Update 2021-06-22
Added:
  • 15553 / 15553.dat  Minifig Headdress Batgirl
  • 15851 / 15851.dat  Minifig Helmet Motorcycle with Open Face and Visor
  • 21700 / 21700.dat  Minifig Tool Screwdriver with  4 Prongs
  • 24067 / 24067.dat  Bundled Baby with Stud Holder on Back
  • 27385 / 27385.dat  Minifig Hair Mohawk Wide
  • 30131 / 30131.dat  Tree 6 x 6 Hollow Stump
  • 62386 / 62386.dat  Constraction Foot  3 x  6 x  2.333 with Squared Ball Socket
Importable:
  • 67692.dat / 22484  =Bar  2L with Ball Joint-8
Added Custom Parts:
  • 36452 / 36452.dat  Minifig Neck Bracket with 4 Angled Handles
Corrected Custom Parts:
  • 36840 / 36840.dat  Bracket  1 x  1 -  1 x  1 Up
  • 500182 / 50018b.dat  Minifig Tool Impact Wrench with Opposing Studs with Angled Ribbed Handle and Rear Bar Handle
md5sum: 2c11b1a43da1373c8d147ddfc470d8a9
  • Replies 325
Posted Images
Update 2021-07-11
Added:
  • 11777 / 11777.dat  Animal Eagle Wing Right
  • 11778 / 11778.dat  Animal Eagle Wing Left
  • 13785 / 13785.dat  Minifig Hair with Ponytail and Fringe
  • 15503 / 15503.dat  Minifigure Hair Female Beehive Style with Sideways Fringe
  • 23922 / 23922.dat  Weapon Gun / Blaster / Shooter / Fire Nozzle Mini with Socket Joint-8 with Friction Centre
  • 26078 / 26078.dat  Animal Dog Terrier
  • 98130 / 98130.dat  Minifig Kendo Mask
  • 98566 / 98566.dat  Technic Weapon Hexagon Shield
Corrected:
  • 11467 / 11467.dat  Animal Eagle Body (Complete)
  • 93575 / 93575.dat  Constraction Hand Clenched with Four Fingers and Axle Hole
Rematched:
  • 4237 / 4237.dat  Container  4 x  6 x  2.333 Crate
Importable:
  • u516.dat / 4237  ~Moved to 4237
md5sum: 950f89cf330055b43559d30550761296
2021-07-14 Toothpaste Fire
Remember that many of the new Custom decors can be converted with lxf2ldr and lxf2ldr.html :wink:
Corrected:
  • 90370 / 90370.dat  Minifig Microphone
Added Custom Assemblies:
  • 65151 / 65151-f2.dat  Technic Shock Absorber 11L Soft
  • 87857 / 87857.dat  Minifig Hips and Legs Long
Added Custom Parts:
  • 2451 / 245c01.dat  Train Wheel 4 Studs with Conical Rim with Stub Axle
  • 3500 / 35.dat  Wheel  8 x 35 with 12 Spokes (Complete)
  • 3600 / 36.dat  Tyre Large
  • 4470 / 447c01.dat  Train Wheel 4 Studs with Traction Teeth with Stub Axle
  • 4143 / 4143.dat  Technic Gear 14 Tooth Bevel
  • 5690 / 569.dat  Technic Gear  9 Large Tooth
  • 5740 / 574.dat  Tyre 10/130 x 17 Offset Tread for Technic Gear 9 Tooth
  • 7039 / 7039.dat  Wheel Rim  8 x 18 with 4 Studs and Cylindrical Axle
  • 7049 / 7049b.dat  Brick  2 x  4 with 4 Red Axle Bushes and Trans-Clear Underside
  • 9131 / u9131.dat  Tyre  7.2/ 45 x 8.8
  • 9237 / u9237.dat  ~Wheel Rim  8 x 35 with 12 Studs
  • 24300 / 243c01.dat  Train Wheel Spoked with Cylindrical Rim with Stub Axle
  • 24400 / 244c01.dat  Train Wheel Spoked with Conical Rim with Stub Axle
  • 24541 / 2454a.dat  Brick  1 x  2 x  5 with Hollow Studs and Asymmetric Inner Ridges
  • 28738 / 28738.dat  Electric Powered Up Hub
  • 34337 / 34337.dat  Wheel Rim  6.4 x  8 with Slot
  • 35394 / 35394.dat  Dish  4 x  4 Inverted with Hollow Stud
  • 37091 / 3709a.dat  Brick  2 x  4 with Top/Side/End Holes and Hollow Studs
  • 37092 / 3709c.dat  Brick  2 x  4 with Top/Side/End Holes and Solid Studs
  • 38339 / 38339.dat  Train Wheel Bogie With Pin Slots without Wheelset
  • 38340 / 38340.dat  Train Wheel with Pin for Wheel Bogie
  • 40341 / 40341.dat  Technic Bionicle Weapon Circular Saw with Axle 6L
  • 45800 / 458c01.dat  Tyre for Electric Train 12V Motor Conically Deformed
  • 45801 / 458.dat  Tyre for Train Wheel for Electric Train Motor 12V
  • 49612 / 49612.dat  Brick  4 x  4 x  2.667 Round Corner with Dome Top
  • 50340 / 50340.dat  Hinge Plate  1 x  2 Locking 7-Position with Dual Finger on Side
  • 65138 / 65138.dat  Brick  4 x  4 x  0.667  with Rounded Top and Four Top Studs
  • 65803 / 65803.dat  Technic Brick 16 x 16 x  1.333
  • 65817 / 65817.dat  Technic Beam 15 x 11 with Perforated Center Plate 13 x  9
  • 67759 / 67759.dat  Windscreen  6 x 14 x  6 with Conical Sides
  • 68325 / 68325.dat  Brick  4 x  4 Round with  3 x  3 Recess with Hole and Snapstud
  • 68888 / 68888.dat  Bar  1L Quadruple with  1L Axlehole Hub
  • 72008 / 72008.dat  Technic Connector Block  2 x  2 with  1 x  1 Cutout
  • 72206 / 72206p01.dat  Wheel 11 x 24 with Integral Rubber Black Tyre
  • 73111 / 73111.dat  Brick  3 x  3 x  2 Round with Recessed Centre
  • 76795 / 76795.dat  Brick  5 x  5 Corner Round with Slope 45 Chamfer
  • 76796 / 76796.dat  Windscreen  4 x  6 x  1.333 Curved Open
  • 76797 / 76797.dat  Brick  3 x  3 x  1 Quarter Circle with Curved Top
  • 77180 / 77180.dat  Slope 10 x  2 x  2 Curved with Rounded Corner - Left
  • 77182 / 77182.dat  Slope 10 x  2 x  2 Curved with Rounded Corner - Right
  • 78256 / 78256.dat  Plate  1 x  2 with Clip Vertical on End
  • 78258 / 78258.dat  Bar  2L with Thick Stop and Pin Holes
  • 78329 / 78329.dat  Plate  1 x  5
  • 78443 / 78443.dat  Wing  2 x  6 Left
  • 78444 / 78444.dat  Wing  2 x  6 Right
  • 78886 / 78886.dat  Slope Brick 65  2 x  2 x  2 Double Convex with Cant
  • 79389 / 79389.dat  Bracket  1 x  1 -  2 x  1 Down
  • 373410 / 37341d.dat  Minifig Scythe with Bar and Cross Hatched Grip
  • 373411 / 37341a.dat  Minifig Sword with Curved Blade and Reinforced Guard with Bar
  • 373412 / 37341b.dat  Minifig Weapon Knife Curved  1.6 L Blade with Cross Hatched Grip
  • 373413 / 37341c.dat  Minifig Sword Katana  3.5 L with Short Smooth Grip and Square Crossguard
  • 373415 / 37341e.dat  Minifig Weapon Hook with Double Blades
  • 722101 / 72210a.dat  Wheel Rim 11 x 24 Front with  5 Spokes
Importable Custom Parts:
