SNIPE Posted March 8, 2016 Posted March 8, 2016 New discovery The lower conveyor belt use a 12-gear disk to turn the turntable, instead of a 12-gear black gear. Under the conveyor belt are two 6-hole disks. They fit well with the slits on the curved gear racks. I don't understand.. Quote
pgplay Posted March 8, 2016 Posted March 8, 2016 New discovery The lower conveyor belt use a 12-gear disk to turn the turntable, instead of a 12-gear black gear. Under the conveyor belt are two 6-hole disks. They fit well with the slits on the curved gear racks. The belt is motorised by a large turntable, the new turntable - the yellow one is more like a track and the wedge wheel rides on it for stability From what I see Quote
Ngoc Nguyen Posted March 9, 2016 Posted March 9, 2016 The belt is motorised by a large turntable, the new turntable - the yellow one is more like a track and the wedge wheel rides on it for stability From what I see Yeah that's what I want to say. Quote
Ngoc Nguyen Posted March 10, 2016 Posted March 10, 2016 New discovery: - The undercarriage uses 4 of these http://brickset.com/parts/design-92907 to secure the round gear racks. Proof: http://www.hobbymedia.it/img/2016/01/lego-technic-bucket-wheel-excavator-4.jpg . Look closely, above the yellow 5M axle. Quote
legobeast73 Posted March 11, 2016 Posted March 11, 2016 when will we see more sneak peeks at 42055 Quote
DrJB Posted March 11, 2016 Posted March 11, 2016 New discovery: - The undercarriage uses 4 of these http://brickset.com/parts/design-92907 to secure the round gear racks. Proof: http://www.hobbymedi...excavator-4.jpg . Look closely, above the yellow 5M axle. You really have an eye for the smallest of details ... impressive! Quote
Maaboo the Witch Posted March 11, 2016 Posted March 11, 2016 (edited) Must have gone to SpecSavers !, That's just awful. Edited March 11, 2016 by Maaboo35 Quote
roppie11 Posted March 11, 2016 Posted March 11, 2016 I think they brought this set because the 42030 did very well, regardless of its huge pricetag. I'm not quite sure how i feel about the look of this thing, but nearly 4000 parts is going to be fun! it's a pity though that the mining truck is included.why would they do that? did they really want to put as many parts as possible in one set? Yep they moves most jerky when the conveyor belts and the turret rotate at the same time. The torque is split. Talking about which I don't understand why Markus design the way that the turret only rotates when the belts are rotating. I mean why not make the two functions separate... well, i'm not entirely sure but i believe that's how they normally work with these machines. They put on the wheel, and than slowly rotate it. then they drive several meters and do it again and again untill everything is dugged away Quote
DrJB Posted March 11, 2016 Posted March 11, 2016 Correct, th two motions have to be linked, either mechanically or via electronics/hydraulics. In the lego rendition they sure opted for the mechanical way. The only way for that machine to cut continuously is for both the bucket wheel and tracks to be running at the same time. Quote
Riley-NZL Posted March 11, 2016 Posted March 11, 2016 Correct, th two motions have to be linked, either mechanically or via electronics/hydraulics. In the lego rendition they sure opted for the mechanical way. The only way for that machine to cut continuously is for both the bucket wheel and tracks to be running at the same time. It kind of depends on the mine, if they are doing long straight sections, then yes the tracks would be moving along with the head, but in corners/curves it wouldn't, it would be moving along with slew. There would also be times, that it would be stationary, and using the head while lifting/lowering the the arm. But in pretty much all cases, something would be moving as well as the bucket. Quote
Gabi_BC Posted March 11, 2016 Posted March 11, 2016 But in pretty much all cases, something would be moving as well as the bucket. Quote
