Didumos69 Posted August 31, 2016 Author Posted August 31, 2016 (edited) Beautiful airplane, the tail is very well done. Cute airplane the 90° indexer is great - very useful, thanks Thank you guys! Love your small models and great use of all parts. Thanks! And guess what, part III of the trilogy will be a... boat. I do not have the slightest inspiration yet, so I miight just have to dive into your excellent floating MOCs first . I did some minor changes to both the Porsche and the Seaplane to get a slightly better resemblance: LXF-file of the Porsche here. LXF-file of the Seaplane here. Edited August 31, 2016 by Didumos69 Quote
Didumos69 Posted October 3, 2016 Author Posted October 3, 2016 (edited) A few months ago I posted about a compact knob gear axles with drive and Ackermann steering. A major drawback of these solid axles is the fact that the wheel hubs are mounted to the vertical drive axles. This causes quite some friction. To fix this I replaced each of the the vertical 5.5L axles with stop by two half pins to mount the wheel hubs and a 2L axle for the knob gear. This way the knob gear can rotate freely. I tested this and the drive setup operates way more smooth while the whole setup remains to be equally robust. Before: After: LXF-file here. Edited October 3, 2016 by Didumos69 Quote
Imanol BB Posted October 3, 2016 Posted October 3, 2016 That is really amazing didumos, i also made a transmission based in your axle, it uses knob gears too to get very compact portal hubs with the pivot point as near as possible to the wheels, it is slightly bigger and it also uses an axle as the pivot point and drive, it has just a little bit of friction, but i will try your idea with tha pins, because it looks very cool; this is the transmission i made by the way: http://www.eurobricks.com/forum/index.php?/forums/topic/57543-8110-unimog-mods-and-improvements/&do=findComment&comment=2664881 Quote
Didumos69 Posted October 3, 2016 Author Posted October 3, 2016 6 hours ago, ImanolBB said: That is really amazing didumos, i also made a transmission based in your axle, it uses knob gears too to get very compact portal hubs with the pivot point as near as possible to the wheels, it is slightly bigger and it also uses an axle as the pivot point and drive, it has just a little bit of friction, but i will try your idea with tha pins, because it looks very cool; this is the transmission i made by the way: http://www.eurobricks.com/forum/index.php?/forums/topic/57543-8110-unimog-mods-and-improvements/&do=findComment&comment=2664881 That's a serious design! Didn't see it before, As of now I will be following the Unimog mods thread too. Another way to gear this setup down would be to use thin bevel gears instead of knob gears for the portal hubs. If the bracing is okay this should work just fine. I tested this and couldn't get the bevel gears to slip in my setup. LXF-file here. Quote
Imanol BB Posted October 3, 2016 Posted October 3, 2016 Yeah, that is exactly what i tried, but the problem came with the lower gear, because this axle uses planetary rims (first built by Efferman), the driving axle is not completely fixed to the hub, it lies above some 8T gears, and because of that it has a little bit of backlash, which provoques that if i use bevel gears, they will slip, which was very sad because the version with normal gears was the perfect dream for me, but it only works with knob wheels (at least so far), i also think that your original design is clean and clever too, i really like it a lot. Quote
Didumos69 Posted November 28, 2016 Author Posted November 28, 2016 (edited) I thought these seats are worth sharing here too. For my FST NML moc I got the idea of redoing the adjustable seats of the Steppenwolf. I'm not sure about the final color scheme yet, so for now I made them bluish gray. LXF-file of the seats can be found here. Edited November 28, 2016 by Didumos69 Quote
Imanol BB Posted November 28, 2016 Posted November 28, 2016 I think they look and work perfectly, i am thinking to make similar seats in some of my future models because i think they add a lot of realism to the models. Quote
mocbuild101 Posted May 31, 2017 Posted May 31, 2017 (edited) Great ideas! I really like the 90 degree stepper and the mini seaplane! Also, I think I might make a topic like this... It's also a great idea . Edited June 1, 2017 by mocbuild101 Quote
1gor Posted May 31, 2017 Posted May 31, 2017 @Didumos69 despite my interest mostly (99%) in machinery, when I see your seats and manual mixer, there is only one thing I can say: Small is beautifull Quote
