I've built these vehicles to be used for the town airport. It is a small unit containing a water (or foam) cannon, a tank with ladder, tools and hose and a paramedic vehicle.
27418510444_bbfce52a47_b.jpgLEGO Fire Crew 1 by Severus A, on Flickr
The water cannon:
27418510964_e3c350d475_z.jpgLEGO f.c. 1 by Severus A, on Flickr
27997829096_4cdcd7c960_z.jpgLEGO f.c. 2 by Severus A, on Flickr
27954688441_3727db107c_z.jpgLEGO f.c. 4 by Severus A, on Flickr
The paramedic unit:
27752017460_1b8340b066_z.jpgLEGO paramedics 1 by Severus A, on Flickr
27997829296_d4aa51f0df_z.jpgLEGO paramedics 2 by Severus A, on Flickr
27954688251_a22a22b123_z.jpgLEGO paramedics 5 by Severus A, on Flickr
27997828936_9e8f4a2a4a_z.jpgLEGO paramedics 6 by Severus A, on Flickr
The tank with ladder:
27997829416_2d0e1b8828_z.jpgLEGO f.t. 1 by Severus A, on Flickr
27954688151_af6985a5ca_z.jpgLEGO f.t. 4 by Severus A, on Flickr
27752017090_5a197a2c2e_z.jpgLEGO f.t. 5 by Severus A, on Flickr
They are pretty cool. I always preferred 4 studs wide vehicles.
You should also build a stair vehicle and an aircraft tow tractor.
Thank you. I usually build the vehicles in 4 wide because I like the classic town way of building. Good point regarding the stair vehicle and tow tractor.
I love it, 4 wide airport is the best! I have ZERO interest in modern lego airport and aircraft, 6 wide is just excessive for Lego scale when it comes to that.
I just finished rebuilding some of my early 1990s airport sets and I still love the way the 4 wide jets look.
Thanks for your comment. I have the same opinion as you regarding the aircraft scale. In the same time I've seen many beautiful works in 6 or 8 wide. Most of my sets are from the middle of the 80s and I prefer to keep the 4 wide scale even I use modern elements and techniques. Maybe a Neoclassic Town movement could be brought in attention. Who knows? :)
The problem with building a stair vehicle in this scale is that the planes are really low usually.
Well, I'll take the challenge :) A mobile stair is contained by 10159 International Airport set. Indeed it is not very inspired but is useful. http://lego.brickinstructions.com/lego_instructions/set/10159/City_Airport
Good work ! I also prefer 4w studs wide vehicle than 6w one.
Thank you.
