SylvainLS Posted June 18, 2020 Author Posted June 18, 2020 (edited) Update 2020-06-18 Corrected: 62275.dat / 62275 ~Technic Linear Actuator 8 x 2 x 2 Piston (remove 1 LDU gap with Head) Torso assemblies Importable: 35298.dat / 62360 =Windscreen 3 x 6 x 1 Curved with Bottom Rectangular Stud Holder 35299.dat / 62360 Windscreen 3 x 6 x 1 Curved with Bottom Rectangular Stud Holder Added Custom parts: 35186 / 35186.dat Technic Transmission Driving Ring Extension with Eight Clutch Teeth 35189 / 35189.dat Technic Steering Wheel Hub with Brake Disc and 3 Pegholes 39367 / 39367p01.dat Wheel 14 x 48 with 4 Spokes with Integral Medium Azure Tyre 66606 / 66606.dat Panel Cone 4 x 6 x 10 Elliptic Parabolic Note: The custom version of 32235 is flexible, that means LDD doesn’t export nor import it anymore. (LDD doesn’t convert flexible parts.) md5sum: 6bfabef025776a883e309fc5193980ff Edited June 18, 2020 by SylvainLS Quote
SylvainLS Posted June 23, 2020 Author Posted June 23, 2020 Update 2020-06-23 Added: 43086 / 43086.dat Panel Ramp Curved Turn 16 x 16 x 6 Added Custom parts: 2619 / 2619.dat Monorail Motor Box 2670 / 2670.dat Monorail Track Straight 4 x 8 2671 / 2671.dat Monorail Track Straight 4 x 32 2672 / 2672.dat Monorail Track Curve Quarter 2677 / 2677.dat Monorail Track Ramp Lower Section 2678 / 2678.dat Monorail Track Ramp Upper Section 2681 / 2681.dat Support 6 x 6 x 10 Stanchion 2687 / 2687.dat Monorail Base 4 x 20 2891 / 2891.dat Monorail Track Curve Short Right 2892 / 2892.dat Monorail Track Curve Short Left 35185 / 35185.dat Technic Gear 20 Tooth Double Bevel with Clutch on Both Sides 42531 / 42531.dat Technic Panel 9 x 2 x 3 Mudguard Arched #30 42545 / 42545.dat Technic Panel 13 x 2 x 5 Mudguard Arched #31 53178 / 53178.dat Technic Pneumatic Cylinder Bracket Added Custom assemblies: (Remember that one should use the correct subparts in the LDraw model for assemblies to be importable. Even though, some of these won’t be importable due to the way they were divided.) 19474 / 19474-f1.dat Technic Pneumatic Valve with Axle Hole (Neutral Position) 19475 / 19475-f1.dat Technic Pneumatic Cylinder 1 x 5 with 2 Ports with Stepped Outlets (Retracted) 19476 / 19476-f1.dat Technic Pneumatic Cylinder 1 x 11 with 2 Ports with Stepped Outlets (Retracted) 19478 / 19478-f1.dat Technic Pneumatic Cylinder 2 x 11 with 2 Ports with Stepped Outlets (Retracted) 19482 / 19482-f1.dat Technic Pneumatic Pump 1 x 1 x 6 with Stepped Outlet (Retracted) 26288 / 26288c01-f1.dat Technic Pneumatic Pump 2 x 2 with 3L Beam (Retracted) 47223 / 47223a-f1.dat Technic Pneumatic Valve with Pegholes (Complete - Neutral Position) 74982 / 74982-f1.dat Technic Pneumatic Pump 1 x 1 x 5.5 (Retracted) 268400 / 2684c01.dat Monorail Motor with White Motor Unit (Complete) 268600 / 2686c01.dat Monorail Wheel Chassis Assembly (Complete) 277400 / 74013.dat Monorail Stop/Go Switch 279300 / 2793c01-f1.dat Technic Pneumatic Cylinder 2 x 2 x 5 with 2 Ports (Retracted) 279700 / 2797c01-f01.dat Technic Pneumatic Pump 2 x 2 x 5 with Large Knob (Retracted) 288900 / 74780-f1.dat Monorail Track Point Right - Straight 289000 / 74781-f1.dat Monorail Track Point Left - Straight 324960 / 32495c01.dat Technic Wheel Spindle Steering Arm (Complete) 469400 / 4694c01-f1.dat Technic Pneumatic Valve (Complete - Neutral Position) 472240 / 47224c01-f1.dat Technic Pneumatic Cylinder 2 x 2 x 5 with Curved Base (Retracted) Modified Custom parts: 35186 Technic Transmission Driving Ring Extension with Eight Clutch Teeth 35188 Technic Changeover Rotary Catch 41682 Bracket 2 x 2 - 1 x 2 Up Centred md5sum: 2f7106d220b2900438d213cea7a4ea6c Quote
SylvainLS Posted June 30, 2020 Author Posted June 30, 2020 Update 2020-06-30 Match colours with LDraw (ldconfig.ldr 2020-05-11). md5sum: e97e1c5f2d8e37f91abfa67031bc042a Quote
