Lego2016Lego Posted June 29, 2016 Posted June 29, 2016 I am making a mini crawler, it is 4-wheel drive, have flex axle suspension (need to buy the flex axles), and steering. I need to get flex axles and a smaller battery box. I also need to make a better body. This is based of a H1 Hummer like this: http://www.thehummerguy.com/wp-content/uploads/2014/07/img_8875.jpg I based some of my frame of a Pego Suzuki Samurai Rock Crawler http://www.eurobricks.com/forum/index.php?showtopic=136280 but not much. Thank you anyways Pego. Quote
Lego2016Lego Posted June 29, 2016 Author Posted June 29, 2016 I may be able to buy the flex axles today. Quote
Lego2016Lego Posted July 1, 2016 Author Posted July 1, 2016 I will be gone for a week but next time I post my crawler body should be done. Quote
agrof Posted July 1, 2016 Posted July 1, 2016 This is the right way to start, it was a good choice to take Pego's chassis as base. It is small, but interesting, good learning material! With some fine tuning, your bodywork will be also better, maybe like an old american truck. :) Please make test video too. Quote
Lego2016Lego Posted July 1, 2016 Author Posted July 1, 2016 (edited) I am making a roll cage body. I need to finish the body and get flex axles and a battery box but here is video. Sorry for bad video. Edited July 1, 2016 by Lego2016Lego Quote
syclone Posted July 1, 2016 Posted July 1, 2016 (edited) Very powerful for it's size , the new body looks better. The video is working Edited July 1, 2016 by LXF Quote
Pego Posted July 1, 2016 Posted July 1, 2016 Looks great! Nice to see someone uses the LDD files I'm making The front axle seems great, but you should lengthen the steering rack by 2 studs if possible, so that it doesn't get reverse ackerman. Also the bodywork seems a little narrow, I'd maybe widen it by 2 studs. Quote
Lego2016Lego Posted July 2, 2016 Author Posted July 2, 2016 I ordered my parts so I will do a update in a week. Quote
PunkTacoNYC Posted July 2, 2016 Posted July 2, 2016 (edited) Nice looking, The steering looks nice and rigid. I would consider moving up to the 62.4mm D. x 20mm tires (from the Mercedes Arocs set) as it will not only have better ground clearance, but it will also have better performance. Edited July 2, 2016 by PunkTacoNYC Quote
Pego Posted July 2, 2016 Posted July 2, 2016 Nice looking, The steering looks nice and rigid. I would consider moving up to the 62.4mm D. x 20mm tires (from the Mercedes Arocs set) as it will not only have better ground clearance, but it will also have better performance. It depends on the situation, here I'd keep these tires as larger ones raise the COG and makes it prone to tipping, also the ground clearance seems fine. Better performance? Depends, for rocks sure, but mud, sand and other stuff not so much, it's all down to preference. Also larger tires means more torque through the cv joints making them pop easily. So keeping those tires is my advise. Quote
Lego2016Lego Posted July 10, 2016 Author Posted July 10, 2016 Hi guys I'm back! I may get the parts tomorrow. Quote
Lego2016Lego Posted August 9, 2016 Author Posted August 9, 2016 Hi, I am sorry for not posting sooner but I have been moving and just been able to work on it. I will post pics soon but I have redone the front suspension and made the chassis stronger. Quote
Lego2016Lego Posted August 9, 2016 Author Posted August 9, 2016 (edited) New suspension and video will be posted soon Edited August 9, 2016 by Lego2016Lego Quote
Imanol BB Posted August 9, 2016 Posted August 9, 2016 Nice to know that, the axle looks very robust. Quote
Lego2016Lego Posted August 9, 2016 Author Posted August 9, 2016 (edited) Nice to know that, the axle looks very robust. Nice to know? and I tried to make it strong. Edited August 9, 2016 by Lego2016Lego Quote
Lego2016Lego Posted August 10, 2016 Author Posted August 10, 2016 I got the video sorry for the wait but flickr was having problems yesterday. Quote
Lego2016Lego Posted August 10, 2016 Author Posted August 10, 2016 I made a mockup of the battery box I want to get and where it will be. Quote
Imanol BB Posted August 10, 2016 Posted August 10, 2016 Nice to know? and I tried to make it strong. I mean that it was nice to know that the video was coming, and the vehicle is looking nice by the way. Quote
JJ2 Posted August 10, 2016 Posted August 10, 2016 If you are using the 9V battery box the IR will not work. Quote
Lego2016Lego Posted August 10, 2016 Author Posted August 10, 2016 If you are using the 9V battery box the IR will not work. what do you mean the ir wont work? Quote
JJ2 Posted August 10, 2016 Posted August 10, 2016 what do you mean the ir wont work? If you use an old Lego battery box that was made before Power Functions the Infrared Receiver will not turn without bridging the tabs like this Quote
Lego2016Lego Posted August 10, 2016 Author Posted August 10, 2016 If you use an old Lego battery box that was made before Power Functions the Infrared Receiver will not turn without bridging the tabs like this I am going to buy http://shop.lego.com/en-US/LEGO-Power-Functions-AAA-Battery-Box-88000?fromListing=listing Quote
JJ2 Posted August 10, 2016 Posted August 10, 2016 I am going to buy http://shop.lego.com...Listing=listing Ok but the size of the mockup battery box looks like the old one sorry. Quote
Lego2016Lego Posted August 10, 2016 Author Posted August 10, 2016 (edited) Ok but the size of the mockup battery box looks like the old one sorry. That's ok Edited August 10, 2016 by Lego2016Lego Quote
