Posted February 28, 20168 yr Just recently I upgraded my crawler with 2 xl's. I connected them + servo motor to one V2 receiver. Turns out That two wheelbases spin the wheels different directions. i connected a 2nd receiver to the same BB and put the servo on there. I used both ports on the V2 receiver to make the wheels go the same direction. I am not sure if that is a very good fix. Is there any other way to have the motors spin the same direction? How did you do it? Kind regards - Alex, 12y.o
February 28, 20168 yr Hi Alex Just turn around one of the differenitals in the crawler from left to right.
February 28, 20168 yr Do you have a differential installed on your axles? If yes, one of them is installed incorrectly (just turn it around)
February 29, 20168 yr Author Hi Alex Just turn around one of the differenitals in the crawler from left to right. Thanks!