SylvainLS Posted July 6, 2020 Author Posted July 6, 2020 Update 2020-07-06 Added: 23860 / 23860.dat Minifig, Weapon Blade Faceted 3.8L with Bar 0.5L 93096 / 93096.dat Door 1 x 5 x 3 with 3 Studs and Vertical Handle Added Custom Parts: 35563 / 35563.dat Cone 4 x 2 x 4 Half with Roof Tiles 39790 / 39790.dat Technic Beam 15 x 11 with Open Center 13 x 9 39794 / 39794.dat Technic Beam 11 x 7 with Open Center 9 x 5 Corrected Custom Assemblies (new versions): 19475 Technic Pneumatic Cylinder 1 x 5 with 2 Ports with Stepped Outlets 19478 Technic Pneumatic Cylinder 2 x 11 with 2 Ports with Stepped Outlets 19482 Technic Pneumatic Pump 1 x 1 x 6 with Stepped Outlet 26288 Technic Pneumatic Pump 2 x 2 with 3L Beam 74982 Technic Pneumatic Pump 1 x 1 x 5.5 268400 Monorail Motor with White Motor Unit 268600 Monorail Wheel Chassis Assembly 277400 Monorail Stop/Go Switch 279700 Technic Pneumatic Pump 2 x 2 x 5 with Large Knob 288900 Monorail Track Point Left 289000 Monorail Track Point Right md5sum: 1dcaa9d55d014bbdd3f93499520e308b Quote
SylvainLS Posted July 16, 2020 Author Posted July 16, 2020 Update 2020-07-16 Added: 18859 / 18859.dat Dish 8 x 8 Inverted with Hollow Studs 98338 / 98338.dat Minifig Weapon Spear Short with Pin Hole Added Custom Parts: 24869 / 24869.dat Wheels Roller Coaster 39793 / 39793.dat Technic Connector Block 3 x 3 with 9 Perpendicular Holes 65416 / 65416.dat Technic Brake Disc 6 x 6 67329 / 67329.dat Brick 1 x 2 x 1.667 with 8 Studs on 3 Sides 67810 / 67810.dat Brick 2 x 2 x 1.333 with Curved Corner Top 405983 / 40598c.dat Minifig Weapon Grenade with Large Tapered Top and Four Indents 405984 / 40598d.dat Minifig Weapon Grenade with Small Tapered Top and Two Ridges Corrected Custom Parts (new versions): 39790 / 39790.dat Technic Beam 15 x 11 with Open Center 13 x 9 39794 / 39794.dat Technic Beam 11 x 7 with Open Center 9 x 5 md5sum: fd79f4c22d4d6205960613319418d7e6 Quote
SylvainLS Posted August 4, 2020 Author Posted August 4, 2020 Update 2020-08-04 Added: 98279 / 98279.dat Minifig Campaign Hat Rematched: 4209 / 4209a.dat Hose Reel 2 x 4 x 2 Holder Importable: 4209.dat / 4209 ~Moved to 4209a 4209b.dat / 4209 Hose Reel 2 x 4 x 2 Holder with Hollow Studs 28686.dat / 30293 =Rock 4 x 4 x 1.333 Top 28696.dat / 30294 =Rock 4 x 4 x 1.333 Bottom md5sum: bafe86dbe2c4f9cb571b2a9905d8eb3a Quote
SylvainLS Posted August 4, 2020 Author Posted August 4, 2020 Update 2020-08-04b Added Custom parts: 15522 / 15522.dat Minifig Head Simpsons Marge Simpson 15523 / 15523.dat Minifig Head Simpsons Bart Simpson 15524 / 15524.dat Minifig Head Simpsons Lisa Simpson 15525 / 15525.dat Minifig Head Simpsons Maggie Simpson 15527 / 15527.dat Minifig Head Simpsons Homer Simpson 22969 / 22969.dat Wheel 56 x 46 Technic Racing 32296 / 32296.dat Tyre 50/ 29 x 54 Technic Racing 32298 / 32298.dat Tyre 61/ 41 x 54 Off Road 46334 / 46334.dat Wheel 17 x 75 Motorcycle Solid (needs Work) 46335 / 46335.dat Tyre 38/ 22 x 75 Mock-Up (needs work) 65617 / 65617.dat Brick 3 x 3 x 1 Corner Round with Curved Top 67140 / 67140.dat Tyre 28/ 48 x 75 Motorcycle with Racing Tread Modified Custom parts: 35442 / 35442.dat Plate Gear 6 Tooth 2 x 2 377203 / 37720c.dat Animal Bat Emblem 1 x 2 md5sum: 4c10ab4bae81cef8736bb554e0d2a86b Quote
SylvainLS Posted August 5, 2020 Author Posted August 5, 2020 (edited) Update 2020-08-05 Rematched: 62808 / 40359a.dat Minifig Key Importable: 62808.dat / 62808 ~Moved to 40359a Added Custom Parts: 46834 / 46834.dat Technic Clutch with Axle Connector Outer Side 46835 / 46835.dat Technic Clutch with Axle Connector Inner Side 46882 / 46882.dat Technic Panel 15 x 2 x 7 Mudguard with Trapezoidal Arch 65413 / 65413.dat Technic Gear 28 Tooth Double Bevel with Peghole 65414 / 65414.dat Technic Differential Casing for 5 Internal Gears Modified Custom Part: 22969 / 22969.dat Wheel 56 x 46 Technic Racing Added Custom Assemblies: 40918 / 40918-f1.dat Technic Linear Actuator 12 x 2 x 2 (Contracted) Note on Customized Part: 47996 Boat Rigging 4 x 28 Rectangular is now flexible, and therefore LDD won’t convert it. lxf2ldr will convert it without flexing it as the part isn’t in LSynth. md5sum: 1103713abeaf19fbdccedf003e5a0088 Edited August 5, 2020 by SylvainLS Quote
