It's AWESOME! And it's crude...
- Awesome because the various wedge belt wheels are used to make the realistic exhaust pipes. I've already been impressed at how the buckets are used for engine covers.
- Crude because the way the BB is attached. I've always suspected that the BBox is at the other side, because that's the only place left. But I didn't expect it to be attached that crudely... I thought it was hidden inside with only an extended pin to turn it on, like that in the 42052. But that open mounting BB does give the feeling of a factory; it's like the huge power building all plants have.
Also, hi-res B-model from direct side view:
http://www.legonewsr...h1-1920x821.jpg
Observation:
- There are 2 large turntables, which means in the A-model, one is used for the rear conveyor belt and one for the superstructure.
- The XL motor is placed really low, just some studs above the tracks.
- The filter must be very, very compact, because the conveyor that bring bricks from the pit to the far left belt is not very far below the pit.
- The bricks don't fall through the upper turntable in the far right belt.
But all in all, hats off to Markus for both the witchcraft filtering function and the appearance. The B-model really looks like and most importantly FEELS like a factory!
Edited by nguyengiangoc
  • Replies 1.3k
The more I look at this model, the more I like it. This one is going to keep me busy for quite some time with both the A and B model. Wow! Looking forward to reviews.
Am I the only one that thinks that this looks like LEGO's entry into GBC?
Andy D
Edited by Andy D
The instruction manual is going to be like a book to me when I was a child. So difficult to keep from reading the last page... I am NOT going to take the instructions and look at how it does the sorting, until I am there with the build.
I'm not fond of sets that are too big, since my place is really small, and too mechanical, because I rarely play with the models. It was a real concern for me about where to put this BWE if I have one, and while it looks cool, the functions don't impress me much. For me the mechanism in the A model really boils down to arranging gears and routing axles. :sceptic:
But after I saw that other side of the B model I know for sure I have got to buy this! I'm a big sucker for realistic details, so I really want this factory, with the filtering witchcraft.
On an irrelevant note, it's the same story for 42009 for me. What really made me buy it was the reach stacker, and its various details (walkways, handles) delight me a lot. I kept 42009 in the B-model form most of the time.
I like some of the regular Lego creeping in here
As someone who is wrestling with the idea of flogging a CREATOR collection to buy more Technic crack, I am already grumpy about this. I need to keep a separate tub just for all the System stuff wot adorns Technic models when they're unbuilt. Looking at that tub already makes me regret what I might do.
Of course I WILL be getting it anyway, once Amazon knocks £40-50 off the RRP.
It is not unusual to find some regular Lego in Technic sets though. Some sets have more of it than others, but still.
Like the Porsche. It uses system parts for the grille, lights, and dashboard.
Yeah, I'm aware of all such as "the entire grille on 8109 is brick-built" and similar things. I heard the problem was much worse 20 years ago, when system bricks even had HOLES through them.
Wow... soms statistics:
- book 552 pages
- 144 gears including gearracks (15) and turntables (4)
- 724 regular black pins
- BWE 669 steps
- numbered bags 1-8
Edited by merman
- book 552 pages
- BWE 669 steps
- numbered bags 1-8
Where are they from?
The B-model is awesome, it's the first time I really like the B-model equally (or more :blush: ) as the A-model. Well done designers
Andy D
It's looking to be a good parts set for gears, track threads, panels and black 2L pins too. :laugh: Great useful parts for MOCing GBC modules.
I think you can use the BWE for a GBC. It would be interesting to see how it fares running all day non-stop at an event with other GBC modules. You would have to build some sort of GBC standards compliant input module to feed the balls to the A model to scoop up. If you have two sets, you can have the A model output into the B model who then feeds the balls on to another GBC module. If you want to make it interesting, you can make B model separate balls from other types of LEGO pieces that the A model had scooped up.
My question is if it has a booklet for the B-model? I don't want to sit in front of my computer for 2 days.
I'm afraid there isn't an extra book.... I love building, but the computer spoils my building fun a lot too. On the other hand, i understand the environment part.
However, this set is mainly aimed at adults, so why not go back to the old school instructions? 10 steps on one page. It's more challenging, it saves paper and we have printed instructions for the B model again. Please Lego!
If you have a tablet I would recommend that. I found that better than sitting at my already cramped computer desk :tongue:
4 turntables, 1 to make rotating the entire structure, 1 for rear conveyor .. then the other 2 (maybe small turntables) have to used for connect ther main beam to the rest of structure
with gearracks do you intend the new yellow pieces? I count only 14 of them..
Edited by Alegomind
I don't quite understand... Where would the other 2 turntables be in the A-model? Can you explain in more details?
My fault for my terrible english, the main beam ( that with buckets, battery box, gearbox ecc ) is supported by two large linear actuator but is pivoted to the structure through the vertical horseshoe structure, I think that the two turntables are used for this connection. I hope this image is helpful:
https://imageshack.com/i/pm7RLNIkj
Edited by Alegomind
I get it now! I used to think the connections at those 2 points are just pins and holes..
I thought too.. but the beam is quite heavy then I think that if there are other two turntables they are used for .. of course I may wrong
