Traveller's Guide to Andromeda
Planets
A planets
B planets
C planets
D planets
E planets
F planets
G planets
H planets
I planets
Aliens
Alien alliances and other advanced aliens.
Submissions
If you would like to submit something to the Traveller's Guide or make an edit, please do so in the discussion topic using one of the templates below:
Creature (link to the first build)
Description: (include links to additional builds here)
Threat level: (or link here if they demonstrate the threat level)
Space-faring alien or Alien organisation
First discovered by Player on x00 Planet name (link to the first build)
Known sectors: x01, x02, x03 (links to builds on other planets)
Description: (can include links to additional builds here)
Allegiance: (link here if they demonstrate their allegiance to a corporation)
Planet description
If you'd like to add something to the planet description, please indicate what you'd like added and provide links to at least two builds that provide evidence.
Edited by Big Sal
A Planets
A04 - Mynderis
An incredibly hot planet, constantly erupting and changing. Large awesomnium reserves.
Known lifeforms:
A05 - Yallorn II
The mountainous islands here provide home to many small creatures.
Known lifeforms:
A06 - Guinevere
A small area of incredibly active volcanoes dominates the climate here, otherwise it's mostly desert.
Known lifeforms:
A07 - Lesser Direstan
Large continents with a wide range of terrain, separated by small oceans. Primarily red vegetation.
Known lifeforms:
A08 - Crentium
The jagged, rocky terrain here is evidence of a relatively young planet. Startling coloured flora in some areas. Icy, volcanic poles.
Known lifeforms:
'Giraffes'
Description: Flying, fire-breathing grey creatures. The infants are cute, but summon adults when in danger.
Threat level: High.
Leg-less men
Description: The name is a misnomer, they actually do have legs.
Threat level: Low, but known to be under the influence of dangerous sentient aliens.
Edited by Bob De Quatre
B Planets
B03 - Linopeia III
Diverse weather forces the creation and disappearance of enormous seasonal lakes.
Known lifeforms:
B04 - Barnius
Low lying mountain ranges worn down by wild winds, now covered by vast forests. Pink water has been found in some areas, and fungus is common.
Known lifeforms:
Head hopper
Description: A dangerous green tentacled creature from the sea with a liking for human heads.
Threat level: High.
Reptorslicer
Description: A ferocious mash-up of a parrot and a pterodactyl.
Threat level: High. An apex predator on Barnius.
B05 - Marphacia
An entire planet covered in dense swampland.
Known lifeforms:
B06 - Sorn
While little exists above sea level, the islands here are rich in awesomnium.
Known lifeforms:
B07 - Vollfort
A former lava planet, now cooled to mostly desert broken up with volcanic rock formations.
Known lifeforms:
B08 - Greater Direstan
Known lifeforms:
B09 - Serium
Desert islands, a little over tropical conditions. Awesomnium discovered below water level.
Known lifeforms:
Edited by Big Sal
C Planets
C02 - Hunston
Volcanoes eons ago created jagged mountain islands which life clings to.
Known lifeforms:
C03 - Torresta
A hot and active young planet, constant volcanic eruptions change landscape.
Known lifeforms:
C04 - Aeristus
Medium sized continental grassland around the equator dominates this world.
Known lifeforms:
C06 - Hyreal
A tropical planet, covered in small jungle and forest covered islands.
Known lifeforms:
C09 - Orinshi
Large jungles and swamp areas are broken up by sweeping tundra plains.
Known lifeforms:
C10 - Marden
Known lifeforms:
Edited by Andromedas Gates
D Planets
D02 - Barker's Folly
An unpredictable asteroid belt.
Known lifeforms:
D03 - Terrial Major
A massive, freezing planet. The entire planet is basically a ball of frozen pure water. Vicious local wildlife
Known lifeforms:
Ice worms
Description: Giant worms with sharp teeth and spikes.
Threat level: Medium.
Frost dragon
Description: Large ice-breathing flying creature.
Threat level: High. Known to attack ships.
One-eyed beast
Description: Large spiky one-eyed beast.
Threat level: Medium. Slow, but only momentarily stunned by the MANTIS™ Death Ray Blaster©.
Titanic reptilian creatures
Description: Enormous white dinosaurs.
