounted turret Poe uses at the start of the movie Quote
MoppeW40k Posted January 1, 2016 Posted January 1, 2016 I just noticed something none of us have even thought about. Hi, do you know any source material? I could not find anything on the internet. greetings Sebastian Quote
atlas Posted January 2, 2016 Posted January 2, 2016 Also, it's shown that a BB unit can enter the socket from the belly, like the N-1 starfighter. Quote
Dameronian Posted January 2, 2016 Posted January 2, 2016 (edited) Hi, do you know any source material? I could not find anything on the internet. greetings Sebastian Well, the source material for the two features described by atlas and Milkpls69 is THE source, the movie.... Edited January 2, 2016 by Dameronian Quote
Pcm979 Posted January 2, 2016 Posted January 2, 2016 (edited) Also, it's shown that a BB unit can enter the socket from the belly, like the N-1 starfighter. It can also shoot energy beams and fly. Some things just aren't going to be possible. Edited January 2, 2016 by Pcm979 Quote
Najra Posted January 3, 2016 Posted January 3, 2016 I just reinstalled LDD version 4.3 on my iMac running OSX 10.11. Every time I try to open LDD it gives the message "LDD cannot access the web server to retrieve new bricks. Do you want to run in offline mode? NO / YES". This is strange as LDD shows that it has just downloaded 37 MB of new parts. I have no firewall issues as far as I am aware of as every other program I use does work. Unfortunately clicking Yes, to turn LDD in offline mode, does not help as the program automatically shuts down. 1. Does anyone here knows what's wrong? 2. Can someone post a pdf version of this T-70 XWING mod because I cannot wait to start building it. 3. Is there a T-65 XWING mod available from the samen builder? If yes, I would like to have the pdf for that one as well. But best would be to have a working version of LDD on my machine.... Thanks!!! Arjan Quote
ScottishDave Posted January 3, 2016 Posted January 3, 2016 I've just been browsing this thread again. Good work, you lot. This collaborative x-wing is almost as pretty as mine! One small thought for you all: with the Psiaki-style x-wings mechanism, you do NOT need to make one set of wings upside down. You can use some 180 snot in the lower engines (which have plenty of room inside them) and have both sets of wings the right way up. As an added bonus, you then no longer have the pesky issues with the wings having a half-plate-thickness gap between them. Quote
Renegade Clone Posted January 4, 2016 Posted January 4, 2016 If anyone is interested, I installed a new X-Wing cockpit on a Psiaki T-65, with a few modifications and additional greebling. It is purposefully angled to match the actual model. It gives you an idea how one would look on this magnificent T-70 design. http://www.brickshelf.com/gallery/RenegadeClone/X-Wing/20151231_004730.jpg http://www.brickshelf.com/gallery/RenegadeClone/X-Wing/20151231_004806.jpg http://www.brickshelf.com/gallery/RenegadeClone/X-Wing/20151231_004839.jpg http://www.brickshelf.com/gallery/RenegadeClone/X-Wing/20151231_041511.jpg Quote
All in the Reflexes Posted January 4, 2016 Author Posted January 4, 2016 Thanks for doing that Renegade, its good to see how it fits. I've ordered the canopy as well and am just waiting for my brick orders to come in so i can start building my design. Nice to see so many people take an interest in it :) Quote
Commander Colt Posted January 5, 2016 Posted January 5, 2016 I have nothing to add yet, but this thread is marvelous. If I have time I might take a gander as well. Quote
GunwitchUK Posted February 7, 2016 Posted February 7, 2016 Just browsing through this thread and made me realise i really need to get my backside into gear. Many thanks for the LDD files, they'll come in handy for me, a total virgin to moccing stuff. All the input from everyone on this thread is very impressive. Quote
