2 hours ago, ifilin said:
Guys, someone knows, is that bug fixed already? Want to buy Buwizzes for Didumos buggy.
All I can say, firmware fix and update is in the works.
Edited by Zerobricks
  • Replies 1.8k
Is there any visible difference between buwizz 1.0 and 2.0?  I have a couple 1.0's but I am debating buying a couple more 2.0's.  Assuming they look the same so would need to careful not to mix them up?
I too have the problem with buzwizz cutting out only after a few seconds on ludicrous, and even in fast but after a bit longer. This unfortunately make them almost unusable since this “safety” kicks in unnecessarily and way too early.
any update on a fix please ?
WHat kind of a load are you putting on BuWizz?
Would love to see one thing implemented in the app - easy switch between steering modes.
Example: 2 servos, each is connected separately. Assigning each servo to different control is pretty obvious - not an option.
If there would be a way to somehow add an inverser for 1 of 2 motors while you already connected, that would be an easily controllable crab mode:innocent:
1 hour ago, MultiDoc said:
Steering also is cutting off at the same time :sceptic:
If your battery level is low than protection will get triggered sooner
You can use the mixers which are in the beta for that.
I have also thought this was because of the safety kicking in, but I even experience this behavior in normal mode. But I only have this issue with Apple devices. With my Android phone it's okay. I also tried the Brickcontroller app, but it has too much lag. Steering is impossible.
Woot, looking forward to alpha then.
That's an interesting observation. So you are saying current protection triggers sooner when using apple device?
I’m using an iPhone with latest iOS FYI. As for the buzwizz’s they are both fully charged when this behaviour is triggered. Another thing to help you with troubleshooting might be that when this “cut off” happens, I have to shut down and restart the application to get back to normal behaviour again.
overall the battery of the buzwizz lasts quite fine, however this cutting off is at the very least annoying and it happens very very easily, in less than a minute on ludicrous and as I said a bit longer on fast.
unfortunately I don’t have any android devices to test if it’s the same or not.
As for range, I’ve been able to have normal control up to about 10-12 meters.
Try changing power modes between fast/ludicrous next time it cuts off. Might help you avoid turning app on and off. Can you get an andorid based device and see it it happens too?
Also they way you are driving can affect this behaviour if you are suddenly changing from forwards to reverse in full power and such.
Well, what I experience is that the Apple devices disconnect all the time and my Android device works fine. I don't know if this disconnecting is caused by the current protection. It happens also in normal mode.
I can confirm. My 3x- buwizz with 3 buggy motors car disconnets while driving very easily. I just can drive straight and may be some turns before 1 of 3 buwizz bricks disconnects with iOS app.
And with Android it does not disconnect?
  • 5 weeks later...
New (beta) version of the BuWizz app has been released. It allows saving profiles (finally), background images, resized controls, repositioned controls, control labels, control style (not working yet on my phone).
Im at work, so I haven't connected it to a BuWizz unit yet, but so far the app is a huge improvement over the last one.
Screenshot of a profile I created:
https://photos.app.goo.gl/DkypGMnohyMdzRhc8
Link to the beta version (Play Store) of the app: https://click.pg.mlsend.com/link/c/YT0xMDY2NDUzMjMxMDI4MTQ3Mjc5JmM9dDlnOSZlPTE5MjgmYj0yMjUwNzM1NjQmZD1nNnQxdDBx.0Cdb0L5EG1BIfg2HYLZiwM8sHCjTNWyaU-EzpjW-nLU
iOS version is pending approval from Apple, should be available in a couple of days.