  • 34.dat / 7049  ~Moved to 7049
  • 7049.dat / 7049  ~Moved to 7049b
md5sum: 623051426acaeab3cc8fadc934a238d5
Edited by SylvainLS
Update 2021-08-29
Added:
  • 11641 / 11641.dat  Sports Basketball Net with Axle
  • 18396 / 18396.dat  Constraction Flame
  • 24782 / 24782.dat  Minifigure Skirt Wavy
  • 92084 / 92084.dat  Animal Owl with Angular Feathers
Re-matched:
  • 44676 / 44676a.dat  Flag  2 x  2 Trapezoid (Thin C-Clip)
Importable:
  • 44676.dat / 44676  ~Moved to 44676a
Corrected Custom part:
  • 66252 / 66252.dat  Plate 4 x 4 with Studs on Three Edges and 2 Clips Horizontal (Open C-Clips)
md5sum: 96aba754c2c795fe1b1dc691af9ab6d4
Update 2021-09-11
Added:
  • 11538 / 11538.dat  Minifig Helmet with Cheek Protectors and Communicator
Corrected:
  • 87568 / 87568.dat  Minifig Mechanical Arm Bent with Clips at 90 Degrees
Rematched:
  • 60583 / 60583b.dat  Brick  1 x  1 x  3 with Two Clips Vertical and Hollow Stud
Importable:
  • 30389c.dat / 30389  Hinge Brick  2 x  2 Locking with Axlehole Type 2 and Single Finger
  • 60583.dat / 60583  ~Moved to 60583a
  • 60583a.dat / 60583  Brick  1 x  1 x  3 with Two Clips Vertical and Solid Stud
  • 37364 / 37364.dat  Minifig Hips and Legs Medium
  • 43370 / 43370.dat  Minifig Torso with Arm Locking Notches
  • 67908 / x67908x.dat  Figure Arm with Friction Pin with Minifig Hand
Added Custom Parts:
  • 2630 / 263.dat  Train Steam Cylinder  2 x  2 x  1.667 Sloped
  • 2641 / 2641a.dat  Support Crane Stand Single with Curved Join
  • 29580 / 29580.dat  Minifig Headdress Rocket Costume
  • 30489 / 30489.dat  Brick 16 x  8 Sports Field Section
  • 30492 / 30492.dat  Brick  8 x  8 Sports Field Section
  • 32643 / 32643.dat  Energy Effect Blast with Bar
  • 36017 / 36017.dat  Minifig Weapon Sword Hilt with Dragon Head
  • 36451 / 36451a.dat  Rock Infinity Stone
  • 41672 / 41672.dat  Technic Beam  1 x  3 x  7 with 4 Axleholes and 3 Holes
  • 41732 / 41732.dat  Technic Pin Joiner Round with Slot, Bar and Pivot
  • 44773 / 44773.dat  Car Track 24 x  16 x  2 V-Branching
  • 45522 / 45522.dat  Tile  6 x  6 x 2/3 with 4 Studs and Card-holder - "SPORTS"
  • 53126 / 53126.dat  Minifig Hair Put Up with Braids
  • 53475 / 53475.dat  Technic Flex-System Hose 26L (520LDU)
  • 64865 / 2714b.dat  Bar  8L with Stop Ring and Pin - Flat End
  • 65249 / 65249.dat  Technic Axle Pin Long without Friction with 2L Axle
  • 65826 / 65826.dat  Technic Axle Pin 1/2 with Stud Tube
  • 66955 / 66955.dat  Slope Brick Curved  4 x  3.5 x  1 Double Stepped
  • 67644 / 67644.dat  ~Figure Lower Body  2 x  2 x  1.667 with Four Hollow Studs and Two Pegholes
  • 67650 / 69061.dat  Minifig Head Minion  2 x  2 x  2.333 - with Goggles
  • 67887 / 67887.dat  Minifig Head Pig
  • 67950 / 67950.dat  Cylinder Half  3 x  6 x  6 Dome Top with  2 Hollow Studs
  • 68986 / 68986.dat  Minifig Head Minion  2 x  2 x  1.333 with Goggles
  • 69073 / 69101.dat  Minifig Head Minion  2 x  2 x  1.667 with Mono-Goggles
  • 70688 / 70688.dat  Technic Flex-System Hose 27L (540LDU)
  • 73507 / 73507.dat  Technic Beam 11 with Alternating Holes
  • 74169 / 74169.dat  Tile  2 x  2 x  0.667 with Two Offset Round Extensions
  • 74611 / 74611.dat  Plate  8 x  8 Round with Hole and Snapstud
  • 76776 / 76776.dat  Brick 5 x 5 x 3.333 Corner Round with Dome Top and  2 x  2 Cutout
  • 78257 / 78257.dat  Plate  1 x  1 with Handles on Opposite Ends
  • 78522 / 78522.dat  Slope Brick Curved  6 x  4 Double
  • 78594 / 78594.dat  Panel Wall  2 x  2 x  5 Corner Faceted
  • 79393 / 79393.dat  Tile  3 x  3 Corner Round
Corrected Custom Part:
Rematched Custom Part:
  • 9237 / 715.dat  Wheel Rim  8 x 35 with 12 Studs with Axle (Complete)
Importable as Custom Part:
  • 2641.dat / 2641  ~Moved to 2641a
md5sum: a9a8240fc993fcf4d2b71c39e3c321a0
Edited by Calabar
Missing link added
Update 2021-10-23
Added:
  • 15424 / 15424.dat  Minifig Hat Cowboy Type 2
  • 59362 / 59362.dat  Minifig Hair Short with Curled Ends
  • 92745 / 92745.dat  Minifig Headdress SW Togruta Montrals
Corrected:
  • 43746 / 43746.dat  Animal Serpent Basilisk Head  (new version)
Added Custom Part:
  • 46534 / 46534.dat  Minifig Helmet with Ear Antenna
  • 68881 / 68881.dat  Brick  10 x  5 x  2.667 Semi Circle with Curved Top
  • 77765 / 77765.dat  Technic Pin Long with End Stop
md5sum: ce4932ec34828b083fb3390ed7bd7254
Update 2021-12-13
Added:
  • 12899 / 12899.dat  Minifig Helmet Sport with Front Handle
  • 18904 / 18904.dat  Animal Crocodile  4 x  9 Body
  • 18905 / 18905.dat  Animal Crocodile  4 x  9 Head
  • 18906 / 18906.dat  Animal Crocodile  4 x  9 Tail
  • 27186 / 27186.dat  Minifig Hair with Large High Bun
  • 46304 / 46304.dat  Minifig Helmet Snow Goggles
  • 87781 / 87781.dat  Minifig Helmet Space with Front Handle
Rematched (renamed in LDraw):
  • 6190 / 6190a.dat  Bar  1 x  3 with Stud Connectors
  • 30348 / 71613.dat  Electric Light and Sound Brick  4 x 12 x  2 Laser Drill
Importable:
  • 6190.dat / 6190  Bar  1 x  3
  • 30346c01.dat / 30348  ~Moved to 71613
  • 13770.dat / 28920  =Tap  1 x  2 with Two Valves with Short Handles
Added Custom Parts:
  • 41835 / 41835.dat  Animal Bird Small
Rematched Custom Parts (renamed in LDraw):
  • 983930 / 98393j.dat  Figure Friends Medical Pen
  • 983932 / 98393b.dat  Figure Friends Medical Clipboard
  • 983933 / 98393c.dat  Figure Friends Medical Otoscope
  • 983935 / 98393e.dat  Figure Friends Medical Spoon
  • 983936 / 98393f.dat  Figure Friends Medical Feeding Bottle
  • 983937 / 98393g.dat  Figure Friends Medical Ice Pack
  • 983938 / 98393h.dat  Figure Friends Medical Nurse Hat
md5sum: 329d59449d7541ee112f9bdb382b6735
  • 2 months later...
