Posted April 27, 20168 yr I am trying to build a model with some Sloping 45° Corners, Standard and Inverted. http://www.mecabrick...els/8mkjAgDpaZG The 4x Different Shaded Green Sloped Corners are not in Lego's Arsenal. The Corner Assembly on the Left is what I am trying to achieve. (it is lots of illegal parts crammed together to make the correct shape) The one in the Middle is the best I could come up with to mimic it. And the one on the Right was just playing around with plates to see what I could come up with. Edited April 27, 20168 yr by Lttlcheeze
April 27, 20168 yr Author I'm more of a visual guy... do you have an example?? I did SNOT some 1x2 Slopes for the Inverted Areas, but there is still alot of air space around them.
April 27, 20168 yr check out this guys video at around 10:08 the pier area, the building has a similar roof to what you are looking for Edited April 27, 20168 yr by Modelmaker
April 27, 20168 yr Author check out this guys video at around 10:08 the pier area, the building has a similar roof to what you are looking for I could do something with that for the inverted slopes, combining both of the inverted into one area, and filling it with some snot fitted angled plates. I am trying to get it stud-less in that area, but i'll see what I can do. Thanks for the tip.