SylvainLS Posted August 20, 2020 Author Posted August 20, 2020 Update 2020-08-20 Rematched: 2454 / 2454b.dat Brick 1 x 2 x 5 with Blocked Open Studs and Symmetric Inner Ridges 3755 / 3755a.dat Brick 1 x 3 x 5 without Inner Ridges Importable: 2454.dat / 2454 ~Brick 1 x 2 x 5 (Obsolete) 3755.dat / 3755 ~Moved to 3755a 46212a.dat / 2454 Brick 1 x 2 x 5 with Hollow Studs without Inner Ridges Added Custom Assemblies: 22127 / 22127.dat Electric Control+ Hub 22169 / 22169.dat Electric Control+ L Motor 22172 / 22172.dat Electric Control+ XL Motor 54675 / 54675.dat Electric Spike Prime Large Motor md5sum: 72f94b467013612cc0d2644e4065ef17 Quote
SylvainLS Posted September 7, 2020 Author Posted September 7, 2020 Update 2020-09-07 Rematched: 2654 / 2654a.dat Dish 2 x 2 with Rim Importable: 2654.dat / 2654 ~Moved to 2654a New Custom Parts: 6594 / 6594.dat Tyre 28/ 38 x 28 VR 22253 / 22253.dat Wheel 25 x 28 VR with 35mm Diameter Rear Rim and Complete Cross Axle Hole 30116 / 30116.dat Panel 14 x 14 x 2.667 Quarter Saucer Top 30119 / 30119.dat Wing 8 x 4 - 2 x 3.333 Down 32057 / 32057.dat Wheel Rim 14 x 60 with 3 Spokes and 3 Pegholes 32076 / 32076.dat Tyre 14/ 21 x 57 32077 / 32077.dat Wheel Rim 28 x 60 with 3 Spokes and 3 Pegholes 32078 / 32078.dat Tyre 28/ 21 x 57 32180 / 32180.dat Tyre 30/ 42 x 28 R Balloon 32195 / 32195b.dat Technic Suspension Arm 2 x 6.5 Type 3 32196 / 32196.dat Tyre 32/ 33 x 61 Racing Wet 32197 / 32197.dat Wheel Rim 30 x 61 with 3 Spokes Swirled 37383 / 37383.dat Wheel Rim 42 x 62 with 10 Spokes and 3 Pins 37452 / 37452.dat Brick 1 x 2 x 2 with Rounded Slab 42529 / 42529.dat Technic Sprocket Wheel 56.5 49294 / 49294.dat Wheel Rim 34 x 56 with 6 Double Spokes and 6 Pegholes 52629 / 52629.dat Technic Ball 19mm for Ball Castor 56907 / 56907.dat Tyre 35/ 42 x 56 Racing 65092 / 65092.dat Tile 1 x 1 x 0.5 Octagonal Facetted Importable Custom Parts: 32195.dat / 32195 ~Moved to 32195b 32195a.dat / 32195 Technic Suspension Arm 2 x 6.5 Type 2 Corrected Custom part: 2337 / 2337.dat Windscreen 4 x 4 x 2 Canopy Extender md5sum: 1a48b57caf6a2ad4bb04fb3c49587e49 Quote
SylvainLS Posted September 24, 2020 Author Posted September 24, 2020 Update 2020-09-24 Added: 93088 / 93088.dat Animal Puppy Stranding 98389 / 98389.dat Animal Hedgehog Added Custom Parts: 44861 / 44861.dat Plate 1 x 2 with Single Clip on Top (Thick C-Clip) 46372 / 46372.dat Technic Gear 28 Tooth Double Bevel 49283 / 49283.dat Technic Cable Clip 52730 / 52730.dat Technic Steering Constant Velocity 8mm Joint Female 52731 / 52731.dat Technic Steering Constant Velocity 8mm Joint Male Added Custom Assembly: 464900 / 46490c01.dat Wheel Hub with Planetary Gear Reduction with Dark Bluish Grey Wheel Hub md5sum: 189742f534fc80283fdf4b06dc7629d6 Quote
SylvainLS Posted October 10, 2020 Author Posted October 10, 2020 Update 2020-10-10 Added: 18663 / 18663.dat Minifig Stand Flexible 19734 / 19734.dat Minifig Torso with Two Studs on Two Opposite Sides and Cube Feet 90388 / 90388.dat Minifig Hat Sombrero 94717 / 94717.dat Figure Friends Accessories Bow 94718 / 94718.dat Figure Friends Accessories Award Ribbon with Number 1 94722 / 94722.dat Figure Friends Accessories Award Ribbon with Number 2 94725 / 94725.dat Figure Friends Accessories Bow with Heart Rematched: 10190 / 10190.dat Minifig Flipper (Thick) 59275 / 59275.dat Minifig Flipper (Thin) Importable: 2599.dat / 59275 Minifig Flipper md5sum: 2b14afa029fe45cef8dc9418d2f65c3e Quote
