March 8, 20168 yr Author Awesome! I wanna see a Millenium Falcon in that hangar! easy task :) but pretty much out of scale.
March 8, 20168 yr Oh man! Yep, definitely too big. The small part of the Falcon in the hangar looks totally dope regardless!
March 13, 20168 yr Actually, the UCS Falcon and Slave 1 are close to being to scale with each other - if you use 34,75m as the official length of the Falcon :)
March 13, 20168 yr Author Actually, the UCS Falcon and Slave 1 are close to being to scale with each other - if you use 34,75m as the official length of the Falcon :) if the are close in scale - didn´t know that the falcon is that much bigger than slave 1.
March 13, 20168 yr The problem is that the 10179 is really oversized for minifig scale. The correct one is the system scaled. But for the Slave I, the UCS version is the most correct in minifig-scale. Sounds weird, but the numbers says that.
March 13, 20168 yr The falcon is 34,75m, Slave 1 is 21,5. Regarding minifig height, they are both approximately minifig scale. The falcon is a few studs too big for them to be in perfect scale, but it is perhaps the model that fit minifig scale the best of the two. Rough estimates puts a falcon minifig at around 1,7m, a slave 1 minifig is close to 2m.
