July 29, 20168 yr I totally missed this whole thread somehow but plan on building this model to rectify that.
September 7, 20168 yr Just finished this Icarus Supercar and I can say this one is a thing of beauty. The picture cannot do justice how beautiful it is. One of the best supercar if not the best.
September 7, 20168 yr On 9/7/2016 at 6:57 AM, leksivalen said: Just finished this Icarus Supercar and I can say this one is a thing of beauty. The picture cannot do justice how beautiful it is. One of the best supercar if not the best. I don't know what's better, the car or the view from your window.
September 10, 20168 yr to whoever built the model, are you having issues powering the car, i can't even drive 5 feet without it stalling, using x2 Li-po and x2 sbricks and have 2 L motors on each + servo on 1. batteries are fully charged and remote control profile has 2 motors inverted. i don't know what i'm doing wrong here. can anyone help? did anyone modify the Li-po battery to overpass the safety?
September 10, 20168 yr You should check all motors and wires. If one of them has a bad contact, it can stall the entire drivetrain.
September 12, 20168 yr On 9/10/2016 at 8:07 PM, brunojj1 said: You should check all motors and wires. If one of them has a bad contact, it can stall the entire drivetrain. I fixed the problem, i opened both sbricks and cleaned the little 4 little spokes at the bottom and i also changed both wires (i had more laying around), then i connected the 2 motors with the 36 tooth gear to their own sbrick, and the 2 other ones + the servo to the other, i deleted and reinstalled the sbrick app, it might have had a problem because i updated to IOS 10 GM early. Edited September 12, 20168 yr by MLGwookie
September 24, 20168 yr Just finished this build and it is just amazing. All the functions are working fine. Created speed build videos for my entire build process, check them out below! Youtube: Icarus Speed Build Playlist Edited September 24, 20168 yr by xiangyu
October 11, 20168 yr Awesome MOC madoca, can't wait to build this! @Jim Great to see this in the Hall of Fame thread, but the spelling needs to be corrected (ICAUS, and side note... internal links are not working, I guess as a result of the forum upgrade and you probably already know this issue...)
October 11, 20168 yr On 10/11/2016 at 12:38 PM, t12ung said: Awesome MOC madoca, can't wait to build this! @Jim Great to see this in the Hall of Fame thread, but the spelling needs to be corrected (ICAUS, and side note... internal links are not working, I guess as a result of the forum upgrade and you probably already know this issue...) Thanks for the heads up. We will look into it.
April 3, 20177 yr hello, is it possible to have the ldraw file? I want to try different color combinations thank you Cristian
December 3, 20195 yr Sorry for being late to the party! While you were all having fun building this beauty, I was still deep in my dark age. Time to catch up! After finishing the car with 1x BuWizz, I was left with 2 gaps on either side of the car (meant for the lipo batteries). I thought it would be nice to install in these gaps a compressor and door selector, such that those stunning doors can be opened remotely. See the result below: [media] [/media]
July 2, 20204 yr I made 2 Icarus. Somehow the yellow one doesn't go forward straight, i checked the servo gear is centered, but one of the wheel is not super straight when the servo is centered. I'm wondering anyone has the similar problem. I'm at my wits end.
July 5, 20204 yr On 7/2/2020 at 4:55 PM, benxz said: I made 2 Icarus. Somehow the yellow one doesn't go forward straight, i checked the servo gear is centered, but one of the wheel is not super straight when the servo is centered. I'm wondering anyone has the similar problem. I'm at my wits end. Anyway, I'll answering my question here. Today as I tried to modify the transmission drive from CV joint to direct gear drive (rear wheel CV joints keep breaking and I finally ran out of them) the right drifting steering is gone, it goes pretty much straight. I think the different wear and tear between the left and right CV joint has something to do with the problem. Again, great supercar! It's super when using 2s lipo!
July 5, 20204 yr With buwizz (or brickcontroller2) you can program it to add 2 motors right away in the throttle, then a third, then the fourth at or near full gas. In this way you can ease the acceleration a little, and save CV joints. I don't know how it is with s brick, but I guess similar. My only problem after that is driving ability and how bits keep flying off the front end.
July 5, 20204 yr Sbrick has sequence too, will check it out. Some new pics. Edited July 9, 20204 yr by benxz
July 9, 20204 yr [media] <iframe width="560" height="315" src="https://www.youtube.com/embed/pXBAPZdGsGs" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe> [/media] https://www.youtube.com/watch?v=pXBAPZdGsGs Edited July 9, 20204 yr by benxz
May 3, 20231 yr This car is amazing and i wanted to improve on the model so i made a awd version with a 2 speed gearbox. the current build has 2 Buwizz buggy motors and a buwizz 3.0 battery box. i was wondering what you all think of this version of the chassis. its still a work in progress. https://bricksafe.com/pages/Killerfrost/icarus-supercar-2.0
May 3, 20231 yr On 5/3/2023 at 2:00 PM, killerfrost said: Very cool remake, it definitely took a lot of time to fit all of those components in, and I congratulate you for that. I advise you to be careful about melting axles and axle holes in the gearbox. I did a similar set-up and I braced the motors very well (at an angle like your build), but I used 4 buwizz motors. Greasing wil definitely help. Keep it up!