Update 2022-02-16
Added:
  • 19732 / 19732.dat  Minifig Legs Minecraft Enderman
  • 18394 / 18394.dat  Wave / Flame Rounded Wing Shaped with Bar 0.5L
  • 24629 / 24629.dat  Minifig Head Mouse
  • 24634 / 24634.dat  Minifig Hair Decoration Bow Large with Pin
  • 24635 / 24635.dat  Minifig Hat Sailor with Ribbon and Pin
  • 30085 / 30085.dat  Animal Sawfish Head
  • 85961 / 85961.dat  Minifig Armour Breastplate with Back Stud
  • 95120 / 95120.dat  Hinge Tile  1 x  4 Locking with 2 Single Fingers on Top with Double Locks
  • 99244 / 99244.dat  Minifig Headdress Rabbit
Rematched:
  • 4790 / 4790a.dat  Boat Ship Wheel
  • 6217 / 6217a.dat  Arm Piece with Pin with Friction and 3 Fingers
  • 6575 / 6575b.dat  Technic Cam with Wide Slit
  • 28974 / 28974a.dat  Bracket  1 x  1 -  1 x  1 Thick with Stud Hole  (new version)
Importable:
  • 3940a.dat / 3940  Support  2 x  2 x  2 Round with Blind Hole
  • 4790.dat / 4790  ~Moved to 4790a
  • 4790b.dat / 4790  Boat Ship Wheel with Slotted Pin
  • 6217.dat / 6217  ~Moved to 6217a
  • 6217b.dat / 6217  Arm Piece with Pin with Friction and 3 Fingers with Ribs
  • 6575.dat / 6575  ~Moved to 6575a
  • 6575a.dat / 6575  Technic Cam with Narrow Slit and Recessed Axlehole
  • 28974.dat / 28974  ~Bracket  1 x  1 -  1 x  1 Thick with Stud Hole (Obsolete)
  • 32064c.dat / 32064  Technic Brick  1 x  2 with Axlehole with Open Sides and Bottom Stud
  • 32064d.dat / 32064  Technic Brick  1 x  2 with Semi-Reduced Axlehole
  • 50945.dat / 50951  =Tyre  6/ 30 x 11
Added Assembly:
  • 76407  Minifig Stand (30491+30488)
Added Custom Assembly:
  • 47592  Electric Powered Up LED Matrix
Added Custom Parts:
  • 18591 / 18591.dat  Windscreen  4 x  4 x  5 Cone with Pins
  • 22167 / 22167.dat  Electric Powered Up 2 Port Battery Box
  • 30635 / 30635.dat  Hose Reel  1 x  4 x  1.667 Drum
  • 30636 / 30636.dat  Hose Reel  1 x  4 x  1.667 Holder with Two Pins
  • 30690 / 3069a.dat  Tile  1 x  2 without Groove
  • 30700 / 3070a.dat  Tile  1 x  1 without Groove
  • 31794 / 31794.dat  Technic Suspension Arm  1 x  5 Type 2
  • 32577 / 32577.dat  Technic Bionicle Torso  1 x  5 x  2 with  3 Pins and  6 Pegholes
  • 35699 / 35699.dat  Minifig Hair Smooth with Spiked Bangs
  • 41612 / 41612.dat  Minifig Hair Long and Straight Parted in the Middle
  • 48298 / 48298.dat  Net  6 x  1 x  5 Soccer Goal Side
  • 49661 / 49661.dat  Animal Duckling
  • 65768 / 65768.dat  Propeller  3 Blade  3.5 Diameter with Technic Peghole
  • 65783 / 65783.dat  Panel 10 x  4 x 13 Curved Tapered with Handle at Each End and  4 Studs On Side
  • 67351 / 67351.dat  Electric Powered Up 2 Port Hub with Yellow Bottom without Rechargeable Battery
  • 69819 / 69819.dat  Technic Cross Block 2 x 2 Split Reinforced (Axle/Twin Pin)
  • 69858 / 69858.dat  Minifig Flame  4L
  • 69910 / 69910.dat  Technic Chain Tread 7 Wide with Cleat
  • 70490 / 70490.dat  Tyre 14/ 68 x 30
  • 72024 / 72024.dat  Container  8 x  8 x  3 Cupcake
  • 73110 / 73110.dat  Plate  6 x  6 with Five Pin Holes
  • 73117 / 73117.dat  Minifig Candelabra with  3 Arms
  • 73878 / 73878.dat  Window Round Corner  3 x  3 x  2
  • 75538 / 75538.dat  Slope Concave 8 x  8 x  4 with  1 x  6 Plate
  • 75539 / 75539.dat  Slope  5 x  8 x  0.667 with  2 x  6 Plate
  • 75972 / 75972.dat  Electric Code Pilot with Code Pilot and Button Description Pattern with Battery Cover
  • 77590 / 77590.dat  Technic Steering Constant Velocity 8mm Joint Male with Sliding Axle Hole 3.5L
  • 77808 / 77808.dat  Brick  1 x  2 with Rounded Ends and Central Bars
  • 78442 / 78442.dat  Technic Gear Ring Quarter  6 x  6 with 15 Teeth
  • 78666 / 78666.dat  Arch  1 x 2  x  1 Inverted
  • 79387 / 79387.dat  Plate 4 x 4 x 0.667 with Rounded Corners with Studs on Edges and  2 x  2 Centre Cutout
  • 79491 / 79491.dat  Plate  2 x  2 Corner Round
  • 79730 / 79730.dat  Door  1 x  4 x  6 with 6 Panes, Handle and Hole for Pet Flap
  • 79743 / 79743.dat  Minifig Food Cupcake
  • 79756 / 79756.dat  Brick  1 x  4 x  0.667 with Curved Top
  • 79846 / 79846.dat  Plate  2 x  6 Angled 135 Degrees with Centre Hole
  • 79850 / 79850.dat  Brick  4 x  4 x  1  Round with Rounded Top and Round  2 x  2 x 0.667 Cutout
  • 79851 / 79851.dat  Ring  7 x  7 with 2 Axle Holes
  • 80267 / 80267.dat  Technic Panel Fairing Smooth #61 (Wide Medium Parallelogram)
  • 80268 / 80268.dat  Technic Panel Fairing Smooth #60 (Wide Medium Parallelogram)
  • 80286 / 80286.dat  Technic Beam  2 x  5 Liftarm Bent 90 Quarter Ellipse
  • 86996 / 86996.dat  Plate  1 x  1 x  0.667
md5sum: 0c48460464d533af3d0662f4b19c3a4e
Update 2022-02-20 is it 22h02min20.22s?
Rematched:
  • 28974 / 28974.dat  Bracket  1 x  1 -  1 x  1 Thick with Stud Hole
Added Custom Parts:
  • 30211 / 30211.dat  Support Insectoid Leg Small
  • 41893 / 41893.dat  Tyre 36/ 36 x 43 H Off-Road
  • 42090 / 42090.dat  Animal Monkey Curved Tail Large
  • 46189 / 46189.dat  Technic Connector  3 x  1 x  2 with Peghole and Two Pins (Perpendicular Slits)
  • 46537 / 46537.dat  Technic Competition Arrow with Solid Shaft and Cross Shaped Rubber Black Tip
  • 49743 / 49743.dat  Spring Shooter  2 x  6 x  1.333 with Dark Bluish Grey Bottom
  • 53118 / 53118.dat  Minifig Video Game Controller
  • 53923 / 53923.dat  Hinge Arm Locking with Single Finger and Axlehole without Slots
  • 57360 / 57360.dat  Hinge Arm Locking with Dual Finger with 7 Fingers and Semi-Reduced Axlehole without Slots
  • 57697 / 57697.dat  Hinge Arm Locking with Single Finger and Friction Pin with Rectangular Centre Hole
  • 65489 / 65489.dat  Technic Cross Block 1 x 3 (Pin/Pin/Pin) with 4 Pins Rectangular Centre Hole
  • 67338 / 67338.dat  Minifig Food Croissant with Square Ends
  • 67928 / 67928.dat  Animal Wing  2 x  2.5 Feathered with Five Rounded Feathers with 0.5L Bar - Half
  • 69636 / 69636.dat  Technic Steering Wheel Bearing with  4 Pegholes and Shock Absorber Socket
  • 71711 / 71711.dat  Technic Brake Disc  9 x  9 with Light Bluish Grey Rim
  • 72046 / 72046.dat  Tile  1 x  1 x  0.5 Round with Raised Star Gem
  • 79505 / 79505.dat  Technic Rotation Joint Disk with Pin and  2 Perpendicular Click Rotation Ring Sockets
  • 79987 / 79987.dat  Plate  1 x  3 with  2 Clips on Top (Thick C-Clip)
  • 89678 / 89678.dat  Technic Friction Pin  1/2
  • 89681 / 89681.dat  Plate  6 x  4 x  0.667 with Rounded Corners
  • 46224 / 46224c01.dat  Technic Gearbox  2 x  4 x  4 (Complete)
  • 67498 / 67498-f1.dat  Technic Shock Absorber 18L (Extended)
md5sum:  f48d56654c8ecedc3ffd5e48b963f05f
Update 2022-03-03
Added Part:
  • 11575 / 11575.dat  Animal Poodle
Corrected Part:
  • 32476 / 32476.dat  Constraction Limb  4 x  7 Bent 45 with Ball Joint and Opposing Axleholes
Added Custom Parts:
  • 27965 / 27965.dat  Cable Flexible 22L with  2 Bar Connectors
  • 30680 / 3068a.dat  Tile  2 x  2 without Groove
  • 44553 / 44553.dat  Minifig Hat Tall Hat with Small Brim and Pin
  • 45275 / 45275.dat  Technic Shield  5 x  5 with Circular Grinder
  • 53500 / 53500.dat  Electric Constraction Eyes  4.5 x  2 x  1.5 Light-Up
  • 65834 / 65834p01.dat  Wheel 14 x 35 with 4 Spokes with Integral Medium Azure Tyre
  • 69778 / 69778.dat  Technic Gear 20 Tooth
  • 69779 / 69779.dat  Technic Gear 20 Tooth
  • 71720 / 71720.dat  Wheel 24 x 107 Motorcycle with  6 Spokes
  • 71721 / 71721.dat  Tyre 27/ 48 x 107 Motorcycle with Racing Tread
  • 71722 / 71722.dat  Tyre 37/ 38 x 107 Motorcycle with Racing Tread
  • 75544 / 75544.dat  Technic Windscreen 11 x 11 Motorcycle with Angled Pegholes
  • 76110 / 76110.dat  Technic Competition Arrow (Complete)
  • 77813 / 77813.dat  Tile 1 x 1 Round with Groove and Handle
  • 80796 / 80796.dat  Brick  1 x  2 x  1.667 with Studs on 2 Opposite Sides
  • 86876 / 86876.dat  Brick  1 x  2 with Centred Stud on Long Side
  • 43097 / 43097-f1.dat  Technic Linear Actuator  8 x  2 x  2 Type 2 (Contracted)
  • 62233 / 62233-f1.dat  Constraction Ball Cannon  (needs part 60932c01.dat that can’t be submitted to LDraw)
  • 27448 / 27448.dat  Turntable Flat Base  2 x  2
md5usm: 4b30c99ccf63f6c4d7ad5d5bb25415ce
Edited by SylvainLS
Update 2022-03-11
Corrected typos.
Corrected:
  • 30377 / 30377.dat  Minifig Mechanical Arm with Clips Parallel
  • 65578 / 65578.dat  Plate  1 x  1 Round with Angled Bar
  • 93609 / 93609.dat  Arm Skeleton with Horizontal Clip Bent 56.31
Rematched:
  • 3049 / 3049d.dat  Slope Brick 45  1 x  2 Double / Inverted with Bottom Stud Holder
  • 10498 / 90641.dat  Technic Constraction Shell  3L Flat
Importable:
  • 4092a.dat / 4025  Train Bogie Plate with Long Pin
  • 6069.dat / 48933  Wedge  4 x  4 Triple
  • 10498.dat / 10498  =Technic Constraction Shell  3L Flat
  • 10830.dat / 10830  Minifig Tool Magnifying Glass with Thick Frame and Lens
  • 16175.dat / 16175  Minifig Construction Helmet with Hair Short
  • 18835.dat / 18835  ~Minifig Hair Mid-Length Straight with Crown
  • 23999.dat / 23999  Boat Hull Floating 40 x 12
  • 25126.dat / 25126  Minifig Baby Body
  • 30483.dat / 30483  Minifig Head Wookiee with Bandolier
  • 47545.dat / 47545  Minifig Head Rodian without Pattern
  • 53914.dat / 30388  Hinge Brick  1 x  6 Locking Double, Two Finger End with  7 Teeth
  • 54671.dat / 30365  Hinge Brick  1 x  2 Locking with Dual Finger On End,  7 Teeth
  • 54672.dat / 30540  Hinge Brick  1 x  2 Locking with Dual Finger on End Horizontal,  7 Teeth
  • 73092.dat / 73092  ~_Magnet Cylindrical in Casing Black (Obsolete)
  • 87561.dat / 87561  Block  6 x  4 x  1 with Handles and Minifig Pattern
  • 90391p01.dat / 90391  Minifig Pike / Spear Elaborate With Flat Metallic Head
md5sum: c23e5c8ac2930b04d87567172c0ec74a
Update 2022-05-05
Added:
  • 15504 / 15504.dat  Minifig Tail Cat
  • 15627 / 15627.dat  Panel  1 x  6 x  6 with  4 x  2 Window Cutout
  • 15864 / 15864c01.dat  Minifig Helmet Large Square with Side Extensions
  • 18395 / 18395.dat  Flame  5L Curved with Bar 0.5L and Triangular Base
  • 20592 / 20592.dat  Minifig Hair Mid-Length Flipped Ends with Cat Ears
  • 28145 / 28145.dat  Minifig Hair Wavy Parted with Large Thick Glasses
  • 88618 / 88618c01.dat  Animal Ostrich
  • 99250 / 99250.dat  Minifig Neckwear Ribbon with Medal
Rematched:
  • 25893 / 25893a.dat  Plate  1 x  1 Round with Bar Handle on Short Stem
Importable:
  • 25893.dat / 25893  ~Plate  1 x  1 Round with Horizontal Handle Below (Obsolete)
Added Custom part:
  • 49492 / 49492.dat  Minifig Shepperd Crook
Rematched Custom part:
  • 22969 / 22969a.dat  Wheel 56 x 46 Technic Racing
Importable as Custom part:
  • 22969.dat / 22969  ~Wheel 56 x 46 Technic Racing (Obsolete)
md5sum: 4c874725e68af4438beab65c409a0fc1
  • 3 months later...
Update 2022-08-05
Added:
  • 6078 / 6078.dat  Door 1 x 4 x 3
  • 11601 / 11601.dat  Minifig Blade with Bar Handle and Spike
  • 17018 / 17018.dat  Minifig Helmet Wolverine
  • 18923 / 18923.dat  Car Base  8 x 16 x  2 with  4 x 14 Recessed Center with Mudguards
  • 26045 / 26045.dat  Minifig Hat Bear Costume with Ears
  • 51642 / 51642.dat  Minifig Weapon Staff Onewa
  • 51644 / 51644.dat  Minifig Weapon Staff Matau
  • 51645 / 51645.dat  Minifig Weapon Staff Vakama
  • 60674 / 60674.dat  CLUB, ASSEMBLED (Needs Work)
  • 88291 / 88291.dat  Animal Camel?
  • 92754 / 92754.dat  Minifig Body Dug Arm
  • 92755 / 92755.dat  Minifig Body Dug without Arm
Rematched:
  • 24314 / 24314p01.dat  Wheel Minifig Wheelchair with Integral Black Tyre
  • 25126 / 25128p01.dat  Minifig Baby Body with Yellow Hands Pattern
  • 30157 / 30157b.dat  Plate  2 x  4 with Flattened Pins
Corrected:
  • 51663 / 51663.dat  Minifig Weapon Staff Whenua
  • 64390 / 64390.dat  Door  1 x  4 x  6 with Window and Reinforced Edge
  • 65128 / 65128.dat  Container Lid  8 x  8 x  4.667 with Latches
Importable:
  • 3023a.dat / 3023  Plate  1 x  2 with Frat Pin
  • 24314.dat / 24314  ~Moved to 24314p01
  • 25126.dat / 25126  ~Moved to 25128
  • 25128.dat / 25126  Minifig Baby Body
  • 30157.dat / 30157  ~Moved to 30157
  • 30157a.dat / 30157  Plate  2 x  4 with Rounded Pins
Added Custom parts:
  • 1126 / 1126.dat Tile  1 x  2 with Rounded Ends
  • 1566 / 1566.dat  Plant with Bar and Off-Shoot with Hollow Stud
  • 1762 / 1762.dat  Slope Brick 33  2 x  2 Double, Curved
  • 1881 / 1881.dat  Figure Arm Bent with Large Hand with Clip and Friction Pin
  • 2310 / 2310.dat  Slope Brick 45  2 x  1 Inverted with 0.667 cutout
  • 3947 / 3947.dat  Baseplate 32 x 32 with Craters
  • 6221 / 6221.dat  Technic Handle
  • 18922 / 18922.dat  Plate  8 x 16 x  0.667
  • 33464 / 33464.dat  Minifig Baby Head with Neck
  • 35386 / 35386.dat  =Tile  1 x  2 with Groove
  • 40687 / 40687.dat  Plate  2 x  4 with Reinforced Flatened Pins
  • 40933 / 40933.dat  Animal Dragon Head Jaw Upper
  • 40934 / 40934.dat  Animal Dragon Head Jaw Lower
  • 41202 / 41202.dat  Minifig Armour Shoulder Pads with Snake Heads and Stud on Back
  • 47976 / 47976.dat  Brick 12 x 12 with 3 Pin Holes on Sides and Support Pins in Corners
  • 49588 / 49588.dat  Minifig Head Snake Closed Mouth
  • 49649 / 49649.dat  Minifig Shopping Cart Frame
  • 50015 / 50015.dat  Tricycle Frame (Needs Work)
  • 51149 / 51149.dat  Technic Transmission Changeover Catch Type 2
  • 53540 / 53540.dat  Brick  1 x  2 with  2 Pins with Squared Centre Hole
  • 54657 / 54657.dat  Hinge Plate  1 x  2 Locking with Dual Finger on End Vertical, 7 Teeth
  • 54671 / 54671.dat  Hinge Brick  1 x  2 Locking with Dual Finger on End Vertical,  7 Teeth
  • 54672 / 54672.dat  Hinge Brick  1 x  2 Locking with Dual Finger on End Horizontal,  7 Teeth
  • 58101 / 58101.dat  Figure Legs Mario
  • 64954 / 64954.dat  Trailer Base  6 x 16 x  2.333
  • 65129 / 65129.dat  Container  8 x  8 x  2 with Rounded Corners and Slots for 16 Tiles
  • 65146 / 65146.dat  Turntable  2 x  2 with Four Snapping Clips
  • 66788 / 66788.dat  Figure Arm Bent Long with Clip and Friction Pin
  • 67017 / 67017.dat  Figure Cap on Brick  2 x  2 with Flat Bill
  • 67491 / 67491.dat  Technic Beam 19 x  3 with Three Open Areas  5 x  1
  • 67695 / 67695.dat  Constraction Connector  3 x  2 with Single Round Ball Socket with Straight Closed Sides
  • 67696 / 67696.dat  Brick  2 x  2 with Axlehole and Ball Socket with Straight Closed Sides
  • 69984 / 69984.dat  Plate  6 x  6 Hexagonal with Six Spokes and Clips (Solid Studs)
  • 70646 / 70646.dat  Ladder  2.5 x 16 with Three  2 x  2 Studs
  • 73304 / 73304.dat  Power Burst Stand  5 x  5 x  0.667 with  2 Studs
  • 73562 / 73562.dat  Bracket  3 x  2 x  1.333 with Bottom Stud Holder
  • 73642 / 73642.dat  Windscreen 14 x 14 x  4 Semicircle
  • 73832 / 73832.dat  Plate  8 x  4 x  0.667 with Rounded Corners with 2 Vacant Stud Areas with Cutout
  • 77598 / 77598.dat  Plate  2 x  2 x  0.667 with Wheel Fork
  • 79194 / 79194.dat  Plate  1 x  1 Round with Bar Handle on Long Stem
  • 79757 / 79757.dat  Brick  2 x  2 x  0.667 Corner with Curved Top
  • 80015 / 80015.dat  Plate  5 x  5 with  4 x  4 Corner Round and  4 x  4 with  3 x  3 Corner Round Cutout
  • 80177 / 80177.dat  Slope Brick Curved  3 x  2 with Cutout Left
  • 80178 / 80178.dat  Slope Brick Curved  3 x  2 with Cutout Right
  • 80271 / 80271.dat  Technic Panel Bent  4 x  5 x  5 Tapered Left #70
  • 80272 / 80272.dat  Technic Panel Bent  4 x  5 x  5 Tapered Right #71
  • 80284 / 80284.dat  Technic Panel 13 x 2 x 5 Mudguard Arched with Rounded Top and Pointed Bottom
  • 80285 / 80285.dat  Technic Panel  3 x 2 x 5
  • 80324 / 80324.dat  Flag  2 x  2 Trapezoid with Flared Edge
  • 80336 / 80336.dat  Figure Friends Skirt Long Full Octagonal
  • 80431 / 80431.dat  Technic Brick  1 x  2 x  1.333 with Hole and Rotation Joint Socket
  • 80519 / 80519.dat  Wave / Flame 3.5L with Clip
  • 80542 / 80542.dat  Tyre 20 / 33 x 62 Motorcycle
  • 80545 / 80545.dat  Slope Brick 45  2 x  4 x  1.333 Double, Wedge
  • 80679 / 80679.dat  Animal Squirrel Standing
  • 84772 / 84772.dat  Wheel 20 x 62 Motorcycle Solid
  • 84868 / 84868.dat  Bar  2L T-shaped with Two Bar Holes and Bottom Tube
  • 85834 / 85834.dat  Brick  4 x  5 x  1.667 with Domed Top and Tapered Sides
  • 89679 / 89679.dat  Technic Panel Curved  1 x  2 x  1
  • 722102 / 72210b.dat  Wheel Rim 11 x 24 Front with  9 Spokes
  • 12799 / 12799.dat  Technic Motor Pull Back  6 x  5 x  3 (Complete)
  • 24689 / 88618c01.dat  Animal Ostrich
  • 84133 / 84133.dat  Minifig Hips and Legs with Spring Prosthetic Leg Left
  • 49242 / 49242p01.dat  Electric Hub Mario with Reddish Brown Hair, Light Nougat Face and Black Moustache Pattern
  • 42609|43058 / 42609c01.dat  Wing 16 x 16 with Four Fixed Pins
  • + Angry Birds assemblies, but they need parts from Digital Bricks
md5sum: 7527ea1f9638dc3f83d0d88930c08c23
  • 4 months later...
Update 2022-12-12
Added:
  • 87556 / 87556.dat  Minifig Helmet Stormtrooper Type 2
  • 93557 / 93557.dat  Minifigure Hat Sailor
Rematched:
  • 2538 / 2538d.dat  Boat Mast  2 x  2 x 16 Top with Bottom Nubs
  • 6152 / 6152b.dat  Windscreen  6 x  4 x  1.333 Airplane with Solid Studs, without Bottom Tabs
  • 21709 / 21709a.dat  Excavator Bucket  6 x  3 with Click Hinge 2-Finger with 7 Teeth
  • 60470 / 60470b.dat  Plate  1 x  2 with  2 Clips Horizontal (Thick C-Clips)  (more recent)
  • 60481 / 60481b.dat  Slope Brick 65  2 x  1 x  2 with Asymetric Stud Holder
Importable:
  • 3233.dat / 4036  =Glass for Train Window  1 x  2 x  3
  • 21709.dat / 21709  ~Excavator Bucket  6 x  3 with Click Hinge 2-Finger (Obsolete)
  • 29211.dat / 29211  =Minifig Construction Helmet with Dark Brown Hair Ponytail
  • 32807.dat / 6191  =Brick  1 x  4 x  1.333 with Curved Top
  • 41486.dat / 32009  =Technic Beam  3 x  3.8 x  7 Liftarm Bent 45 Double
  • 46481.dat / 48172  =Technic Brick  2 x  2 with Hole and Two Rotation Joint Sockets
  • 48454.dat / 48171  =Technic Brick  2 x  2 with Hole, Half Rotation Joint Ball Vert
  • 52394.dat / 4588=Brick  1 x  1 Round with Fins
  • 54662.dat / 30544  Hinge Arm Locking with Single and Dual Fingers and Hole
  • 60481.dat / 60481  ~Moved to 60481a
  • 60481a.dat / 60481  Slope Brick 65  2 x  1 x  2 with Symetric Stud Holder
  • 69732.dat / 50451  =Technic Axle 16
  • 6152a.dat / 6152  Windscreen  6 x  4 x  1.333 Airplane with Hollow Studs and Bottom Tabs
Added Custom Part:
  • 39742 / 39742.dat  Animal Cat Standing with Spiky Mohawk and Collar
  • 80222 / 80222.dat  Windscreen  6 x  7 x  1.333
md5sum: f0d2e59764e32c37cb0ce50adcaed72f
  • 2 months later...
Update 2023-02-16
Added:
  • 24087 / 24087.dat  Minifigure Skirt Ruffled
  • 26050 / 26050.dat  Figure Cloud
  • 51641 / 51641.dat  Minifig Weapon Staff Nokama
  • 52345 / 52345.dat  Minifig Headdress SW Luminara Unduli
  • 93565 / 93565.dat  Minifig Hair Female with Top Knot Bun and Forelock
  • 22168 / 22168.dat  Electric Powered Up Light with Black Coiled Cable
  • 77834 / 77834-f1.dat  Brick  2 x  4 x  5 Spring Loaded (Extended)
  • 77127 / 77127p01.dat  Electric Hub Luigi with Reddish Brown Hair, Light Nougat Face and Black Moustache Pattern
Added Custom Parts:
  • 1411 / 1411.dat  Minifig Food Corn on the Cob
  • 1745 / 1745.dat  Plate  1 x  2 Half Round with 1 Centre Stud
  • 1746 / 1746.dat  Cone  4 x  8 x  6 Half with Roof Tiles
  • 1747 / 1747.dat  Plant Stem  2L with  2 Leaves and Bar Attachments
  • 1748 / 1748.dat  Tile  1 x  2 Half Round
  • 1749 / 1749.dat  Support  2 x  4 x 13 Semicircle with  5 Pin Holes
  • 1750 / 1750.dat  Brick  2 x  2 x  1 with Curved Bottom
  • 1751 / 1751.dat  Tile  4 x  4
  • 1871 / 1871.dat  Brick  1 x  1 x  1.333 Round Quarter Dome with Curved Top
  • 1874 / 1874.dat  Windscreen  9 x  6 x  1.667
  • 1936 / 1936.dat  Technic Swashplate  5 x  5 Top with  5 Pin Holes
  • 1937 / 1937.dat  Technic Swashplate  5 x  5 Base with  4 Pin Holes
  • 1938 / 1938.dat  Technic Swashplate Ball Joint with  4 Grooves and Square Hole
  • 2387 / 2387.dat  Technic Panel Fairing Smooth #7 (Thin Very Short)
  • 2389 / 2389.dat  Technic Panel Fairing Smooth #8 (Thin Very Short)
  • 2391 / 2391.dat  Technic Beam  7 with Alternating Holes
  • 2393 / 2393.dat  Technic Cross Block  1 x  3 (Pin/Pin/Pin) with  2 Pins
  • 2395 / 2395.dat  Technic Panel Fairing Smooth #9 (Medium Triangle)
  • 2403 / 2403.dat  Technic Panel Fairing Smooth #10 (Medium Triangle)
  • 2457 / 2457.dat  Technic Panel Curved  3 x  2 x  1 Angled #3
  • 2459 / 2459.dat  Technic Panel  9 x  2 x  3 Mudguard Arched with Rounded Top #42
  • 3704 / 3704.dat  Technic Axle  2
  • 4350 / 4350c01.dat  Electric 4.5V 3 C-Cell Battery Box
  • 30101 / 30101.dat  Door  2 x  8 x  6 Revolving Frame
  • 30102 / 30102.dat  Door  2 x  8 x  6 Revolving
  • 35157 / 35157.dat  Glass for Train Door with Lip on All Sides
  • 35635 / 35635.dat  Minifig Armor Dual Layer Shoulder Pads
  • 35701 / 35701.dat  Minifig Hair Short Parted with Two Pigtails and Pin Hole on Top
  • 36481 / 3648a.dat  Technic Gear 24 Tooth with 3 Axleholes
  • 36756 / 36756.dat  Animal Rat with Bent Tail
  • 37614 / 37614.dat  Minifig Shoulder Guards
  • 38547 / 38547.dat  Animal Dragon Wing  9 x  6 with Handle Bars
  • 42819 / 42819.dat  Train Door  1 x  4 x  5 Right with Thick Bottom Support
  • 43967 / 43967.dat  Train Door  1 x  4 x  5 Left with Thick Bottom Support
  • 44511 / 44511.dat  Roof Piece  8 x 12 x 10 Half Onion Dome
  • 48267 / 48267.dat  Technic Tooth  1 x  3 with Axlehole with Straight Bottom Cavity
  • 50335 / 50335.dat  Excavator Bucket  6 x  3 Reinforced with Click Hinge 2-Finger with  7 Teeth
  • 64872 / 64872.dat  Technic Suspension Arm  2 x  6 Reinforced
  • 67737 / 67737.dat  Propeller  4 Blade  5 Diameter with Closed Hub
  • 67929 / 67929.dat  Plate  6 x  6 Octagon with Rim
  • 68327 / 68327.dat  Wheel 16 x 40 with  7 Pin Holes
  • 68547 / 68547.dat  Cloud / Smoke Swirl with Bar  1L
  • 69754 / 69754.dat  Projectile Launcher with Plate  1 x  2
  • 69755 / 69755.dat  Projectile Launcher Trigger
  • 69761 / 69761.dat  Technic Gear 22 Tooth Bevel with Peghole
  • 69762 / 69762.dat  Technic Gear 14 Tooth Bevel
  • 69767 / 69767.dat  Projectile Launcher with Bar
  • 71603 / 71603.dat  Electric Light & Sound Insectoid Tail  4 x 20 x  4.333 with Battery Cover and Trans-Neon-Green Prisms
  • 72514 / 72514.dat  Belville Crown Small
  • 73389 / 73389.dat  Wheel Rim 41 x 75 with  5 Spokes and  3 Pins #2 (Right)
  • 73398 / 73398.dat  Wheel Rim 41 x 75 with  5 Spokes and  3 Pins #1 (Left)
  • 77107 / 77107.dat  Technic Ring 11
  • 80273 / 80273.dat  Technic Beam Propeller  5 Blade  9 Diameter with Square Hole
  • 80274 / 80274.dat  Technic Panel Fairing Smooth Right #62 (Wide Medium Triangle)
  • 80278 / 80278.dat  Technic Panel Fairing Smooth Left #63 (Wide Medium Triangle)
  • 80279 / 80279.dat  Tyre 44/ 12 x 75
  • 80319 / 80319.dat  Baseplate  8 x  8 with Adhesive Tape
  • 80326 / 80326.dat  Flag  2 x  2 Square with Flared Edge
  • 80477 / 80477.dat  Technic Pin with Friction, Bar  2L and Towball
  • 80543 / 80543.dat  Arch  1 x  4 x  3
  • 80563 / 80563.dat  Technic Rotation Joint Socket with Two Friction Pins
  • 80677 / 80677.dat  Tile  2 x  2 Round Splat
  • 81346 / 81346.dat  Technic Gear 20 Tooth with Clutch on Both Sides
  • 81911 / 81911.dat  Windscreen  2 x  4 x  1 Curved
  • 84867 / 84867.dat  Figure Feet  2 x  2 x  0.667 with  4 Feet
  • 90826 / 90826.dat  Broom Bristles with Stud
  • 98878 / 98878.dat  Windscreen 10 x  4 x  2 with Handle - Half
  • 360831 / 36083a.dat  Minifig Weapon Web Effect  5L Narrow with Bars at Both Ends
  • 360832 / 36083b.dat  Minifig Weapon Web Effect Handcuffs
  • 360833 / 36083c.dat  Minifig Weapon Web Effect Web  4 x  3 with Bar
  • 360834 / 36083d.dat  Minifig Weapon Web Effect Web  2 x  2 with Bars on Both Sides
  • 360835 / 36083e.dat  Minifig Weapon Web Effect Web  4.5 x  4 with Bar and  2 Handles
  • 360836 / 36083f.dat  Minifig Weapon Web Effect  4L Spreading with Bars at Both Ends
Modified Custom Parts:
  • 2310 / 2310.dat  Slope Brick 45  2 x  1 Inverted with 0.667 Cutout
md5sum: b6613422a5a16b8e9e8f19327190a9fb
  • 2 months later...
Update 2023-05-08
Added Parts:
  • 10055 / 10055.dat  Minifig Hair Long Straight with Three Braids and Elves Ears
  • 12893 / 12893.dat  Minifig Hair Short with Bald Top with White Hair
  • 23945 / 23945.dat  Minifig Utensil Hourglass
  • 27151 / 27151.dat  Mnifig Bowtie
  • 48005 / 48005.dat  Boat Mast  4 x  4 x 22
  • 60671 / 60671.dat  Figure Troll Body (Complete)
  • 60674 / 60674.dat  Figure Club with Spikes (Complete)
Rematched:
  • 6061 / 6061b.dat  Brick  2 x  4 x  2 with 3 Understuds with Axlehole at Left and Right Side
  • 9570 / 88285.dat  Animal Ostrich Head
  • 10177 / 10177b.dat  Minifig Leg Right Robotic
Importable:
  • 6061.dat / 6061  ~Moved to 6061b
  • 6061a.dat / 6061  Brick  2 x  4 x  2 with 3 Reinforced Understuds with Axlehole at Left and Right Side
  • u9570.dat / 9570  Animal Ostrich Head without Patternable Surfaces
  • 10177.dat / 10177  ~Minifig Leg Right Robotic (Obsolete)
  • 43030.dat / 18969  =Panel  4 x  4 x 13 Curved Tapered with Clip at Each End
Added Custom Part:
  • 39796 / 39796.dat  Minifig Aviator Oxygen Mask
  • 36806 / 36806.dat  Minifig Hair Long Parted in Center
  • 43559 / 43559.dat  Constraction Shoulder Pad Toa Nuva
  • 76959 / 76959.dat  Slope Brick 45  2 x  2 Inverted with Hollow Round Bottom Tube
md5sum: 3ce1f7e2dd22859b21823d324e24472f
Update 2023-06-25
Added Parts:
  • 6245 / 6245.dat  Animal Elephant Head 6 x 7 x 4
  • 14518 / 14518.dat  Animal Shark Body with Gills
  • 20512 / 20512.dat  Animal Shark Head with Rounded Nose
  • 64807 / 64807.dat  Minifig Hair Female Short with Braid on Sides and Hole
  • 90390 / 90390.dat  Minifig Staff with Snake Head
  • 95225 / 95225.dat  Minifig Hair Long Wavy with Center Part
Rematched:
  • 6023 / 6023b.dat  Plate 1 x 2
  • 20460 / 20460b.dat  ~Minifig Leg Left Dual Mould
  • 20461 / 20461b.dat  ~Minifig Leg Right Dual Mould
Importable:
  • 6023.dat / 6023  ~Moved to 6023b
  • 20460.dat / 20460b  ~Minifig Leg Left Dual Mould (Obsolete)
  • 20461.dat / 20461b  ~Minifig Leg Right Dual Mould (Obsolete)
Added Custom Part:
  • 79435 / 79435.dat  Minifig Head  2 x  2 x  1.333 Giant (Needs Work)
md5sum: c891d89f6c49eb345436ae48290a49df
  • 3 months later...
Update 2023-10-02
New parts:
  • 11602 / 11602.dat  Animal Cat Sitting
  • 11264 / 11264.dat  Minifig Hair Short with Laurel Wreath
  • 11418 / 11418.dat  Minifig Headdress Bold with Large Pointed Ears
  • 18962 / 18962.dat  Minifig Helmet Snake Skull
  • 23985 / 23985.dat  Minifig Sword Hilt with Skull
  • 30668 / 30668.dat  Minifig Hood with Fringe
  • 93069 / 93069.dat  Minifig Beard Long with  3 Points
  • 98128 / 98128.dat  Minifig Helmet with Clip and Long Visor
Corrected:
  • 4719 / 4719.dat  Minifig Bicycle Frame  (realigned on stand and wheels; studs are now too high)
Re-matched:
  • 70358 / 70358a.dat  Electric Train Motor  9V (Complete)
Custom parts:
  • 28578 / 92851.dat  Wheel Minifig Bicycle with Integral Rubber Black Tyre
  • 35692 / 35692.dat  Minifig Utensil Balloon Dog
Importable:
  • 2894c01.dat / 70358  ~Moved to 70358a
  • 28578.dat / 28578  =Wheel Minifig Bicycle with Integral Rubber Black Tyre
  • 31510.dat / 96874  =Brick Separator with Top Axle
  • 31576.dat / 15279  =Plant Grass Stem
  • 33449.dat / 93609  =Arm Skeleton with Horizontal Clip Bent 56.31
  • 37846.dat / 93550  =Minifig Sword Rapier
md5sum: 32310b043190e4d30f4fe18853f520f0
Update 2023-10-21
Colours updated (I forgot to do that in April when ldconfig.ldr was updated :innocent:)
Added:
  • 6089 / 6089.dat  Minifig Helmet Diving with Scuba Tanks and Clips
Corrected:
  • 23985 / 23985.dat  Minifig Sword Hilt with Skull         (I had the wrong file :facepalm: )
md5sum: 6eb81b0a2f6cd2525013ab2856605686
Update 2023-12-19
I did not check the 100 or 200 parts (stock and custom) that were customized/modified since December 2022.  Theoretically and hopefully, their orientations and positions weren’t changed.
Added:
  • 13784 / 13784.dat  Minifig Hair Female Long with Braided Pigtails
  • 15437 / 15437.dat  Minifig Armour Shoulder Pads
  • 15557 / 15557.dat  Minifig Hair Trapezoid Swept Back
  • 24204 / 24204.dat  Animal Tail Bladed with Pin and Bar Tip
  • 25613 / 25613.dat  Minifig Hair with Top Knot Bun and Fringe
  • 53545 / 53545.dat  Constraction Torso 11 x 6
Importable:
  • 3347.dat / 94161  =Window  1 x  2 x  2.667 Shutter with Rounded Top
  • 79811.dat / 98369  =Minifig Cleaver
  • 35287.dat / 60602  Glass for Window  1 x  2 x  3
Added Custom assemblies:
  • 37779  Minifig Arm Large Left with Friction Pin
  • 37783  Minifig Arm Large Right with Friction Pin
  • 73261  Electric 4.5V 3 C-Cell Battery Box Polarity Switch 2 x 4
  • 85824  Electric Control+ Hub with Screw Opening
Added Custom parts:
  • 1686 / 1686.dat  Constraction Shell  2 x  4 x  3.333 Shoulder Pad with Bar
  • 1744 / 1744.dat  Cylinder  3 x  3 x  3 Dome Elongated
  • 1846 / 1846.dat  Car Mudguard  4 x  3 x  1.667
  • 1872 / 1872.dat  Wheel Rim 11 x 18 Front with 36 Spokes and Knock-off Hub Nut
  • 1939 / 1939.dat  =Tile  4 x  4 Corner Round Type 2
  • 1942 / 1942.dat  Slope Curved  4 x  2 x  0.667 Double with Fresnel Lens
  • 2142 / 2142.dat  Horn Stacked with Axle Holes
  • 2405 / 2405.dat  Technic Wheel Spindle Axle Driver Bar  5L
  • 2438 / 2438.dat  Technic Panel  5 x  3 x  2 Corner Left
  • 2442 / 2442.dat  Technic Panel  5 x  3 x  2 Corner Right
  • 2471 / 2471.dat  Technic Gear 24 Tooth with Clutch on Both Sides
  • 2473 / 2473a.dat  Technic Transmission Driving Ring  2L with  8 Teeth
  • 2474 / 2474a.dat  Technic Gear Stepper with  8 Teeth
  • 2477 / 2477.dat  Technic Beam  3 x  5 Bent 90 with Alternating Holes
  • 2491 / 2491.dat  Tyre 29/ 66 x 43
  • 2502 / 2502.dat  Technic Beam  2 x 12 x  9 with Claw
  • 2509 / 2509.dat  Technic Panel 11 x  2 x  5 Mudguard Arched #32
  • 2612 / 2612.dat  Plate 16 x 16 x 0.667 with  8 x  8 Cutout and Recessed Studs
  • 2628 / 2628.dat  Plate  8 x  8 x  0.667 with Cutouts and Recessed Studs
  • 2629 / 2629.dat  Plate  8 x 16 x  0.667 with Cutouts and Recessed Studs
  • 2656 / 2656.dat  Container Cupboard  2 x  3 x  5
  • 2657 / 2657.dat  Door  1 x  3 x  5
  • 2676 / 2676.dat  Minifig Beard with Braided Moustache Ends and Braid in Back
  • 2937 / 2937.dat  Slope Brick 55  1 x  6 x  5 with Bottom Stud Holders
  • 3130 / 3130.dat  Panel  2 x  2 x  1 Side Panels
  • 3131 / 3131.dat  Panel  2 x  2 x  1 Corner Posts with Centre Stud
  • 3160 / 3160.dat  Tile  6 x  6 x  0.667 with Angled Textured Surface
  • 3161 / 3161.dat  Panel 2 x  4 x  6 Rock
  • 3166 / 3166.dat  Vehicle Mudguard 4 x 8 x 0.667 (needs Work)
  • 3170 / 3170.dat  Plate  1 x  2 with Ball Joint-8 on Both Ends
  • 3172 / 3172.dat  Plate  1 x  3 with Offset Peghole on Underside
  • 3221 / 3221.dat  Minifig Helmet Pan Shaped with Hollow Stud on Front
  • 3224 / 3224.dat  Fence  1 x  2 x  1.667 with 45 Degree Diagonal Bar
  • 3250 / 3250.dat  Technic Ring 15
  • 3251 / 3251.dat  Technic Panel Cylinder 15 60°
  • 3263 / 3263.dat  Plate  4 x  3 x  0.667 with Rounded Corners on one Side
  • 3384 / 3384.dat  Windscreen  6 x  4 x 1.333 Sloped
  • 3385 / 3385.dat  Car Base  6 x 12 with  5 x  6 Recessed Centre and Studs on Sides
  • 3386 / 3386.dat  Plate  1 x  1 x  0.667 Half Round with Open Side Stud
  • 3387 / 3387.dat  Car Mudguard  4 x  2.5 x  2
  • 3388 / 3388.dat  Wedge  1 x  5 Straight Left
  • 3389 / 3389.dat  Wedge  1 x  5 Straight Right
  • 3395 / 3395.dat  Tile  2 x  4 Inverted with Groove
  • 3396 / 3396.dat  Tile  2 x  2 with Two  1 x  1 Curved Cutouts
  • 3477 / 3477.dat  Tile  4 x  4 Corner Round Type 2
  • 3486 / 3486.dat  Wheel 16 x 37 Hard-Plastic with 4 Studs
  • 3504 / 3504.dat  Wedge  2 x  5 Straight Left
  • 3505 / 3505.dat  Wedge  2 x  5 Straight Right
  • 3535 / 3535.dat  Panel  3 x  3 x  2 Quarter Round
  • 3538 / 3538.dat  Technic Panel 11 x  2 x  5 Mudguard Arched with Rounded Top #43
  • 3544 / 3544.dat  Wing  3 x  8 Left
  • 3545 / 3545.dat  Wing  3 x  8 Right
  • 3569 / 3569.dat  Cone  4 x  4 x  3 on Brick  2 x  2 Round
  • 3572 / 3572.dat  Arch  1 x  5 x  2
  • 3661 / 3661.dat  Plate  1 x  1 with Vertical Bar
  • 3668 / 3668.dat  Plate  2 x  6 with Side Bricks  1 x  2 x  1.333 with Axlehole with Underside Ridges
  • 3885 / 3885.dat  Minifig Sword Darksaber
  • 4158 / 4158.dat  Technic Changeover Cylinder with Groove
  • 4159 / 4159.dat  Technic Changeover Catch Fork
  • 4192 / 4192.dat  Technic Steering Constant Velocity 8mm Joint Female With 2L Axle
  • 4569 / 4569.dat  Slope Brick 10  6 x  1
  • 18031 / 18031.dat  Minifig Sword Longsword with Thick Guard
  • 26741 / 2674c.dat  Minifig Sword Small with Curved Blade and Detailed Hilt
  • 26742 / 2674e.dat  Minifig Sword with Broken Blade
  • 26743 / 2674f.dat  Minifig Sword Small with Upturned Crossguard and Capped Pommel
  • 26744 / 2674b.dat  Minifig Sword Greatsword with Capped Pommel
  • 26745 / 2674a.dat  Minifig Sword Elfish
  • 26746 / 2674d.dat  Minifig Weapon Axe Dwarven
  • 28621 / 28621.dat  Minifig Head with Vented Stud
  • 32305 / 32305.dat  Technic Connector Block  7 x  4 x  3
  • 32533 / 32533.dat  Technic Disc  5 x  5 Projectile
  • 35530 / 35530.dat  Minifig Baby Head Cuboid
  • 37822 / 37822.dat  Minifig Baby Carrier
  • 38301 / 38301c02.dat  Minifig Cape Cloth Scalloped  6 Points (Formed Shape 2)
  • 38458 / 38458.dat  Minifig Head with Exaggerated Chimpanzee Features
  • 39370 / 39370.dat  Technic Beam  5 x  3 H-shaped with Ball Socket
  • 40145 / 40145.dat  Plate  2 x  2 Round with Rotation Stem
  • 45779 / 45779.dat  Minifig Helmet with Mask
  • 45991 / 4599a.dat  Tap  1 x  1 with Hole in Spout
  • 49736 / 49736.dat  Cylinder Tube Slide Straight
  • 49737 / 49737.dat  Cylinder Tube Slide Curved 45 Degrees
  • 51066 / 51066.dat  Minifig Robot Leg  1 x  2 x  1.667 with Pin with Square Centre Hole
  • 57881 / 57881.dat  Minifig Hat Rain
  • 65066 / 65066.dat  Glass for Door  1 x  6 x  7 with Arch
  • 66964 / 66964.dat  Minifig Sword Greatsword Pointed with Upturned Crossguard
  • 67631 / 67631.dat  Animal Otter
  • 68577 / 68577.dat  Wheel Rim 42 x 62 with 20 Spokes and  3 Pins
  • 69912 / 69912.dat  Tyre 35/ 55 x 43 R Tractor
  • 69945 / 69945.dat  Animal Hermit Crab with 45 Degree Bar on Back
  • 70495 / 70495.dat  Windscreen  3 x 14 x  4 with Conical Sides
  • 70880 / 70880.dat  Rock Rounded  1 x  4 with  2 Studs on Ends
  • 73763 / 73763.dat  Technic Worm Gear  6L
  • 77123 / 77123.dat  Minifig Head Special with Black Mouse Ears and Nose with Fire Fighter Helmet
