marbleman Posted June 14, 2016 Posted June 14, 2016 Since finished my QJ locomotive(http://www.eurobricks.com/forum/index.php?showtopic=133621#entry2572918), I begin to plan upgrade smoking effect. At beginning, I plan to use smoking device always used on train model but finally failed. It's not suitable to Lego train. Finally, I found a good solution. The secret is this device, Micro ultrasonic atomizer. Install it in my train, the circle board can be put in tender. Here is final effect You can see from video, the effect is vivid. YouTobe is forbidden in China, I hope you can link the video in china site http://v.youku.com/v_show/id_XMTYwODIzMDEwOA==.html Quote
LEGO Train 12 Volts Posted June 14, 2016 Posted June 14, 2016 Fantastic upgrade ...the smoke is the icing on the cake! Quote
marbleman Posted June 14, 2016 Author Posted June 14, 2016 Awesome! What liquid are you using? Just water. Quote
dr_spock Posted June 14, 2016 Posted June 14, 2016 Cool. Don't they use ultrasonic atomizers in aroma therapy machines too? Quote
3D LEGO Posted June 15, 2016 Posted June 15, 2016 marbleman, Only using water will be a definite advantage as the alternative uses paraffin wax which would leave a residue on your models. 3D LEGO Quote
marbleman Posted June 15, 2016 Author Posted June 15, 2016 Cool. Don't they use ultrasonic atomizers in aroma therapy machines too? Yes, but smoke is small used in aroma therapy. This is nomally used in humidifier. Quote
marbleman Posted June 15, 2016 Author Posted June 15, 2016 wow! where did you get this? It's bought from China shopping site. Quote
Xris Posted June 16, 2016 Posted June 16, 2016 Hello Marbleman, congratulations for this solution! The generated "vapour" is less smelly and you also avoid the oily emissions produced by usual smoke generators. Since finished my QJ locomotive(http://www.eurobrick...21#entry2572918), I begin to plan upgrade smoking effect. At beginning, I plan to use smoking device always used on train model but finally failed. It's not suitable to Lego train. Could you please report on the problems you ran into when trying to use conventional smoke generators? Was it just insufficient voltage or current? I would be happy to learn from you. Christian Quote
toxicbananna Posted June 17, 2016 Posted June 17, 2016 It's bought from China shopping site. Can you PM me the link? Quote
marbleman Posted June 17, 2016 Author Posted June 17, 2016 Can you PM me the link? https://item.taobao.com/item.htm?id=36219661723 Quote
marbleman Posted June 17, 2016 Author Posted June 17, 2016 (edited) Hello Marbleman, congratulations for this solution! The generated "vapour" is less smelly and you also avoid the oily emissions produced by usual smoke generators. Could you please report on the problems you ran into when trying to use conventional smoke generators? Was it just insufficient voltage or current? I would be happy to learn from you. Christian The Votage of the smoke generator I every used is higher than 9V, It's hardly drivered by lego battery box. And the main issue is it special used for train model, you must install whole system into your lego train, my train haven't enough room for it. And the last, the price of the generator is more than $60, my device only $2 and no continious cost, water is free. Edited June 17, 2016 by marbleman Quote