Ngoc Nguyen Posted March 12, 2016 Posted March 12, 2016 (edited) I think it is very likely that: There is no axle running under the upper belt. - First, you guys can look at this, full screen, resolution 1080px: https://www.dropbox.com/s/7oioxojya4ndgzc/Screenshot%202016-03-13%2014.08.11.png?dl=0 . The yellow axle goes through a black bracket (http://brickset.com/parts/design-87408) that leads to the upper belt, then another bracket that goes down to the lower belt. This means the upper belt only gets one transmission input. - Second, look at this, also full screen, resolution 1080px: https://www.dropbox.....39.37.png?dl=0 . In the upper left corner there is this gear: http://brickset.com/parts/design-87407 . It is used to support the upper belt. And through the liftarm holes next to it I don't see anything like an axle or supporting an axle. So I think the motion of the bucket wheel is transmitted through the belt itself, not an axle running below it. Edited March 13, 2016 by nguyengiangoc Quote
andrewganschow Posted March 13, 2016 Posted March 13, 2016 If your correct, and I think you are, it'll be interesting to see how much strain the belt can take of running the bucket and it's self, I plan on some hard core testing of this feature. Quote
Ngoc Nguyen Posted March 13, 2016 Posted March 13, 2016 Brace yourself for more color vomit: The BWE has 10M axle and 8M axle in red, but 6M axle is in black https://www.dropbox.com/s/2yzu8dmgle347nf/Screenshot%202016-03-13%2015.56.53.png?dl=0 Quote
wumsi Posted March 13, 2016 Posted March 13, 2016 Maybe they are red, because the have a different fitting. And if not, that would be something anyone here could easily change Quote
vmln8r Posted March 13, 2016 Posted March 13, 2016 Maybe they are red, because the have a different fitting. And if not, that would be something anyone here could easily change Modify a children's construction toy? Are you sure you can do that? Quote
wumsi Posted March 13, 2016 Posted March 13, 2016 Modify a children's construction toy? Are you sure you can do that? I don't know...i may have to ask my kids for help! Quote
N-4K0 Posted March 13, 2016 Posted March 13, 2016 I don't mind the color vomit with red and yellow axles. One of the things that makes me excited is the 13 dark blue 3x11 panels on the sides of the conveyor belts, and I can count at least 12 of the 5x7 square frames. Dang, what a parts pack this set is! 13 dark blue + at least 1 DBG 3x11 panel 12+ square frames 4 LBG 5x11 panels 8 buckets 2 yellow + 2 white of the new tipper bed panels A load of track links 14 of the new curved yellow quarter circle, whatever it was called, gear rack? And then comes who knows how many pins, beams, axles and what not. Man, just the complete pack of parts itself is almost a good enough reason to buy this set. Quote
andrewganschow Posted March 13, 2016 Posted March 13, 2016 Hmmm, from the sounds of it, I'll have to buy 2 sets, one to build, and one to add to my collection, but on second thought that would require a ton of sorting, and I'm very limited on space right now. Quote
Kman860 Posted March 13, 2016 Posted March 13, 2016 I'm buying two so I can build the a and b models at once and use them together (wallet starts screaming). Quote
Kalhiki Posted March 13, 2016 Posted March 13, 2016 Woah. Didn't realize this set had its own topic. Anywho, I'll be limiting my spending this year to justify buying this. BWEs are my favorite piece of heavy machinery, so having a properly large Lego one is amazing. And everything I've seen of the model makes me excited. I love it. Only problem... Where will I put it? Quote
andrewganschow Posted March 13, 2016 Posted March 13, 2016 Woah. Didn't realize this set had its own topic. Anywho, I'll be limiting my spending this year to justify buying this. BWEs are my favorite piece of heavy machinery, so having a properly large Lego one is amazing. And everything I've seen of the model makes me excited. I love it. Only problem... Where will I put it? I'd say dig a spot with it for it to go. Quote
DrJB Posted March 14, 2016 Posted March 14, 2016 I don't mind the color vomit with red and yellow axles. One of the things that makes me excited is the 13 dark blue 3x11 panels on the sides of the conveyor belts, and I can count at least 12 of the 5x7 square frames. Dang, what a parts pack this set is! 13 dark blue + at least 1 DBG 3x11 panel 12+ square frames 4 LBG 5x11 panels 8 buckets 2 yellow + 2 white of the new tipper bed panels A load of track links 14 of the new curved yellow quarter circle, whatever it was called, gear rack? And then comes who knows how many pins, beams, axles and what not. Man, just the complete pack of parts itself is almost a good enough reason to buy this set. My wish was granted ... a flagship with NO tires, unless you count the small truck! Quote