Threat level: Unknown.
D04 - Terrial Minor
The peace on the surface hides a desert teeming with life
Known lifeforms:
Sand worms
Description: Brightly coloured worms that live below the surface in large numbers.
Threat level: Low.
Flying bugs
Description: Small flying bugs that come out of the ground.
Purple creature
Description: Purple creature.
Jevin
Description: Large fearsome black beast.
Threat level: Medium. Known to be under the influence of dangerous sentient aliens.
Carnivorous Birds
Description: Large birds. The males have red plumage and the females have green plumage.
The plog
Description: A rare and mysterious creature.
Gubbies
Description: Friendly and curious flying creatures.
Threat level: Low.
D08 - Angornal
Several mountainous islands between large continental plains.
Known lifeforms:
D09 - Magrathea
A cold, rocky, almost dead looking planet.
Known lifeforms:
D10 - The Hamilton Belt
A dense asteroid belt, rich in resources.
Known lifeforms:
E Planets
E01 - Donwarr
Forest covered mountain ranges dominate the large continents here. Regions of yellow rocks. The biology is similar to ours but consists mainly of enantiomers (mirrored molecules) and can't be digested by humans.
Known lifeforms:
Giant Hawk
Description: A large hawk-like creature
Threat level: Medium. It's relatively friendly but its size means it could take on a dropship in a fair fight
Giant spider
Description: A large spider-like creature
Threat level: High. Hostile and equipped with sharp fangs and web.
E02 - Jurin II
Chains of islands, big and small link together huge jungle ranges.
Known lifeforms:
E03 - Ertauq
A hot dry planet, covered in scars from underground gas jets. Teeming with small life.
Known lifeforms:
"Ya-te-veo", (vidya zavod) (taxonomy by Vedauwoo)
Description: Semi-sentient Spiky Fern/Palm-like organism with two large eyes, develops a grassy stalk for locomotion. Seems both selfless and fearless, but has a distinct sense of justice. Has a language composed of clicking, cracking and rustling sounds.
Threat level: Low, invite them on your mission, they are very helpful.
E09 - Castral
The forests here hide most of the life on the planet.
Known lifeforms:
E10 - Traig IV
Small mountainous islands separated by large areas of oceans.
Known lifeforms:
E11 - The Fascini Cluster
A tight swirling cluster of awesomnium rich asteroids.
Known lifeforms:
F Planets
F02 - Lesser Drigo
While dominated by volcanic activity, the deserts here hide vast water supplies.
Known lifeforms:
F03 - Forring
A beautiful planet, covered in lush forest and grassy plains.
Known lifeforms:
F04 - Illustria
Planet covered in large mountainous continents separated by large oceans.
Known lifeforms:
F08 - Raduon
Tropical island jungles dominate this planets surface.
Known lifeforms:
F09 - Arium Minor
Covered mostly with mountain ranges. Very little terrain variation.
Known lifeforms:
F10 - Arium Major
A large ocean dominates the equatorial region of Arium Major, with huge continents at the poles.
Known lifeforms:
G Planets
G02 - Freegate
Icy mountains dominate the landscape here. Predatory wildlife dominates the world.
Known lifeforms:
G03 - New California
Seasonal oceans spring up from under otherwise constant desert.
Known lifeforms:
G04 - Fractor V
Medium sized islands covered in dense jungle, linked by smaller island chains covering the whole planet.
Known lifeforms:
G05 - Jen's Star
Large mountain ranges hide vast pure underground water supplies.
Known lifeforms:
G06 - Zimunsk
A majority desert planet with an ocean that constantly shifts around the planet.
Known lifeforms:
G07 - Hennigan II
A fertile planet covered in grassy plains and lush forests.
Known lifeforms:
G08 - Xerillian
A medium sized desert planet, teeming with underground life.
Known lifeforms:
G09 - Greater Drigo
A clay like crust covers this planet, interrupted by random geysers which create large short lived lakes.
Known lifeforms:
G10 - Onix
An unforgiving planet dominated by Lava flows. Very predatorial life.