SylvainLS Posted October 20, 2020 Author Posted October 20, 2020 Update 2020-10-20 Added: 23766 / 23766.dat Minifig, Head Cuboid with Raised Rectangle 94719 / 94719.dat Figure Friends Accessories Comb, Small with Heart 94720 / 94720.dat Figure Friends Accessories Brush Oval, Large Rematched: 3308 / 3308a.dat Arch 1 x 8 x 2 Importable: 3308.dat / 3308 ~Arch 1 x 8 x 2 (Obsolete) 29161.dat / 10190 =Minifig Flipper Thick 88408.dat / 59275 =Minifig Flipper Thin Added Custom Assemblies: 2698c01 / 2698c01.dat Technic Action Figure (Complete) 5292 / 42908.dat Electric RC Race Buggy Motor (Complete) 6272c01 / 6272.dat Electric RC Race Buggy Receiver Unit with Auxiliary Output (Complete) 9062 / u9062c01.dat Motor Pull Back 4 x 9 x 2.333 Type 2 with Black Base 32283c01 / 32283c01.dat Motor Pull Back 4 x 9 x 2.333 Type 1 with Black Base 37191c01 / 37191c01.dat Minifig Torso Brick 2 x 3 with Arms Added Custom Parts: 1023 / u1023a.dat Sheet Plastic 11 x 27 Trapezoidal 1024 / u1023b.dat Sheet Plastic 14 x 20 Triangular 1025 / u1023c.dat Sheet Plastic 11 x 20 Trapezoidal 1026 / u1023d.dat Sheet Plastic 10 x 17 Trapezoidal 2738 / 2738.dat Technic Suspension Arm 2 x 6.5 Type 1 2999 / 2999.dat Technic Large Wheel Hub 30037 / 30037.dat Wing 9 x 12 - 6 x 2.333 Down 32079 / 32079.dat Technic Beam 9 Liftarm Offset with Boss 32137 / 32137.dat Technic Connector Block 3 x 2 x 2 66909 / 66909.dat Bar 2L with Top Studs md5sum: 8a8072e8561b79d4ef7fa000aff3597c Quote
SylvainLS Posted October 23, 2020 Author Posted October 23, 2020 Update 2020-10-23 Added: 10164 / 10164.dat Minifig Headdress Beanie with Pom Pom 11437 / 11437.dat Minifig Helmet Ornament Horn Elaborate 15446 / 15446.dat Minifig Helmet Visor with Night Vision 29601 / 29601.dat Minifig Gun with Round Heat Diffusers, Fin and Spherical Emitter 30210 / 30210.dat Dish 2 x 2 with Angled Bar 47991 / 47991.dat Panel 5 x 10 x 10 Rocky Skull 60751 / 60751.dat Minifig Helmet with Cheek Protection and Thin Bands 93106 / 93106.dat Minifig Metal Detector without Stud on Search Head 94721 / 94721.dat Figure Friends Accessories Brush Round, Small 94723 / 94723.dat Figure Friends Accessories Sponge md5sum: 686a99e8cf1a7784b6d36891e532dd2d Quote
SylvainLS Posted October 30, 2020 Author Posted October 30, 2020 Update 2020-10-30 Added: 11250 / 11250.dat Minifig Tool Gavel 15082 / 15082.dat Animal Wing Bat with 0.5L Bar 15626 / 15626.dat Panel 4 x 16 x 10 with Gate 21787 / 21787.dat Minifig Hair Short Quiff 24054 / 24054.dat Door 1 x 4 x 7.667 with Curved Top 27149 / 27149.dat Minifig Hat Cylinder Tapered with Hatband 29633 / 29633.dat Minifig Hair Bob Cut Parted in Middle 29636 / 29636.dat Minifig Whisk 59232 / 59232.dat Minifig Flail 93091 / 93091.dat Figure Friends Handbag with Zipper 94724 / 94724.dat Figure Friends Accessories Spray Bottle with Heart Rematched: 23306 / 577c.dat Minifig Lightsaber Hilt without Bottom Ring 32531 / 32531b.dat Technic Brick 4 x 6 with Open Center 2 x 4 with Round Underside Studs 32532 / 32532b.dat Technic Brick 6 x 8 with Open Center 4 x 6 with Round Underside Studs Importable: 577a.dat / 23306 ~Minifig Lightsaber Hilt without Bottom Ring (Obsolete) 15556.dat / 23306 ~Minifig Lightsaber Hilt without Bottom Ring (Obsolete) 15556a.dat / 23306 =Minifig Lightsaber Hilt without Bottom Ring 32531.dat / 32531 ~Moved to 32531a 32531a.dat / 32531 Technic Brick 4 x 6 with Open Center 2 x 4 with Cross Underside Studs 32532.dat / 32532 ~Moved to 32532a 32532a.dat / 32532 Technic Brick 6 x 8 with Open Center 4 x 6 with Cross Underside Studs md5sum: e35bb62f0bef2f623e357cd19a94bb38 Quote
pierrot9538 Posted November 16, 2020 Posted November 16, 2020 Hi, It seems part 24299 and 24307 don't export at all from LDD. Is this a problem with my setup ? I opened Ldraw.xml and found these parts but there are not foundable in LDD. Quote
SylvainLS Posted November 16, 2020 Author Posted November 16, 2020 Hi, It’s not clear to me: You’re first talking about exporting from LDD, so the parts have to be in LDD. Then you’re saying they aren’t in LDD. If you can’t find them in LDD with the other wings, then check in Help | About that you have LDD 4.3.11 with a brick version 2670. If you’ve brick version 777, then you’ve installed 4.3.12. See one of the numerous posts about this crap (like this last one). Quote
