DrJB Posted May 13, 2016 Posted May 13, 2016 I found the LDD file I was working on a while back. It's not final, and not tested. Also, the bucket part is not available in LDD so I used close substitutes. I have yet to build this and try it ... as I already have all the parts. http://www.brickshelf.com/gallery/djamil/GBC/bucket_wheel_excavator3.lxf Quote
doug72 Posted December 20, 2016 Author Posted December 20, 2016 (edited) The previous built up bucket wheel made from connectors and axles was prone to flexing and connectors coming apart so an improved version required. Currently working on a new improved bucket wheel GBC lift using four BWE gear quadrants (6151167) for a single ring gear, which makes for a sturdier structure with smooth rotation. The bucket wheel is driven by an M motor with 24:1 reduction to a 20T double bevel drive driving the gear ring at 7:1 giving an overall 168:1 reduction. The 8 buckets for carrying the balls use LEGO Dark Stone Gray Beam 3 with Large Ball Socket (92911) The ball release trip mechanism is the same as previous BW but constructed using studless technic parts with a threaded lego 4L axle to allow adjustment. Almost perfected the ball transfer onto and off the bucket wheel. Will post images / video later. Edited December 20, 2016 by Doug72 Added content Quote
doug72 Posted December 21, 2016 Author Posted December 21, 2016 (edited) Photos of new improved bucket wheel GBC lift using new gear rack quadrants:- Oblique view:IMG_4225 by Doug Ridgway, on Flickr Loading side view: With wheel rotating clockwise the balls enter the buckets at 7:00 o’clock. Wheel rotates and balls falls out of bucket at 1:00 o’clock and rolls down along rim to sit on back of preceding bucket. At 4 o’clock balls drop from wheel onto discharge track.IMG_4223 by Doug Ridgway, on Flickr Motor side view: showing motor/gearbox with battery & PF switch interlocked to prevent wrong way rotation.IMG_4224 by Doug Ridgway, on Flickr Edited December 21, 2016 by Doug72 Quote
doug72 Posted January 8, 2017 Author Posted January 8, 2017 (edited) The Mk 2 bucket wheel lift has been linked up to my "Drag & Tilt" module on one base plate with a new conveyor linking the two modules. IMG_4236 by Doug Ridgway, on Flickr I now have 10 pce White Visors from the Mk 1 bucket wheel looking for a new build. http://www.brickowl.com/catalog/lego-visor-2007-57702 I have thoughts on using these for a vertical or incline GBC stepper module. Struggling to find way to achieve this. Has anyone ideas on how this could be achieved ? Edited January 8, 2017 by Doug72 add image Quote
doug72 Posted February 27, 2017 Author Posted February 27, 2017 (edited) On 08/01/2017 at 10:15 AM, Doug72 said: I now have 10 pce White Visors from the Mk 1 bucket wheel looking for a new build. After completing my Bucket Wheel GBC Lift I had 10 pcd White Visors spare waiting for a new use ! Finally used two visors for a module based on the Nxtstep101 module Dual arm lift GBC. Adapted to use parts I had available. The loading gates are my own standard design operated by trips actuated by the bucket. Driven by M motor at 24:1 reduction with arms 180 deg apart. PS think I have been bitten by the GBC bug ! Edited February 27, 2017 by Doug72 Quote
ColletArrow Posted February 27, 2017 Posted February 27, 2017 Simple and clever! I like it! Have you tested out any of these GBC modules over a longer stretch of time, as a module would experience at an event? I don't see why this particular module should break down, but you can never tell until it's been 'run in'. (And it seems you have posted the same picture twice ) Quote
doug72 Posted February 27, 2017 Author Posted February 27, 2017 21 minutes ago, ColletArrow said: Simple and clever! I like it! Have you tested out any of these GBC modules over a longer stretch of time, as a module would experience at an event? I don't see why this particular module should break down, but you can never tell until it's been 'run in'. (And it seems you have posted the same picture twice ) Not tested the dual arm GBC for continuous running yet as need to set up a return ball run. It took a lot of trial & error to get the levers & cranks working smoothly. Some of my other GBC modules have been run for a long time and functioning OK still. I don't anticipate going to an event and not sure is any are held in the UK. Intention is to link them all up on a 6 ft x 3 ft board.Thanks for advising I had duplicated the image - now corrected in original post above. At the moment trying to get a GBC bucket chain lift working which uses a Large Lego chain and the white visors as the ball holder. First attempt failed but 2nd one looking better. Will post once working OK. Quote
