only one I can think of is this one but its maybe smaller and lighter than you need - oh and no axle hole so a friction pin you would have to use (or clamp it tight)
Edited by Rockbrick
  • Replies 67
There is a rarer part ... 2740c01, which is 7 stud dia, and from 8855.
Mind you, I don't have one of these so, I can't really comment on whether it would be suitable.
Edit: I think it may be bigger than I thought, having taken a look on BL, sorry.
Edited by Boulderer
That works quite well with a friction pin but is it too small?
The 2740 part is brilliant but way too big for my TC9. The diameter looks about 16 or 17 studs, I must get a couple for future MOCs.
30332 is another cool part I've not seen before. It is too big unless I can lower the ratchet by 2 studs and I can't see a way to do that in a model this small.
I've built two velocity type planes and they both have much larger propellers... That propeller looks way too small... Work it out because the A model is my favourite, I trust you :wink: Okay, my mistake, velocity planes don't have "radar" so your type of plane could have smaller propeller... Maybe just one step bigger propeller and it is like spot on... Everything is so cool at this point, if you could you should :wink: That part 30332 is just perfect but if it does not fit I think this current propeller do its' job quite well.
Edited by MacKaiwer
What is the largest diameter you can have for your dimensions ? 7 studs? You could do something with tiles (below), but use 1x3 tiles for the blades.
So just add a turntable or a string to the A! ;-)
E.g. A whinch with a string for the SUV?!
BTW: incredible cute A model
Edited by Kumbbl
Give the SUV a winch? :classic:
For the turntable... this trailer doesn't really give a good excuse to use it as a connection point to the car, so design a new propeller around it?
edit: basically what the guy above said lol
Edited by Appie
Everything I want to build for the B has something important missing. A turntable and string would have been nice.
What are you going to build; some sort of crane thing perhaps?
I started building an ambulance but it turned in Ecto1 and then a Cadillac convertable.
It has also been a fire engine and a trophy truck today.
I started building an ambulance but it turned in Ecto1 and then a Cadillac convertable. It has also been a fire engine and a trophy truck today.
It is good to see that you are trying all the possibilities. Do you have any pictures to show us?
