I decided to create a new topic for my WIPs and failed MOCs (or bad/low quality MOCs).
So I´m going to post my WIPs here and maybe create a new topic when the model is finished (is this a good idea?).
This is the first one:
24387324964_540f890658_c.jpgLego Mini/Micro rock crawler WIP by Pego's Legos, on Flickr
It is a front axle for a small rock crawler.
It has drive, steering and leaf spring suspension.
24991592766_70a673a6f4_c.jpgLego Mini/Micro rock crawler WIP by Pego's Legos, on Flickr
I´m waiting for a minizip cable and batteries to arrive, which will make it easier to design and a lot more capable.
24650298659_c019233823_c.jpgLego Mini/Micro rock crawler WIP by Pego's Legos, on Flickr
25017921615_3fd0aec7d3_c.jpgLego Mini/Micro rock crawler WIP by Pego's Legos, on Flickr
  • 1 year later...
Ok, let's put this thread to some use.
Here's my new WIP, a micro-sized (is it micro or mini?) 4x4:
34957000380_03657c3cd8.jpgWhat body should I build? by Pego's Legos, on Flickr
34957015640_5ba1c3e0ce.jpgWhat body should I build? by Pego's Legos, on Flickr
35214788911_44dc37d858.jpgWhat body should I build? by Pego's Legos, on Flickr
34500902824_bce3d32907.jpgWhat body should I build? by Pego's Legos, on Flickr
The steering is very special to make it fit under the L motor, a servo to a linkage system to the axle. It is a little sloppy, but very usable. What is not usable are the tires. They have of the worst rubber, and are useless offroad. I already found a solution, model team tires as rims and some old tires on top, with much better rubber and grooves.
The question then is what body should I build?
I want something fairly simple, light and small, so Suzuki Jimny and Samurai came to mind. I don't know if I want to build a fourth one of those though, so something else would be nice.
  • 17 stud wheelbase
  • 13 studs wide body, 15 at tires
  • FJ40 doesn't work, as its body tapers inwards
What about Lada Niva? You don't see this model built very often.
I agree, Niva would be great!
YES!
Lada Niva it is!
I had a really hard time finding anything short enough, but the Niva is just perfect in terms of dimensions. :thumbup:
