Elostirion Posted July 31, 2016 Posted July 31, 2016 Could we maybe add the challenge-threads as well as result-post-links to the Master Index? Quote
narbilu Posted August 3, 2016 Posted August 3, 2016 Hi all, This may be somewhere in the thread already, but a small question: Can you use the coins earned in freebuilds, use in the same month to buy additional buildings? For instance, I just posted two freebuilds giving me 20 DBs. Can those 20 DBs be used in August? Yours, Captain Bran Quote
Tomsche Posted August 3, 2016 Posted August 3, 2016 Normally, they should already be in your total on the account summary now if they are registered (mind license costs are also substracted already then), so as long as you end the month on the +, it`s all fine Quote
narbilu Posted August 3, 2016 Posted August 3, 2016 Normally, they should already be in your total on the account summary now if they are registered (mind license costs are also substracted already then), so as long as you end the month on the +, it`s all fine Cool thanks, Qjuinnsville will be growing a little more this week Quote
Elostirion Posted August 6, 2016 Posted August 6, 2016 (edited) I want to question the size requirements for a "Viceroy's Palace" (biggest version of Residence). Cost: 300 DBs (10% of other "royal" properties which are at 3.000 DBs) Yield: 15 DBs (3% of other royal properties which are at 500 DBs) I think that the minimum size requirement for a "Viceroy's Palace" should be no more than 48x48 (23% of other royal properties at 100x100). Also I think the size requirements for the other residences should be adapted, my suggestion is: small: 12x12 medium: 20x20 large: 32x32 Reasoning behind that is that a) the yield really sucks b) residences are usually "dense" MOCs of one house consisting of many bricks, unlike e.g. a factory or plantation with much rather "unused" space. Sure, you can always add a garden etc., but that's rather limited for cities as well... What do the officials think? Edited August 6, 2016 by Elostirion Quote
TitusV Posted August 9, 2016 Posted August 9, 2016 I want to question the size requirements for a "Viceroy's Palace" (biggest version of Residence). Cost: 300 DBs (10% of other "royal" properties which are at 3.000 DBs) Yield: 15 DBs (3% of other royal properties which are at 500 DBs) I think that the minimum size requirement for a "Viceroy's Palace" should be no more than 48x48 (23% of other royal properties at 100x100). Also I think the size requirements for the other residences should be adapted, my suggestion is: small: 12x12 medium: 20x20 large: 32x32 Reasoning behind that is that a) the yield really sucks b) residences are usually "dense" MOCs of one house consisting of many bricks, unlike e.g. a factory or plantation with much rather "unused" space. Sure, you can always add a garden etc., but that's rather limited for cities as well... What do the officials think? Seconded. Quote
Capt Wolf Posted August 9, 2016 Posted August 9, 2016 I don't have a problem with the current residence sizes, especially since they're not minimums, but guidelines. And residences shouldn't be a great source of income. But I agree that the minimum size for a viceroy's palace doesn't need to be 100x100. 64x64 should be adequate. I think a palace should be an open, grand thing, but it doesn't need to be as big as a royal factory. Quote
Garmadon Posted August 9, 2016 Posted August 9, 2016 The plot sizes for the royal residences will be remaining the same, but a bit of leeway if necessary will obviously be granted as to size, since the guidelines are not supposed to be rigid rules. As Capt. Wolf said, residences are clearly not ever a huge source of revenue (since that is not their primary purpose), so it makes sense that it will not be nearly as good a return as, for example, a royal factory or plantation. Quote
Legostone Posted August 9, 2016 Posted August 9, 2016 Btw, as it is already the 9th - can we get some information when we can expect the MRCA results? As usual a big thanks to the team working behind the scenes making all this possible;) Quote
TitusV Posted August 10, 2016 Posted August 10, 2016 May I ask where my member title comes from? I've just had two weeks withouth internet acces, so... If I need to apologise somewhere, I'd happily do so. Quote
Capn Frank Posted August 10, 2016 Posted August 10, 2016 If I need to apologise somewhere, I'd happily do so. No apology needed here. Quote
TitusV Posted August 10, 2016 Posted August 10, 2016 No apology needed here. Now I'm even more confused Quote
TitusV Posted August 10, 2016 Posted August 10, 2016 That`s because you where to late Yes, but where? Quote
Tomsche Posted August 10, 2016 Posted August 10, 2016 Couple of quick questions 1. Can I register a ship as an actual property? The idea I`m building around with, is a merchant vessel that will be permanently moored on my second big Quinnsville plate, and in a sort of dock. Basically, a floating shop. 2. Any news when Ska will return, so I can get some info on what sort of mine I ended up with (which was set up end of May) Quote
Capn Frank Posted August 11, 2016 Posted August 11, 2016 1. Can I register a ship as an actual property? The idea I`m building around with, is a merchant vessel that will be permanently moored on my second big Quinnsville plate, and in a sort of dock. Basically, a floating shop. As long as it's not entered in the MRCA, I would say it's fine to have a floating shop. You should not be able to receive yield and trade income from the same building/ship. 2. Any news when Ska will return, so I can get some info on what sort of mine I ended up with (which was set up end of May) None yet. I too am waiting on two mine prospects. Ska has had an extremely busy summer. Quote
Sir Stig Posted August 11, 2016 Posted August 11, 2016 1. Can I register a ship as an actual property? The idea I`m building around with, is a merchant vessel that will be permanently moored on my second big Quinnsville plate, and in a sort of dock. Basically, a floating shop. As long as it's not entered in the MRCA, I would say it's fine to have a floating shop. You should not be able to receive yield and trade income from the same building/ship. Register it as a property. So it is basically artistic freedom on the concept/visual of your property. Cool idea. Quote
kaiju Posted August 15, 2016 Posted August 15, 2016 Do we need a new Monthly Freebuild Registration thread (and webform) or are we running with July's through until the end of August? Quote
Capn Frank Posted August 15, 2016 Posted August 15, 2016 Do we need a new Monthly Freebuild Registration thread (and webform) or are we running with July's through until the end of August? We're just going to have one Free Build Registration topic. We haven't updated the text yet. Quote
TitusV Posted August 15, 2016 Posted August 15, 2016 We're just going to have one Free Build Registration topic. We haven't updated the text yet. Is it then one post/month/person in that thread? Quote
Legostone Posted August 19, 2016 Posted August 19, 2016 Considering that Ska still isn't back, do we have to postpone the next MRCA for longer? Quote
blackdeathgr Posted August 19, 2016 Posted August 19, 2016 Dont worry, things will go back to normal soon. Not that i dont enjoy some summer relaxation these days...! I was always saying that AFOL LEGO building is an indoor activity Quote
Bregir Posted August 22, 2016 Posted August 22, 2016 A question: Have any of you experimented with, or seen anyone experiment with cutting hull pieces in half in order to make wider hulls? The thought just occured to me, and while it involves precision cutting and the "creative destruction" of bricks (oh, the horror!) it might well solve some of the scale issues for larger vessels. (Please don't burn me at the stake for such a heretical suggestion!) Quote
TitusV Posted August 22, 2016 Posted August 22, 2016 A question: Have any of you experimented with, or seen anyone experiment with cutting hull pieces in half in order to make wider hulls? The thought just occured to me, and while it involves precision cutting and the "creative destruction" of bricks (oh, the horror!) it might well solve some of the scale issues for larger vessels. (Please don't burn me at the stake for such a heretical suggestion!) Gimme a torch, so I can burn that heathen myself! Actually, the tought just never came up in me. But that May also be because I don't have any hulls... Quote
