Harrie45 Posted January 11, 2016 Posted January 11, 2016 (edited) When I bought the home version of Mindstorms EV3, I was disappointed that the gyro sensor was not included. So I bought the gyro sensor, and also the ultrasonic sensor, separately. Using the elements from the home EV3 set and the 2 sensors I made this model. (utrasonic sensor is optional) gyroboyharrie, a shooting gyroboy Control via colored bricks, infrared remote or Android phone.Even infrared beacon following is included. In case the optional utrasonic sensor is used it will avoid objects. If you want to see it in action: https://www.youtube....h?v=5nxW51COfIs Building instructions: https://www.youtube....h?v=GP7Y2l_wdn8 .lxf file for Lego Digital Designer is attached. Use Lego Digital Designer to generate better visible, but less logical, instructions. The complete .EV3 file on request. (EV3 @ harrie.info -remove spaces) gyroboyharrie.lxf Edited January 11, 2016 by Harrie45 Quote
DaveDoc Posted November 19, 2016 Posted November 19, 2016 Hi, I'd like to build your version of Gyroboy with my 2 grandkids. Can you send me the .ev3 program file, if you don't mind. Thankyou. Quote
oracid Posted November 20, 2016 Posted November 20, 2016 It looks fine. I am too interested about the .ev3 file and most of all about the gyro sensor MyBlock. Thank you. Quote
DaveDoc Posted November 21, 2016 Posted November 21, 2016 On 11/01/2016 at 11:16 PM, Harrie45 said: When I bought the home version of Mindstorms EV3, I was disappointed that the gyro sensor was not included. So I bought the gyro sensor, and also the ultrasonic sensor, separately. Using the elements from the home EV3 set and the 2 sensors I made this model. (utrasonic sensor is optional) gyroboyharrie, a shooting gyroboy Control via colored bricks, infrared remote or Android phone.Even infrared beacon following is included. In case the optional utrasonic sensor is used it will avoid objects. If you want to see it in action: https://www.youtube....h?v=5nxW51COfIs Building instructions: https://www.youtube....h?v=GP7Y2l_wdn8 .lxf file for Lego Digital Designer is attached. Use Lego Digital Designer to generate better visible, but less logical, instructions. The complete .EV3 file on request. (EV3 @ harrie.info -remove spaces) gyroboyharrie.lxf Edited January 11 by Harrie4 I tried downloading your gyroboyharrie.lxf file, but LDD always told me - Unable to open file ?????? Help: Why does Lego Digital Designer say - Unable to Open File - when I download gyroboyharrie.lxf from your post ? Quote
oracid Posted November 21, 2016 Posted November 21, 2016 Thank you very much for the files. You made a very good work. In the .ev3 file, I can see 2 MyBloks which are named Gyro and Balance. Can you tell me more about this 2 blocks . Quote
kabigon3 Posted March 20, 2019 Posted March 20, 2019 Hi Harrie, I'd like to build Gyroharrie with my 2 students. Could you send me the .ev3 program file, if you don't mind. Thankyou. Quote
Nedde11 Posted August 3, 2024 Posted August 3, 2024 @Harrie45 I just found your GyroBoyHarrie. Would you share the code with me? Quote
Berthil Posted August 4, 2024 Posted August 4, 2024 On Pybricks is the similar Gyro Boy, you can get the Python code for it and links to the Mindstorms building instruction:https://pybricks.com/ev3-micropython/examples/gyro_boy.html Quote
