Posted December 22, 20159 yr As mentioned in the introduction thread, the kids and I have been able to get the Winter Village sets over the past several years, and can put together quite a nice little town for Christmas. (Much nicer than the Dept. 56 buildings, IMO .) Last year, we added a loop of track around the village, which sat on a 3'x4' board. It was a little tight, space-wise, so this year we decided to expand! After a shameless land grab in the middle of the family room, we were able to place a 6'x4' board. This allowed us to add a smaller, nested loop, inside the outer one. The frame for the 4x6 table. Since i have a small car, I used three 2'x4' boards for the top. The downside of using separate boards, caulking the gaps and the screw holes. Next time I'll borrow the van and grab a larger board. I used a textured spray paint to cover the whole surface of the table. It took several cans, but I just don't have enough white Lego! In its place of honor in the center of the family room, with the track laid. I picked up the 60051 High Speed Passenger Train (aka the Candy Cane Express) to run around the outside of the village. That's what connects the Winter Village with the "big city." The inner loop, and the switches, are 9v track. We have the 4535 Lego Express Deluxe running around the inside as a "tourist train." I think next year, we're going to tray to make that into a tram, as the full train is a bit much. I love Miro Dudas' Winter Village Tram. We chose to have a small mountain in the corner, to give us an elevated area to set up Santa's Workshop at the North Pole, and because I love tunnels! I laid out a template for the "mountain" before building it. The mountain still needs to be painted, and a slope built to cover the hole facing the village. That's being built up out of styrofoam sheets, and will be added to the display soon. I'll have an updated photo to show that. The old and the new, side by side. I was recently fortunate enough to win an ebay auction for a set of Lego Super Chief cars and a Santa Fe locomotive. I like the look of this much better than the high speed train, so that will replace that train on the outer loop. But first I'll need to convert one of the locomotives (I already had a pair bought from Lego when they first came out) to ruin off PF, or get enough 9v track to make the outer loop electric. Right now, I have enough to do one or the other loops in 9v track, but not both. (Here's a short .) I still need two more of the original cars, and I'd love to add an MOC dome car and B-unit locomotive... maybe for next Christmas.As mentioned, we're combining the 9V and plastic track, and it works as long as we can throw the switch fast enough that the steamer does not get sent to the unpowered track! This video shows my daughter handling the . One of the hazards of railroading with Lego. This NEVER happened on my old N-scale layout. We are by no means "theme purists" and often mix and blend - in fact, I think the Empire has scheduled a stormtrooper raid on the village to control the scourge of hobbits (they love to pilfer goodies from the bakery) later today! Merry Christmas everyone! Edited December 22, 20159 yr by Crossbones
December 22, 20159 yr Looks like a lot of fun. Does the texture paint help keep the tracks from moving?
December 22, 20159 yr Good questions above - also is that really drywall? Don't the edges get messy? I am thinking when I make a table that I'd do what I did in my workshop - hardboard over plywood. But then the question above is a good one - I currently use large felt sheets (with a bit of glitter) to cover the tables I use, but that's only because it's not a permanent layout. The textured paint to help keep things from easily slipping seems interesting.
December 22, 20159 yr Author Thanks! And thanks for the questions - fire away if you have more. Looks like a lot of fun. Does the texture paint help keep the tracks from moving? Yes, the tracks actually do not move much if at all. They move a little if I run the train at full speed, but then it derails on the curves anyway so it's a moot point! :) Good questions above - also is that really drywall? Don't the edges get messy? I am thinking when I make a table that I'd do what I did in my workshop - hardboard over plywood. But then the question above is a good one - I currently use large felt sheets (with a bit of glitter) to cover the tables I use, but that's only because it's not a permanent layout. The textured paint to help keep things from easily slipping seems interesting. Actually, the surface is not drywall, it's MDF (Medium Density Fiberboard) I got it at the Home Depot. It is VERY smooth so it does look like drywall in the pictures (the flash washed it out so it looks whiter than it is - it's actually a light brown). I'll probably do something similar when I do a more permanent layout in the basement, but I'll likely want to use Lego baseplates at that point.
December 25, 20159 yr Author OK, I finished the mountain. gave it a coat of white over some texture to match the rest of the board. I added tunnel portals carved out of styrofoam as well to add a little detail: Merry Christmas everyone!
December 27, 20159 yr Author A couple of additions. Yesterday I dug out a box I'd had since they were being cleared out - the 79111 Lone Ranger train set. I enjoyed building it, it really is a cool set with a lot of neat details. But there was something missing - a motor. I found an online video by Patent Pom showing how to do it. I did not have enough bricks to complete it (Bricklink order placed! ), but it works: And, while it was makings its rounds, we discovered that the Orcs were hard at work beneath the tunnel, setting up explosives to bring it down!
January 12, 20169 yr That is a very nice Winter Village project. I like the progress pictures and the elevated North Pole with ski slope coming down the side and the integrated tunnel turned out great. I picked up the 60051 High Speed Passenger Train (aka the Candy Cane Express) to run around the outside of the village. That's what connects the Winter Village with the "big city." The inner loop, and the switches, are 9v track. We have the 4535 Lego Express Deluxe running around the inside as a "tourist train." I think next year, we're going to tray to make that into a tram, as the full train is a bit much. I love Miro Dudas' Winter Village Tram. Thank you for liking my Winter Village Tram. I designed it at the end of last year mainly for two reasons: 1) I always wanted a tram in my Winter Village and 2) to have something new to add to my Winter Village since the Toy Shop was a rerelease. I agree, the tram does provide a nice alternative for those that don't have the space for a full trainlayout. I look forward to your next Winter Village setup with the tram incorporation. I am always curious how people incorporate it. Cheers and Happy New Year!
