Bering Posted June 28, 2016 Posted June 28, 2016 Good news Jim. No particular questions here, just curious about your review. Quote
Ngoc Nguyen Posted June 28, 2016 Posted June 28, 2016 (edited) Oh thanks Jim for the offer! I've always wondered: - How many push does it take for the crane arm to raise. - How long can the crane arm stays erected after the hand pump has been pushed. I mean, there's no air tank to maintain the internal pressure, so at some point the crane arm will fall. - Does the set come with extra part for the B-model-only stickers? The Volvo loader set has 2 stickers for the 5x11 black panel in both models, but only provides one 5x11 black panel. So if I want to use the B-model sticker I'll have to peel off the A-model one on the panel, which I don't want to. So I wanna see if TLG does something about that this time. Not related to this post, but are you going to review the BWE also, or is it gonna be someone else? Edited June 28, 2016 by nguyengiangoc Quote
M4X1994 Posted June 28, 2016 Posted June 28, 2016 It might be interesting to include some kind of comparison between this new pump and the older pumps from the older pneumatic system. I am curious to see what improvements they made to this 'Pneumatic System V2' pump. Looking forward to your review! Quote
miguev Posted June 28, 2016 Posted June 28, 2016 Also, can you motorize this pump? Like in the walking castle that made it to the front page some time ago (can't find it now). Quote
lcvisser Posted June 29, 2016 Posted June 29, 2016 I'm curious about the size. The clams are the same as on the Arocs, but the I have the impression that this excavator is in a bigger scale. A comparison of the two would be nice, if possible. Quote
schraubedrin Posted June 29, 2016 Posted June 29, 2016 Concerning Playability: Does it stand "sturdy" enough to use the valves? As it's lighter than the Arocs i fear to move the model when making the small movements needed to get small enough movements. And while some movements can be controlled by pumping, the lowering of the arm is always critical. Quote
allanp Posted June 29, 2016 Posted June 29, 2016 (edited) Any way of testing the max pressure of the new pump? Most of my pumps will exceed the limit of my lego pressure gauge. Edited June 29, 2016 by allanp Quote
dr_spock Posted June 29, 2016 Posted June 29, 2016 Any way of testing the max pressure of the new pump? Most of my pumps will exceed the limit of my lego pressure gauge. You could attempt to connect it to a pressure gauge that has higher readings. You may have to hook up an adapter that goes from small LEGO pneumatic tubing to the connection type your gauge uses. Quote
allanp Posted June 29, 2016 Posted June 29, 2016 You could attempt to connect it to a pressure gauge that has higher readings. You may have to hook up an adapter that goes from small LEGO pneumatic tubing to the connection type your gauge uses. Right but not having the new pump myself I want Jim to do it! Quote
roppie11 Posted June 29, 2016 Posted June 29, 2016 (edited) wow i did not know that the cabin can lift that high. This is the technic version This is the real version. (- edit: changed image after jim's post) Edited June 30, 2016 by roppie11 Quote
andrewganschow Posted June 29, 2016 Posted June 29, 2016 Hmm, I wonder if this set contains a new hand pump, and a 5 or 6L pump, both connected to the valves Via a T piece, so you can hand pump it, or motorize the small pump, I see room in the superstructure for it, so it might be possible. Quote
Jim Posted June 29, 2016 Author Posted June 29, 2016 This is the real version. The That images is way too big. Isn't CAT a different brand than Volvo? Quote
GoldVillage Posted June 29, 2016 Posted June 29, 2016 wow i did not know that the cabin can lift that high. It can, kinda https://pbs.twimg.com/media/CFifheDWEAET7j4.jpg:large Quote
