NickGratian Posted February 14, 2016 Posted February 14, 2016 I need suggestion with my car. I have images below of what I have so far. A few questions. What springs should I use. Hard or soft? What wheels or tires? And I need ideas on how to complete it. So far my axle has working steering and a driveshaft connected. I don't know what to do next as I am a new technic builder. If any more information or pictures are needed please tell me :) Images: http://imgur.com/a/QbhXw Quote
agrof Posted February 14, 2016 Posted February 14, 2016 Welcome here! It is hard to tell, what spring, what wheels. What will it be? A truck, a car, a hedgehog? I suggest You to start to build it in LDD as well, there You will see the proportions = find the right wheel size. (if You don't have physical parts on hand) During the build You will add a lot weight with body and PF elements, the strength of the springs must be tested, it is that easy. You can play with the spring position too, to adjust the strength a bit. Good luck! Quote
nicjasno Posted February 14, 2016 Posted February 14, 2016 Your steering links... they need to be much less angled than they are. Preferably paralel to the woishbones. Quote