Known lifeforms:
Oni-Ren
Description: Named by an early Kawashita explorer whose crew was taken hostage and eaten by one of their smaller clans, the Oni-Ren of G10's Onix have developed a reputation throughout the galaxy as a backwards people. A.L.I.E.N. refuses to work with them, since the Zoid are considered a delicacy by the Oni-Ren, and the uncooperative feeling is mutual. They are one-eyed humanoid sentients with a tough hide and high heat tolerance. The Oni-Ren are universally matriarchal, and not egalitarian, with the males of the species unable to hold positions of power, and often serving as foot soldiers during times of war. The largest organized government of the Oni-Ren, the Gongen Empire, dominates almost the entirety of Onix's north pole where some of the most fertile land, and greatest deposits of copper can be found. The empire is characterized by lack of trust for Offworlders, and maintains a policy of isolationism. The Oni-Ren from the empire and those within its range of influence all follow a similar religion featuring a pantheon of celestial figures for whom many copper statues have been erected. Recently a deadly illness has spread to the Gongen Empire, known as "Black-Eye"... the Gongen Empire lacks the technology level to effectively combat the illness and refuses to work with outsiders who may be able to help them.
Threat Level: Medium to High. Depends on what clan or faction one encounters. Many are openly hostile when encountering offworlders. The consumption of sentient species holds no taboo to the Oni-Ren. Even among more "civilized" factions, outsiders are often treated poorly.
Source: Octan's cultural informant, Ba'al-Ba'al Jinks.
H Planets
H03 - Kaalin
A dry planet, covered mostly with Tundra like plains.
Known lifeforms:
H04 - Crofter's Ridge
An unforgiving mountainous area teeming with life.
Known lifeforms:
H05 - Livgorn
A cold, wet planet covered with swamps, marshes and jungle.
Known lifeforms:
H06 - Farmolis
Large flat grassy plains and forests, broken up by numerous small oceans."
Known lifeforms:
H07 - Quantus III
Temperate continents separated by oceans. A mix of forestland and mountains.
Known lifeforms:
H08 - Sinden's Run
An Awesomnium packed asteroid belt with a small navigable channel known as Sinden's Run.
Known lifeforms:
H09 - Wastyria
A cold planet, mostly ocean based with several small mountainous islands.
Known lifeforms:
Aliens
Alien alliances
Merchant Confederacy
First discovered by John Hannibal on G02 Freegate
Known sectors:
Description:
Allegiance: Working with Octan.
A.L.I.E.N. (Andromeda’s Liberated Interracial and Entrepreneurial Nations)
First discovered by Narbilu on B06 Sorn
Known sectors:
Description:
Allegiance: Working with Kawashita.
Other advanced aliens
Ter Tahls
First discovered by Kodan Black on F10 Arium Major
Known sectors: F10
Description: A subterranean species that does their best to avoid contact with humans. A proud warrior culture that is advanced and technologically proficient.
Generally friendly though an advanced warrior culture and perfectly capable of defending themselves.
The Ter Tahls main color is dbg, but they mix in various blues as a tribute to their aquatic lineage. The triple triangle blue piece is symbolic also.
Allegiance:
"Space-ducks"
First discovered by Jedadiah Douglass on E09 Castral
Known sectors: E09
Description:
Allegiance:
Terrestrials
Known sectors: B06
Description:
Allegiance: Head of the ALIEN Alliance.
Rothillian
Known sectors: B06
Description:
Allegiance: Part of the ALIEN Alliance.
Zard
Known sectors: B06
Description:
Tron
First discovered by Narbilu on E10 Traig IV
Known sectors: E10
Description:
Zoid
Known sectors: B06
Description: Known for raiding and enslaving members of other species. Operate mostly on the "east" side of the galaxy.
Allegiance: Part of the ALIEN Alliance. An enemy to the Merchant Confederacy.
Frogans
First discovered by Lady Kianna on B03 Linopeia III
Known sectors: B03
Description: The Frogans are a viscous slave-taking race... that is... if they leave any survivors at all.
Allegiance:
Zotaxians (Insectoids)
First "discovered" by Dr. Danielle Long on F04 Illustria
Known sectors: F04
Description: An ancient race shrouded in mystery charged with protecting even more ancient knowledge.
Allegiance:
Terrians
First discovered by Lady Kianna on D04 Terrial Minor
Known sectors: D04
Description: Peaceful natives of Terrial Minor.
Allegiance:
