Siegfried Meyer Posted July 20, 2016 Posted July 20, 2016 Thank you very much for the LDD-file, I took the liberty of hiding the structure and highlighting the functions in different colours. I really like the clever mechanisms in this set: One thing confuses me though, the drive to the PTO's (in red) appears to be liked to the M-motor with two sets of gears, but each is geared in a different ratio (see image below). Although there is a clutch gear, this seems to be a stange construction or am I missing something? The cross axle joiner and the 4l axle from the motor are not connected
Cumulonimbus Posted July 20, 2016 Posted July 20, 2016 (edited) The cross axle joiner and the 4l axle from the motor are not connected Ah thanks, that makes sense. So this is an updated image: Edited July 20, 2016 by Cumulonimbus
BrickWild Posted July 21, 2016 Posted July 21, 2016 Done with the LDD file if anyone is interested model is without attachments here I see that you haven't put in the small linear actuators on the front & back!
Siegfried Meyer Posted July 21, 2016 Posted July 21, 2016 I see that you haven't put in the small linear actuators on the front & back! Yes I can't get them to align As the are fully extended and when I try this trick that is posted (Somewhere in the LDD FORUM) it crashes my PC.... Maybe someone with more LDD experience should try it, Me and my novice attempts have only failed
Siegfried Meyer Posted July 21, 2016 Posted July 21, 2016 (edited) Then adjust the attachments accordingly. With the front build as a sample, I found that the LA does not extend fully when at max height, as the beams reach the max turning radius and the LA starts to "click" Apologies for the poor pic Will rebuilt it and try Okay It's added to the Model, let me know if you want the updated LDD file Edited July 21, 2016 by Siegfried Meyer
Gnac Posted July 21, 2016 Posted July 21, 2016 (edited) Maybe someone with more LDD experience should try it, Me and my novice attempts have only failed GNAC HAS ARRIVED! These can be slotted in where they need to be after removing the existing axles / joiners / gears because I had to change the angle. Also: the ram doesn't rotate with the rest of the actuator now for some reason. I didn't edit the <RigidSystem> data, so that's probably why. Let me know if these need to be a different length, and I'll have a proper look at them. EDIT: balls, didn't see the edit. Edited July 21, 2016 by Gnac
Siegfried Meyer Posted July 21, 2016 Posted July 21, 2016 Thanks Gnac Lenght required is 8l, i managed to fit the LA
JunkstyleGio Posted July 22, 2016 Posted July 22, 2016 Nice model so far.. Even without the big wheels..
Siegfried Meyer Posted July 22, 2016 Posted July 22, 2016 Nice model so far.. Even without the big wheels.. Very nice render how did you manage to fit the flex axle?, I just can't get them to snap or are you using LDRAW
vliet Posted July 22, 2016 Posted July 22, 2016 If everything in the mail goes well, I will receive my 42054 next saturday (the 30th) have to be impatient for another week
M_longer Posted July 22, 2016 Posted July 22, 2016 If everything in the mail goes well, I will receive my 42054 next saturday (the 30th) have to be impatient for another week I have mine already and I will start buidling it today :)
dimaks13 Posted July 22, 2016 Posted July 22, 2016 (edited) I have mine already and I will start buidling it today :) https://c8.staticflickr.com/9/8724/27841617663_b1c8903dbc_c.jpg[/im] When you got it? Edited July 22, 2016 by dimaks13
M_longer Posted July 22, 2016 Posted July 22, 2016 When you got it? Yesterday. And I am going to write reviews for two polish LUGs.
dimaks13 Posted July 22, 2016 Posted July 22, 2016 (edited) Yesterday. And I am going to write reviews for two polish LUGs. Oh. I was able to get it earlier than you... Edited July 22, 2016 by dimaks13
HallBricks Posted July 22, 2016 Posted July 22, 2016 I have mine already and I will start buidling it today :) Where did you get it from?
M_longer Posted July 22, 2016 Posted July 22, 2016 Where did you get it from? Stationary store. They had few of them.
HallBricks Posted July 22, 2016 Posted July 22, 2016 Stationary store. They had few of them. Okay, I will check some local stores here in Sweden as well.
Husky Posted July 22, 2016 Posted July 22, 2016 I got it today. Hopefully I can build it tomorrow :) Thank you Sariel for the great review, it helped in my decision.
Ngoc Nguyen Posted July 23, 2016 Posted July 23, 2016 Anybody wanna guess what function does the silage plow have? I think the motorized functions are: changing the angle of the side blades, and changing the angle of the whole plow.
Brick-Nick Posted July 23, 2016 Posted July 23, 2016 Anybody wanna guess what function does the silage plow have? I think the motorized functions are: changing the angle of the side blades, and changing the angle of the whole plow. From my understanding there is no PF on the silage plow
M_longer Posted July 23, 2016 Posted July 23, 2016 From my understanding there is no PF on the silage plow Claas has motorized PTO in front and rear (which is weird, because real Xerion has it only on the back).
Emmi Posted July 23, 2016 Posted July 23, 2016 I think Claas looks best without any attachment ... I think I use the parts for the crane arm for something else. And first thing I try to mod is manual cab-turning.
dimaks13 Posted July 23, 2016 Posted July 23, 2016 I'll get mine tomorrow. Although the set was available since 18th, I wasn't buying it because I was waiting for discount. And in result discount is 8%.