Beard Posted June 29, 2016 Posted June 29, 2016 Also, can you motorize this pump? Like in the walking castle that made it to the front page some time ago (can't find it now). In the box art it seems that there are instructions for motorizing the arm. Other that motorizing the pump, I don't know how they do it. On the other hand, it does not look like they are motorizing the pump. Quote
Ngoc Nguyen Posted June 29, 2016 Posted June 29, 2016 (edited) Isn't that obvious? There are 2 pumps, a manual one sticking out, and a small one intended for motor in the back. You can see more details about the manual pump in this pic: http://images.bricks.../42053_alt3.jpg I really love the B-model, because it has a lot of realistic details and closely resemble the real L30G. However, the stickers on the panels in B-models are different from those on ones in A-model. That means I'll have peel off the A-model ones to use the B-model ones, which I really don't like. And I just discover another shortcoming of the B-model. As you can see in the picture, the front section are connected to the rear ones only through 2 liftarms on the top of the turntable. This connection will be very flimsy. Edited June 29, 2016 by nguyengiangoc Quote
Beard Posted June 29, 2016 Posted June 29, 2016 Isn't that obvious? There are 2 pumps, a manual one sticking out, and a small one intended for motor in the back. Having two different pumps in a set seems possible, but not obvious. At least not to me. Quote
M_longer Posted June 30, 2016 Posted June 30, 2016 Having two different pumps in a set seems possible, but not obvious. At least not to me. 8049 had two pumps and was ready for motorisation with 8293. Quote
Beard Posted July 1, 2016 Posted July 1, 2016 8049 had two pumps and was ready for motorisation with 8293. Ok, I didn't know that. Maybe that's it then. All the better, because there's value in those pumps. Quote
BrickWild Posted July 1, 2016 Posted July 1, 2016 In the box art it seems that there are instructions for motorizing the arm. Other that motorizing the pump, I don't know how they do it. On the other hand, it does not look like they are motorizing the pump. Perhaps it's likely to include an optional compressor pump. Quote
dimaks13 Posted July 7, 2016 Posted July 7, 2016 Bigger old images and some new: http://i2.rozetka.ua/goods/1656938/lego_42053_images_1656938350.jpg http://i1.rozetka.ua/goods/1657044/lego_42053_images_1657044869.jpg http://i2.rozetka.ua/goods/1657044/lego_42053_images_1657044960.jpg http://i1.rozetka.ua/goods/1657045/lego_42053_images_1657045051.jpg http://i2.rozetka.ua/goods/1657045/lego_42053_images_1657045142.jpg http://i1.rozetka.ua/goods/1657045/lego_42053_images_1657045233.jpg http://i2.rozetka.ua/goods/1657045/lego_42053_images_1657045324.jpg http://i2.rozetka.ua/goods/1657045/lego_42053_images_1657045415.jpg http://i1.rozetka.ua/goods/1657045/lego_42053_images_1657045506.jpg http://i1.rozetka.ua/goods/1657045/lego_42053_images_1657045597.jpg http://i1.rozetka.ua/goods/1656938/lego_42053_images_1656938441.jpg http://i1.rozetka.ua/goods/1656938/lego_42053_images_1656938532.jpg Quote
Victor Imaginator Posted July 7, 2016 Posted July 7, 2016 Dimaks13, thanks - it's really larger and detailed) As i look at these photos - PF upgrade may be just motorised first boom section with some levers and gears, leaving all pneumatics untouched. Quote
GoldVillage Posted July 7, 2016 Posted July 7, 2016 Dimaks13, thanks - it's really larger and detailed) As i look at these photos - PF upgrade may be just motorised first boom section with some levers and gears, leaving all pneumatics untouched. That doesnt make any sense at all so that photo doeasnt mean anything, and its the same as the other one above (next to the 347 degree pic) Quote
Victor Imaginator Posted July 7, 2016 Posted July 7, 2016 That doesnt make any sense at all so that photo doeasnt mean anything, and its the same as the other one above (next to the 347 degree pic) They are larger, and that opinion just came to my mind) Quote
merman Posted July 9, 2016 Posted July 9, 2016 (edited) Very lovely set. Edited July 9, 2016 by merman Quote