pierrot9538 Posted November 16, 2020 Posted November 16, 2020 Hi, Ok i had installed 4.3.12 version instead of 4.3.11, it's ok now. i have download your last ldraw.xml file, but i can't find those in LDD in wing parts Thank your for your help. Quote
SylvainLS Posted November 16, 2020 Author Posted November 16, 2020 You need to be in LDD Extended mode (menu View | New themes | Extended). You can go back and forth between the modes, though, even when LDD was still updated, the last parts updates were only available in Extended, so “normal” mode has been pretty useless for some time now. LDD saves the last mode used in the LXF, so it starts in the “right” mode when you open a file. The big difference is in how colours/painting work. Quote
SylvainLS Posted November 20, 2020 Author Posted November 20, 2020 Update 2020-11-20 Added: 11216 / 11216.dat Bar Grill 13 X 17 with Studs and Tips 15362 / 15362.dat Claw 6.4L with Axle 24636 / 24636.dat Minifig Headdress with Widow's Peak and Two Large Curved Segmented Horns 27934 / 27934.dat Plate 1 x 2 with Extrusion with Hexagonal Decorations 28946 / 28946.dat Minifig Head Powerpuff Girls Blossom with Orange Hair and Red Bowtie 28948 / 28948.dat Minifig Head Powerpuff Girls Bubbles with Yellow Hair 28949 / 28949.dat Minifig Head Powerpuff Girls Buttercup with Black Hair 43889 / 43889.dat Animal Tail Joint with Short Pin Connector 89519 / 89519.dat Bar Grill 9 X 13 with Studs and Tips Rematched: 30191 / 30191.dat Bar Flexible H-shaped with Holders Importable: 30191-f1.dat / 30191 Bar Flexible H-shaped with Holders 89513.dat / 89519 Door 1 x 8 x 12 Castle Gate Portcullis Added Custom Parts: 2712 / 2712.dat Technic Rotor 3 Blade 2719 / 2719.dat Technic Plate 1 x 10 with Holes 2737 / 2737.dat Technic Steering Arm Tall 2792 / 2792.dat Technic Steering Top 2900 / 2900.dat Technic Flex-System Pin Hole Connector 2901 / 2901.dat Technic Flex-System Ball Connector 2908 / 2908.dat Technic Helicopter Rotor Holder 2989 / 2989.dat Technic Brick 1 x 4 with Holes and Bumper Holder 2991 / 2991.dat Technic Brick 1 x 2 Double Angled with Bumper Holder 2997 / 2997.dat Tyre 34/ 38 x 56 ZR 2998 / 2998.dat Wheel Rim 32 x 56 with Peghole and 6 Spokes with Pegholes 3651 / 3651.dat Technic Connector (Pin/Bush) with 2 Studs 4261 / 4261.dat Technic Steering Arm 4262 / 4262.dat Technic Plate 1 x 6 with Holes 4273 / 4273b.dat Technic Connector Toggle Joint Toothed 4442 / 4442.dat Technic Plate 1 x 8 with Holes 4504 / 4504.dat Hinge Plate 1 x 6 with 2 and 3 Fingers On Ends 4727 / 4727.dat Plant Flower 2 x 2 Leaves 4745 / 4745.dat Propellor 2 Blade 5.5 Diameter 65401 / 6540b.dat Technic Steering Arm Large with Peghole 65402 / 6540a.dat Technic Steering Arm Large with Axlehole 6543 / 6543.dat Technic Plate 4 x 6 with 4 Position Gear Shift Gate 6549 / 6549.dat Technic 4 Speed Shift Lever 28125 / 28125.dat Minifig Headdress Bald Head High 65509 / 65509.dat Plate 2 x 4 with Groove with 2 Studs 426502 / 6577.dat Technic Bush 1/2 Type 2 Added Custom Assemblies: 6282 / 6282c01.dat Electric RC Race Buggy Steering Unit (Complete) (exports with duplicated axle and level, doesn’t import) 6642 / 6642.dat Technic Flex-System Pin Connector Double Closed (doesn’t import, exports with one misplaced lid) 6643 / 6643.dat Technic Flex-System Pin Connector Single Closed 6644 / 6644.dat Technic Flex-System Ball Connector Closed 9244 / 3712c01.dat Technic Universal Joint (Complete Assembly Shortcut) 32181c01 / 76320-f1.dat Technic Shock Absorber 10L Damped (Extended) 41894c01 / 41894c01.dat Technic Steering Arm With 2 Ball Joints (Complete) Importable as Custom Parts: 4265b.dat / 426502 ~Moved to 6577 4273.dat / 4273 ~Moved to 4273b 4273a.dat / 4273 Technic Connector Toggle Joint Toothed With No Slots md5sum: e18435d056431a28cf7e297d72408d32 Quote
