Jan Beyer (TLG community manager for europe) started building it. :)
Looks like those hubs are pretty offset! Edited by davebarrett
  • Replies 2.7k
Posted Images
Have you notices that the wheels do not come out of the archers much? It can be seen from the picture often posted here. Another question, have you seen that there is a kind of yellow axle going into the front of the car? Then it is connected to CV join and goes somewhere into the frame ... ?
Isn't it strange that the rims come in a nylon bag, while in the designer video they come in a separate container right upon the top of the box?
Close to perfect. Might be wishful thinking though.
I really hope the front wheels have a nice turning angle and pivot point rather than some compromise to fit them in the wheel arches...
Edited by LegoCube
This is most likely pre-production run. I'm sure that final box will be as on video.
Any more pics yet?
Not yet. I would not expect them before weekend, since Jan is very busy guy and also not a Technic builder, so it will take a bit more time.
I am planning on using these new rims on my next supercar, ( I'll start a WIP topic later this week) but to my dismay it doesn't look like an axle can be mounted in the center...
Which is a shame, since it will render my working disc brakes solution useless :(
I had this same question a couple pages back. I still have no indication of a center axle hole. There are not many wheels without it. I'd like to be hopeful.
Busy??????
I would volunteer to help him here! :laugh::excited:
Where is he located?
Edited by tripletschiee
He, Sariel just posted on his Facebook page the incoming review on the 1st of June :) :)
Edited by AOW
Any more pics yet?
Please don't quote images? And more images will most certainly be posted when available. No need to ask.
Has this been posted before?
It appears to NOT have a center hole.
I'm not 100% sure, but the pivot point looks well positioned here in the designer video, 3m 40s point here:
Jim, thats rear suspension :laugh: About the lack of wheels's axlehole... Personally I dont miss it, hardly anyone uses normal axles at such large scales due to the flex and weak attachment point.
:wall:
Explains the lever in the right bottom. I wasn't very sharp. I saw the calipers and I immediately linked them to the front wheels. Obviously the rear wheels have them as well.
There's definitely front wheel suspension too - I have seen the shock absorbers on the front too, I'm 100% sure!
Yes, there is. Don't panic :wink:
Front suspension is identical to the one in 24 hr race car.
Yes. Just a little wider. I never thought that I would see Lego use a series of bevel gears to route the steering wheel to the front steering in one of there cars. Then again, they rarely ever use a functional steering wheel. :grin:
The rear suspension of the 42039 uses a single spring:
Any idea why the Porsche uses a double spring? That's not something which is based on the real car, right? Is it to make the rear a bit stiffer?
Any idea why the Porsche uses a double spring? That's not something which is based on the real car, right? Is it to make the rear a bit stiffer because there's more clearance?
Simple answer.... Weight! 3000 parts is like 3 kilograms with more than half of them in the rear.
Sounds logical. The 42039 was pretty big, but this model is massive.
Sounds like you have it standing in front of you ... mouth opened amazed on how big it is :grin:
