Blakbird Posted March 20, 2016 Posted March 20, 2016 @Blakbird, do you build in MLCad or any other software? All in MLCAD. There's no such thing as "building in LDRaw". LDCad, which uses LDRaw part library, has part snap feature and is quite easy to use, even for odd angles Unless the parts don't actually fit. Quote
legolijntje Posted March 20, 2016 Posted March 20, 2016 Unless the parts don't actually fit. Still, there's the 'magic' button: O Quote
piterx Posted March 21, 2016 Posted March 21, 2016 outstanding job madoca! it's really amazing, probably your best model ....for now :D Quote
Blakbird Posted March 21, 2016 Posted March 21, 2016 Here are some new views of the model that I made while waiting for the last parts to arrive. Quote
AFOLegofan66 Posted March 22, 2016 Posted March 22, 2016 just finished this fantastic car....does it move on a gymnasium floor...great ride and handling. Thanks Madoca for your best MOC yet!! Quote
BrickMonkeyMOCs Posted March 26, 2016 Posted March 26, 2016 Here are some new views of the model that I made while waiting for the last parts to arrive. Fantastic work. Can you share the LDraw file? Quote
2LegoOrNot2Lego... Posted March 26, 2016 Posted March 26, 2016 This is indeed fantastic work!!! Quote
Blakbird Posted March 30, 2016 Posted March 30, 2016 This was so much fun to build and it is even more fun to drive! Here are some photos to help do it justice. Quote
Kumbbl Posted March 30, 2016 Posted March 30, 2016 One question: could this marvel also be built with two PF IR receivers instead of sbricks? Is this an easy MOD? Quote
Blakbird Posted March 30, 2016 Posted March 30, 2016 One question: could this marvel also be built with two PF IR receivers instead of sbricks? Is this an easy MOD? It could be done. Two of the motors need to run the opposite direction as the other two, so you would have to wire it correctly. Quote
2LegoOrNot2Lego... Posted March 31, 2016 Posted March 31, 2016 Also such a great build, and this pics of yours are outstanding...!!! Quote
Madoca 1977 Posted April 1, 2016 Author Posted April 1, 2016 This was so much fun to build and it is even more fun to drive! Here are some photos to help do it justice. Thanks for sharing beautiful pictures! Seeing your two motorized supercars, I noticed that my ICARUS is shorter than BMW. Main reason is that I made rear overhang minimized. Its length : width is 2:1. More compact, lighter, and having less horsepower (4 L motors). That theory is more like Alfa 4C or Lotus lightweight sports cars rather than McLaren P1. Now I'm very curious how it looks among your supercar collection! Quote
Blakbird Posted April 1, 2016 Posted April 1, 2016 Now I'm very curious how it looks among your supercar collection! Don't worry, you will soon see it! I need to finish my last 2 white cars (lipko simple supercar and pvdb Koenigsegg) and then I will take a picture of all the white cars. Quote
technic_addict Posted April 7, 2016 Posted April 7, 2016 I am in the process of building this beautiful supercar and I am curious why two Sbricks are required. I am currently using two IR V2 receivers on the same channel (with one additional polarity switch) so I would think one Sbrick with four channels should suffice. 2L motors on C1, 2L motors on C2, Servo on C3 and lights on C4. Any thoughts? BTW.....long time lurker Quote
deehtha Posted April 7, 2016 Posted April 7, 2016 One battery box cannot supply the necessary power to 4 l motors. The safety fuse kicks in. Quote
technic_addict Posted April 7, 2016 Posted April 7, 2016 So the battery box limitation was the sole reason? Couldn't two battery boxes be setup in parallel to avoid the problem or is that just a wiring headache? Quote
deehtha Posted April 7, 2016 Posted April 7, 2016 It is just easier to use a second sbrick or IR receiver and battery box. I don't know if two boxes wired in parallel would get around the limitation. Quote
Blakbird Posted April 7, 2016 Posted April 7, 2016 So the battery box limitation was the sole reason? Couldn't two battery boxes be setup in parallel to avoid the problem or is that just a wiring headache? PF connections are designed specifically to prevent you from connecting anything in parallel. You can't stack the battery connectors. Quote
Therion Posted April 8, 2016 Posted April 8, 2016 One battery box cannot supply the necessary power to 4 l motors. The safety fuse kicks in. Are you sure? I'm currently building this, and I have 4 L-motors connected to a single V2 receiver (2 per channel), and the servo to a second receiver and it works fine. Quote
technic_addict Posted April 8, 2016 Posted April 8, 2016 Have you applied a load on the motors? Quote
kandykop Posted April 8, 2016 Posted April 8, 2016 Are you sure? I'm currently building this, and I have 4 L-motors connected to a single V2 receiver (2 per channel), and the servo to a second receiver and it works fine. Did you forget to mention that only one battery box was used? Or you just misread what deehtha's post? Quote
technic_addict Posted April 8, 2016 Posted April 8, 2016 Did you forget to mention that only one battery box was used? Or you just misread what deehtha's post? See below what Therion was responding to. While I am sure the battery box with run four L motors without issue, I am not so sure it will under load. One battery box cannot supply the necessary power to 4 l motors. The safety fuse kicks in. Are you sure? I'm currently building this, and I have 4 L-motors connected to a single V2 receiver (2 per channel), and the servo to a second receiver and it works fine. Quote
Blakbird Posted April 8, 2016 Posted April 8, 2016 In my Icarus, the safety fuses kick in sometimes even using the default setup with two batteries and two S-bricks. This happens when turning at full speed. I don't think it would really be usable with only a single battery. Quote
technic_addict Posted April 9, 2016 Posted April 9, 2016 In my Icarus, the safety fuses kick in sometimes even using the default setup with two batteries and two S-bricks. This happens when turning at full speed. I don't think it would really be usable with only a single battery. I am not noticing the battery cutting out but I am noticing some rubbing of the tires. It seems the DBG 90 degree axle hub is touching the tires when tires are fully turned. Can you confirm if this is happening in your model please? Quote