SylvainLS Posted December 23, 2020 Author Posted December 23, 2020 Update 2020-12-23 Added: 11305 / 11305.dat Technic Rotor 1 Blade 14L with Axle 12895 / 12895.dat Minifig Captains Hat with Black Visor and Narrow Golden Braid 25279 / 25279.dat Animal Horse Friends Barding 98135 / 98135.dat Technic Rotor 1 Blade 16L with Axle Added Assembly: 10679 / 10679.dat Minifig Hips and Legs with Robotic Leg Right Added as Custom Part but was in LDD before 4.3.10: 23065 / 22119.dat Ball 52mm Diameter Added Custom Parts: 2302 / 2302.dat Duplo Brick 2 x 3 with Curved Top 4587 / 4587.dat Animal Horse Hitching with Hinge 20193 / 20193.dat Sheet Plastic 3.6 x 6.6 Rectangular with Mirror Glass Pattern 24108 / 24108.dat Minifig Sword with Hexagonal Decorations 32627 / 32627.dat Plate Round 4 x 4 with Groove with Two Open Centre Studs 35039 / 35039.dat Animal Spider Biomechanical Legs and Head 35473 / 35473.dat Plant Flower 4 x 4 with 4 Rounded Petals 35565 / 35565.dat Panel 2 x 6 x 6 with Pointed Arch Opening and Rounded Sides 35578 / 35578.dat Tyre 14/ 70 x 17 38317 / 38317.dat Cone 4 x 2 x 3 Half 39613 / 39613.dat Plate 3 x 3 Heart Shape 40066 / 40066.dat Door 1 x 6 x 7 with Arch and Rounded Pillars 43979 / 43979.dat Wing 12 x 12 x 1.333 with 8 x 4 Recessed Centre 46342 / 46342.dat Plate 6 x 6 Heart Shape 60373 / 60373.dat Cylinder Quarter 3 x 3 x 5 with 2 Half-Arches at 90 Degrees 65421 / 65421.dat Technic Concrete Mixer Half Shell 65422 / 65422.dat Technic Rotor Blade 19L with Beam 3L 67141 / 67141.dat Technic Panel 15 x 2 x 5 Mudguard Arched with Rounded Top 67142 / 67142.dat Technic Panel 5 x 13 Curved 50 Tapered Left 68196 / 68196.dat Technic Panel 5 x 13 Curved #51 Tapered Right 71708 / 71708.dat Technic Beam 2 x 3 Liftarm Bent 90 Quarter Ellipse 73831 / 73831.dat Plate 2 x 3 with 1 x 1 Cutout 92198 / 92198.dat Figure Friends Head without Pattern 92240 / 92240.dat Figure Friends Male Head without Pattern 107400 / t1074.dat | Big Ben Bricks Train Wheel Medium Blind Driver 24.0 mm 107500 / t1075.dat | Big Ben Bricks Train Wheel Blind Driver 30.4 mm Added Custom Assemblies: 16530 / 16529p01c01.dat Figure Friends Hips and Legs Mermaid Tail with Light Lime Tip Pattern 38551 / u9210p01c01.dat Figure Friends Torso Boy 92241 / 92241p01c01.dat Figure Friends Torso Girl 92242 / 92242p01c01.dat Figure Friends Torso Man md5sum: b3bf90da145b21a8fe888a130505a48d Quote
SylvainLS Posted January 16, 2021 Author Posted January 16, 2021 Update 2021-01-16 Added: 98088 / 98088.dat Animal Wing Left Pteranodon 98089 / 98089.dat Animal Wing Right Pteranodon Corrected: 14226 String Braided 11L with End Studs (Complete) 14224 String Braided 41L with End Studs (Complete) 63140 String Braided 41L with End Studs (Complete) Those are now flexible as Custom parts and therefore LDD won’t export them anymore… but remember that most flexible parts can be converted by lxf2ldr(.html) Added Custom parts: 32166 / 32166.dat Technic Connector Block 3 x 6 x 1.667 Gearbox 35463 / 35463.dat Tile 1 x 1 with Curved Triangle 35709 / 35709.dat Minifig Costume Flowerpot 37493 / 37493.dat Train Front 6 x 10 x 7 39369 / 39369.dat Technic Beam 19 x 11 Baseplate 44666 / 44666.dat Plate 14 x 18 x 1 with Three Pinholes at Centre 49577 / 49577.dat Plant Seaweed with 4 Studs and 7 Bars 49656 / 49656.dat Rock 1 x 1 Geode 52494 / 52494.dat Plate 1 x 1 x 0.667 with Binoculars 65473 / 65473.dat Brick Round 2 x 2 Curved 135 Degree 65578 / 65578.dat Plate 1 x 1 Round with Angled Bar 66961 / 66961.dat Brick 2 x 2 x 0.667 with Handle on 4 Sides and 2 Studs on Top 67095 / 67095.dat Tile 3 x 3 Round 67139 / 67139.dat Technic Connector Block 3 x 5 x 1 with Cutout 67440 / 67440.dat Slope Brick 60 4 x 1 x 3 Inverted 67446 / 67446.dat Plate 2 x 4 with Side Bricks 1 x 2 x 1.333 with Axle Hole 67811 / 67811.dat Car Steering Wheel 5 x 5 with Two Spokes and 2 x 2 Stud Centre with Axlehole 68013 / 68013.dat Cylinder Half 1 x 2 with Cutout 68297 / 68297.dat Plate 4 x 8 without Corners 68382 / 68382.dat Plate 1 x 4 with 2 Pins 68495 / 68495.dat Minifig Cup Stein with Handle 68504 / 68504.dat Minifig Sundae Glass 68568 / 68568.dat Plate 3 x 3 with 2 x 2 Corner Round and 2 x 2 with 1 x 1 Corner Round Cutout 