Posted April 2, 20168 yr Hi, I am trying to use Brickstore to manage my Bricklink inventory in GBP. I am using the Mac version and have the preferences set to use local currency with a conversion rate entered from USD to GBP. Brick stock appears to show the converted currency correctly in Brickstore itself but when I go to upload to Bricklink it actually tries to upload the dollar value as a GBP one. Any help greatly appreciated.
July 1, 20168 yr I'm having the exact same problem but with AUD. did you end up finding a solution to this problem? as it would help me out greatly too.
July 5, 20168 yr I also encountered this problem and I don't think there's an easy solution. If you look at the .bsx or exported .xml file in a text editor, you'll see the values are always stored in USD. When I was doing this in old Bricklink, I ended up multiplying all my Brickstock prices by the currency conversion rate and then importing them into Bricklink in my local currency. It was a pretty inconvenient process and I ended up just using USD for most things. These days it's a little bit easier since with new BL, you can bulk increase or decrease wanted prices by a percentage. So now I'd keep everything in Brickstock as-is, import my wanted list and then multiply all the imported prices by a percentage to get the right values.