Didumos69 Posted June 1, 2017 Author Posted June 1, 2017 21 hours ago, mocbuild101 said: Great ideas! I really like the 90 degree stepper and the mini seaplane! Also, I think I might make a topic like this... It's also a great idea . 11 hours ago, I_Igor said: @Didumos69 despite my interest mostly (99%) in machinery, when I see your seats and manual mixer, there is only one thing I can say: Small is beautifull Thanks guys! I alo use the OP as an index to everything I posted about. I should update it. Quote
Didumos69 Posted June 9, 2017 Author Posted June 9, 2017 (edited) I built my manual mixer and made instructions available on rebrickable: Edited June 9, 2017 by Didumos69 Quote
lcvisser Posted June 9, 2017 Posted June 9, 2017 Looks like those 3x5 frames won't be used again anymore... How can you undo step 2 of your instructions? Quote
Aventador2004 Posted June 9, 2017 Posted June 9, 2017 Are you absolutely sure to don't work for TLG? Nice blender. Quote
TheHypaaa Posted June 9, 2017 Posted June 9, 2017 34 minutes ago, Ludo Visser said: Looks like those 3x5 frames won't be used again anymore... How can you undo step 2 of your instructions? With a pair of pliers I imagine. It works really well and does not damage any components. Quote
Didumos69 Posted June 9, 2017 Author Posted June 9, 2017 (edited) 1 hour ago, Ludo Visser said: Looks like those 3x5 frames won't be used again anymore... How can you undo step 2 of your instructions? 33 minutes ago, TheHypaaa said: With a pair of pliers I imagine. It works really well and does not damage any components. I managed to pull out the 3L axles with knob quite easily to make the tear-down sequence; one by attaching a pinhole to the knob and one with my bare nails, but maybe I was lucky. To stay on the safe side you could replace the #2 connector between the 36t gears with a bush and use pins with stop bush instead of the 3L axles with knob. 1 hour ago, Aventador2004 said: Are you absolutely sure to don't work for TLG? Nice blender. Haha, I don't, but I regard that as a compliment! I would love to work at their Technic quality assurance department though - if it exists . I sure would have vetoed the Porsche . But not only to send things back to the designers, also to add a finishing quality touch to each model. Edited June 9, 2017 by Didumos69 Quote
Aventador2004 Posted June 9, 2017 Posted June 9, 2017 1 hour ago, Didumos69 said: Haha, I don't, but I regard that as a compliment! I would love to work at their Technic quality assurance department though - if it exists . I sure would have vetoed the Porsche . But not only to send things back to the designers, also to add a finishing quality touch to each model. I can imagine you doing that, you sure are a perfectionist! Quote
TechnicRCRacer Posted June 10, 2017 Posted June 10, 2017 (edited) The blender is cool! I like the effect the soft axles give to the mixing part! Have you used it on anything yet? Edited June 10, 2017 by TechnicRCRacer SOFT axles, not FLEX axles! Quote
Didumos69 Posted June 10, 2017 Author Posted June 10, 2017 (edited) 4 hours ago, TechnicRCRacer said: Have you used it on anything yet? Not to whip cream, but yes I have: Edited June 10, 2017 by Didumos69 Quote
Didumos69 Posted June 30, 2017 Author Posted June 30, 2017 (edited) Recent discussion in the Technic 2017 Set Discussion topic about the 2017 flagship set gave me some inspiration to finish my mini-trilogy. A car, a plane and a now also a boat. A catamaran to be specific. With a flag, of course . Edited June 30, 2017 by Didumos69 Quote
DugaldIC Posted June 30, 2017 Posted June 30, 2017 Very clever little trio, I do like your final/third option. What does it look like next to the others though? Quote
grum64 Posted June 30, 2017 Posted June 30, 2017 I love your miniature build's with the Catamaran being my favourite. Any more in the pipeline? Quote
Didumos69 Posted June 30, 2017 Author Posted June 30, 2017 5 hours ago, DugaldIC said: Very clever little trio, I do like your final/third option. What does it look like next to the others though? 1 hour ago, grum64 said: I love your miniature build's with the Catamaran being my favourite. Any more in the pipeline? Thanks guys! No nothing in the pipeline, apart from instructions for my 40th anniv. tiny tow truck tribute. Here's a tender of the trio: And the less pretty side of the catamaran: Quote
1gor Posted July 1, 2017 Posted July 1, 2017 Small catamaran is trully a flagship in your collection Quote
Didumos69 Posted July 2, 2017 Author Posted July 2, 2017 16 hours ago, I_Igor said: Small catamaran is trully a flagship in your collection Thanks! Even though I like the catamaran with sails, I think a speed catamaran suits the trilogy better: Quote