68869 / 68869.dat Tile 4 x 4 x 0.667 with Rounded Corners 69066 / t69066.dat Container 1 x 3 Crate 69906 / 69906.dat Bracket 3 x 2 - 2 x 2 Down with Rounded Brace 69909 / 69909.dat Tyre 28/ 57 x 43 Off Road 69911 / 69911.dat Technic Panel 13 x 2 x 5 Mudguard Arched with Rounded Top 69963 / 69963.dat Plate 2 x 4 with Steering Axle Socket 69964 / 69964.dat Wheel Axle Tilt Steering 71682 / 71682.dat Technic Panel Curved 3 x 2 x 1 71689 / 71689.dat Technic Panel 13 x 2 x 5 Mudguard Arched Extension 71709 / 71709.dat Technic Panel 3 x 7 71710 / 71710.dat Technic Beam 15 with Alternating Holes 609000 / u609.dat Brick 1 x 4 x 2 Bellshaped with Headlights Corrected Custom parts: 36752 Minifig Tool Wand 37695 Plant Stem with 3 Leaves with Bar and Pin Holes 38317 Cone 4 x 2 x 3 Half 41812 Projectile Launcher 4 x 2 x 1 with Bottom Axle 52985 Tyre 27/ 48 x 43 92198 Figure Friends Head without Pattern Corrected Custom assembly: 279300 PNEUMATIC CYLINDER 2X7 md5sum: e27209a82591db9b5ea02a29bf79865d Quote
SylvainLS Posted March 12, 2021 Author Posted March 12, 2021 Update 2021-03-12 Added: 15423 / 15423.dat Minifig Body Armour Vest 18729 / 18729.dat Windscreen 6 x 10 x 4 Curved 18926 / 18926.dat Tipper Bucket 8 x 12 x 4.6667 25111 / 25111.dat Minifig Sword Dao with Curved Blade and Hilt 30838 / 30838.dat Wheel Rim 6.4 x 11 with 7 Spokes 93565 / 93565.dat Minifig Body and Shoulder Armour Smooth 97895 / 97895.dat Minifig Life Jacket 98150 / 98150.dat Minifig Head Snake 98386 / 98386.dat Animal Puppy Walking Rematched (renamed in LDraw): 9320 / 23807.dat ~Electric Power Functions 2.0 Socket 23306 / 23306.dat Minifig Lightsaber Hilt with Steep Sloping Fingers md5sum: 75125d758db8ef8a3d074291a7cf4abb Quote
SylvainLS Posted May 9, 2021 Author Posted May 9, 2021 Update 2021-05-09 Added: 6206 / 6206.dat Figure Feeding Bottle 10183 / 10183.dat Minifig Wings Fairy 11055 / 11055.dat Flag 2 x 2 Square[Thick Clips] 12618 / 12618.dat Minifig Armour Shoulder Pads with Six Spikes 17979 / 17979.dat Flag 5 x 6 Hexagonal with Thicker Clips 28424 / 28424.dat Minifig Police Hat with Hair Pulled Into Bun 47328 / 47328.dat Technic Bionicle Vahki Lower Leg Section 90109 / 90109.dat Tipper Bucket 8 x 12 x 4.667 92814 / 92814.dat Minifig Hat Square Academic Cap with Tassel 93230 / 93230.dat Minifig Hair Swept Back with Pointed Ears 98067 / 98067.dat Animal Dinosaur Lower Jaw Raptor 98387 / 98387.dat Animal Bunny Sitting Corrected: 24093 / 24093.dat Minifig Book Cover 32187 / 32187.dat Technic Transmission Driving Ring Extension 43750 / 43750.dat Serpent Neck S-Curve with Fixed Pin Rematched: 2528 / 2528a.dat Minifig Hat Bicorne 59275 / 59275a.dat Minifig Flipper Thin Importable: 2528.dat / 2528 ~Minifig Hat Bicorne (Obsolete) 35378.dat / 87552 =Panel 1 x 2 x 2 Reinforced 42135.dat / 32039 Technic Connector (Axle/Bush) Type 2 42924.dat / 6558 Technic Pin Long with Friction 44676b.dat / 44676 Flag 2 x 2 Trapezoid [Thick Clips] 44874.dat / 87082 Technic Pin Long with Pin Hole Type 2 59275.dat / 59275 ~Minifig Flipper Thin (Obsolete) Added Custom Parts: 21987 / 21987.dat Constraction Bar 15L with Axle Bush End 24531 / 2453b.dat Brick 1 x 1 x 5 with Solid Stud 32172 / 32172.dat Technic Connector Block 3 x 3 with Ball Socket 35470 / 35470.dat Plate 3 x 5 Cloud Shape with 3 Studs 35477 / 35477.dat Brick 1 x 3 x 1.333 with Rounded Ends 37704 / 37704.dat Sports Ball, Winged, Harry Potter Quidditch Golden Snitch 42205 / 42205.dat Door 1 x 6 x 6 Frame 42509 / 42509.dat Glass for Window 1 x 6 x 6 42924 / 42924.dat Technic Pin Long with Friction Type 2 445671 / 44567a.dat Hinge Plate 1 x 2 Locking with Groove with Single Finger On Side Vertical 46212 / 46212a.dat Brick 1 x 2 x 5 with Hollow Studs without Inner Ridges 47326 / 46326.dat ~Technic Connector 2 x 3 with Ball/Axle Socket with Rubber Insert 50665 / 50665.dat Minifig Helmet Classic with Thin Chin Guard Unbroken 51377 / 51377.dat Wheel Rim 14 x 18 with 8 Spokes 53075 / 53075.dat Animal Dog Dachshund 54661 / 54661.dat Hinge Brick 1 x 4 Locking Double, Two Finger End with 7 Teeth 55889 / 55889.dat Wheel 12 x 18 Smooth 61332 / 61332.dat Technic Pin with Friction Type 2 64454 / 64454.dat Container Box 3 x 8 x 6.667 - Back 64462 / 64462.dat Container Box 3 x 8 x 6.667 - Front 65132 / 65132.dat Hinge Bracket 4 x 5 x 5 Locking with 2 Fingers, Two on Each Side, 3 Teeth and 12 Studs on Back 65140 / 65140.dat Plate 8 x 8 with Rounded Corners 65304 / 65304.dat Technic Pin Long with Stop Bush Type 2 65417 / 65417.dat Boat Hull Floating 36 x 7 x 7 Bottom 65418 / 65418.dat Boat Hull Floating 36 x 7 x 7 Top 65676 / 65676.dat Roadsign Clip-on 2.2 x 2.667 Triangular (Thick C-Clip) 65753 / 65753.dat Minifig Skirt Straight Curved 0.55 Length 66155 / 66155.dat Wheel Rim 30 x 20 with 3 Dual Angled Spokes and 4L Hub 66252 / 66252.dat Plate 4 x 4 with Studs on Three Edges and 2 Clips Horizontal (Open C-Clips) 66787 / 66787.dat Cylinder Warp Pipe 7 x 7 x 3.333 66789 / 66789.dat Plate 6 x 6 x 0.667 with Rounded Corners with Studs on Edges without 4 Centre Studs 66790 / 66790.dat Plate 8 x 8 x 0.667 with Rounded Corners with 5 Vacant Stud Areas 66792 / 66792.dat Plate 4 x 4 x 0.667 with Rounded Corners with Studs on Edges 66855 / 66855.dat Plate 2 x 2 with Truncated Cube Extension 66857 / 66857.dat Tile 2 x 4 with Rounded Ends 66858 / 66858.dat Figure Feet 2 x 2 x 0.667 66859 / 66859.dat Figure Feet 2 x 3 x 0.667 66956 / 66956.dat Slope Brick Curved 2 x 2 with Double Cutout 67013 / 67013.dat Shell 4 x 4 x 1.333 with 2 x 2 Recess 67931 / 67931.dat Shell 4 x 4 x 1.333 with Spikes with 2 x 2 Recess 68211 / 68211.dat Bar 1 L with Three Prongs 69729 / 69729.dat Tile 2 x 6 69900 / 69900.dat Technic Chain Tread 38 Narrow with Central Divider 69944 / 69944.dat Minifig Sword Macuahuitl with Eight Blades 69958 / 69958.dat Plate 16 x 16 x 0.667 with Cutouts and Recessed Studs 70681 / 70681.dat Slope Brick Curved 1 x 3 with 1 x 2 Inverted Cutout 70695 / 70695.dat Tyre 26/ 49 x 30 Tractor 71752 / 71752.dat Brick 2 x 2 x 0.667 Ribbed Horizontally 71771 / 71771.dat Slope Brick Curved 5 x 8 x 0.667 without Studs 71772 / 71772.dat Plate 8 x 16 x 0.667 with Cutouts and Recessed Studs 72078 / 72078.dat Tile 1 x 1 x 0.5 with Raised Diamond Gem 72869 / 72869.dat Bar Tube with Clip Angled 90 Degrees 73109 / 73109.dat Technic Brick 1 x 2 with Plate 1 x 2 73230 / 73230.dat Technic Brick 1 x 1 with Axlehole 73682 / 73682.dat Brick 3 x 3 with Rounded Inverted Cutout and Rounded Corner 73825 / 73825.dat Bracket 1 x 1 - 1 x 2 Up 76798 / 76798.dat Panel 5 x 8 x 3.667 Curved with Two Axleholes 78267 / 78267.dat Sheet Plastic 5.3 x 20.3 Rectagular with 4 Tabs 983932 / 1010475.dat Figure Friends Medical Clipboard 983933 / 1010481.dat Figure Friends Medical Otoscope 983935 / 1010470.dat Figure Friends Medical Spoon 983936 / 1010462.dat Figure Friends Medical Feeding Bottle 983937 / 1010471.dat Figure Friends Medical Ice Pack 983938 / 1010482.dat Figure Friends Medical Nurse Hat 949001 / u9490c01.dat Minifig Cape Cloth Tattered and Pixelated (Formed) Corrected Custom Parts: 39739 / 39739.dat Tile 1 x 1 Heart Shape 42716 / 42716.dat Wheel Rim 20 x 30 "Torq Thurst" with 5 Spokes and External Ribs 54661 / 54661.dat Hinge Brick 1 x 4 Locking Double, Two Finger End with 7 Teeth 500181 / 50018a.dat Plate 1 x 1 Hexagonal with Studs on Both Sides and 3 Bars at 120 Degrees 500183 / 50018c.dat Bar with Perpendicular Hollow Stud and Bar Importable as Custom Part: 46212.dat / 46212 ~Brick 1 x 2 x 5 without Centre Studs (Obsolete) md5sum: ebf05a258d72a05cb18394db119320c2 Quote
SylvainLS Posted May 10, 2021 Author Posted May 10, 2021 Update 2021-05-10 Added Custom Parts: 21987 / 21987.dat Constraction Bar 15L with Axle Bush End 46891 / 46891.dat Technic Excavator Bucket 19 x 12 65128 / 65128.dat Container Lid 8 x 8 x 4.667 with Latches 983930 / 1010470.dat Figure Friends Medical Spoon md5sum: 35dd924f8f41917eb1cc0787bc401157 Quote