  • 77822 / 77822.dat  Sports Stuntz Loop Ramp Base
  • 77823 / 77823.dat  Sports Stuntz Loop Ramp Section
  • 77844 / 77844.dat  Plate  3 x  3 Corner
  • 77845 / 77845.dat  Plate  1 x  4 Round Ends with  2 Open Studs on Ends
  • 77850 / 77850.dat  Plate  1 x  3 Round Ends and  3 Open Studs
  • 78124 / 78124.dat  =Container Cupboard  2 x  3 x  2 Drawer
  • 78168 / 78168.dat  Plate  2 x  6 with Centred  2 x  2 Rounded Holder
  • 79768 / 79768.dat  Technic Beam 16 x  7 Triangular with Diagonal Bars
  • 79996 / 79996.dat  Bag Tag with  3 x  8 Studs
  • 80031 / 80031.dat  Plate 10 x 10 with Rounded End
  • 80390 / 80390.dat  Bag Tag with  3 x  6 Studs
  • 80428 / 80428.dat  Technic Weight  7 x 11 x  2
  • 80497 / 80497.dat  Animal Tail with Straight Tip
  • 80513 / 80513.dat  Animal Toucan
  • 80562 / 80562.dat  Train Track Roller Coaster  4 x  4
  • 80567 / 80567.dat  Vehicle Mudguard  4 x 10 x  0.667
  • 80577 / 80577.dat  Minifig Hair Long Wavy with Knit Ski Cap
  • 80683 / 80683.dat  Door  1 x  3 x  6
  • 80834 / 80834.dat  Minifig Hair with Nurse Hat with Long Back
  • 83496 / 83496.dat  Tile  4 x  8 Inverted
  • 86879 / 86879.dat  Animal Axolotl Body
  • 90840 / 90840.dat  Train Wheel Very Large with Axlehole and Pinhole
  • 100662 / 100662.dat  Minifig Baby Head with Space Helmet and Air Tanks
  • 101658 / 101658c01.dat  Minifig Cape with Stepped Shoulders and Single Top Hole (Formed)
  • 101777 / 101777.dat  Minifig Top Hat with Band
  • 102498 / 102498.dat  Minifig Tool Wand with Hollow Stud at Tip
  • 103918 / 103918.dat  Windscreen  4 x  4 x  2 with Integral Glass
  • 350321 / 35032a.dat  Power Burst Blaster with Bar
  • 350322 / 35032b.dat  Power Burst Bolt  5L with Bar at Both Ends
  • 350324 / 35032d.dat  Power Burst Bolt  5L Spiral with Bar at Both Ends
  • 350325 / 35032e.dat  Power Burst Shield  3.5 x  3.5 with Bar
  • 350326 / 35032f.dat  Power Burst Shield  3 x  2.5 with Bar at Both Ends
md5sum: f5167111b89abeb94b6421975dbf678e
Update 2024-02-08
Added:
  • 10056 / 10056.dat  Minifig Helmet with Cheek and Neck Protection
  • 10065 / 10065.dat  Minifig Beard with Braided Moustache Ends
  • 10829 / 10829.dat  Minifig Helmet Deep Diver with Lens
  • 11098 / 11098.dat  Minifig Armour Breastplate with Shoulder Pads, Front Stud and  2 Back Studs
  • 11107 / 11107.dat  Minifig Sword Serrated with Bar Holder
  • 12551 / 12551.dat  Minifig Mask Crocodile
  • 12894 / 12894.dat  Minifig Hat Cone
  • 16768 / 16768.dat  Bar  4L with Flame Protusions
  • 17348 / 17348.dat  Minifig Princess Hair with Hat
  • 18051 / 18051.dat  Vehicle Mudguard  3 x  4 x  1 2/3 with Curved Fenders
  • 18742 / 18742.dat  Bucket  2 x  2 without Handle Holes
  • 18959 / 18959.dat  Minifig Hat Nemes
  • 19026 / 19026.dat  Minifig Helmet Cyborg Open Side
  • 20690 / 20690.dat  Animal Dog Sitting Great Dane Body
  • 20691 / 20691.dat  Animal Dog Sitting Great Dane Head
  • 24084 / 24084.dat  Minifig Weapon Spiked Ball
  • 98129 / 98129.dat  Minifig Helmet Visor Samurai
  • 98132 / 98132.dat  Minifig Armour with Shoulder Pads and Scabbard
  • 98133 / 98133.dat  Minifig Hat Ninja Wrap Type 1
  • 98725 / 98725.dat  Minifig Hair Female Long Wavy with Tiara
  • 99251 / 99251.dat  Minifig Neck Ruff
Added custom parts:
  • 60189 / 60189.dat  Brick Braille 2 x 4 with 1 Stud (DOTS-1)
  • 60290 / 60290.dat  Brick Braille 2 x 4 with 6 Studs (DOTS-123456)
  • 65559 / 65559.dat  Brick Braille 2 x 4 with 1 Stud (DOTS-5)
  • 65579 / 65579.dat  Minifig Hair Parted in Middle with 2 Round Buns on Top
  • 73210 / 73210.dat  Mario Pixelated
md5sum: 6e5456c9d8359b6508c0e8c09d41fd62
Update 2024-03-23
Added:
  • 18277 / 18277.dat  Minifig Tail Fluffy
  • 95341 / 95341.dat  Animal Goat
  • 18386  Minifig Hips and Legs with Black Leg Extenders
  • 100943  Technic Steering Wheel Bearing with 2 Towballs
Added Custom Parts:
  • 1994 / 1994.dat  Technic Cylinder with Peghole and Half Click Rotation Joint Ball
  • 1995 / 1995.dat  Flame / Vapor Trail 3 x 12 with Axle Hole and Marbled Core
  • 2821 / 2821.dat  Container 2 x 2 x 1 Crate Reinforced
  • 3167 / 3167.dat  Technic Beam 2 x 3 C-shaped
  • 3171 / 3171.dat  Constraction Finger Angled with Clip
  • 3233 / 3233.dat  Window 1 x 2 x 3 Train with Underside Ridged Stud Holders
  • 3484 / 3484.dat  Bar 1.5L with Clip Type 3
  • 3563 / 3563.dat  Brick 1 x 2 x 0.667 with Curved Top
  • 3565 / 3565.dat  Plant Palm Leaf 2 x 6 Rounded with Rounded 1 x 2 Plate
  • 3567 / 3567.dat  Tile 2 x 2 Round Inverted with Groove
  • 3573 / 3573.dat  Slope Brick Curved 4 x 1 x 1.667
  • 3627 / 3627.dat  Constraction Lightsaber Blade 10L with Axle End
  • 3766 / 3766.dat  Plate 4 x 6 with Rounded Ends
  • 3803 / 3803.dat  Bar 1L Quadruple with 1L Peghole Hub
  • 3917 / 3917.dat  Ring 2 x 2 with Stud Holder
  • 3968 / 3968.dat  Figure Arm Bent Long with Peghole and Friction Pin
  • 4041 / 4041.dat  Panel 4 x 4 x 3 Corner Round
  • 4042 / 4042.dat  Bar Curved with Axle End and 2 Opposite Studs
  • 4304 / 4304.dat  Plate  2 x  2 x  0.667 with Two Studs On Side and Two Raised with Partial Closed Understud
  • 4585 / 4585.dat  Bracket 2 x 1 - 2 x 1 Up Centred
  • 4586 / 4586.dat  Technic Beam 9 x 0.5 with 3 Holes
  • 5065 / 5065.dat  Panel 6 x 5 x 3.333 with Curved Top
  • 5066 / 5066.dat  Plate 2 x 2 with Horizontal T-Bar Below
  • 5152 / 5152.dat  Brick 3 x 3 Corner Round
  • 5405 / 5405.dat  Technic Gear 4 Knob 45°
  • 21788 / 21788.dat  Minifig Hair Short Smooth
  • 35809 / 35809.dat  Minifig Pen
  • 37784 / 37784.dat  Minifig Hair Half Giant with Beard
  • 42876 / 42876.dat  Minifig Food Turkey Leg with Oval Opening on Back
  • 65203 / 65203.dat  Figure Micro Doll Body with Long Dress
  • 65700 / 65700.dat  Plate Round 2.5 x 2.5 with Melting Drops on Sides
  • 65766 / 65766.dat  Technic Steering Wheel Bearing with 2 Pegholes & 2 Axleholes Arms Type 2
  • 67037 / 67037.dat  Minifig Helmet with Cheek Guard and Neck Protector
  • 67144 / 67144.dat  Sheet Plastic 8.5 x 7 Motorcycle Windscreen
  • 67361 / 67361.dat  Brick 2 x 2 Round with Tail/Neck Curved Extension with Tip Pin Hole
  • 67697 / 67697.dat  =Technic Beam 2 Liftarm with Straight Ball Joint
  • 68212 / 68212.dat  Minifig Tuft
  • 69857 / 69857.dat  Minifig Hair Curly with High Ponytail
  • 72132 / 72132.dat  Plate 2 x 6 x 0.667 with Four Studs On Side and Four Raised Reinforced
  • 73764 / 73764.dat  Brick 2 x 2 x 1.667 with Hole for Worm Screw 6L
  • 78333 / 78333.dat  Hose Reel 2 x 2 with Stud and Pin Holes
  • 78643 / 78643.dat  Minifig Armor Breastplate with Round Shoulder Pads and 2 Back Studs
  • 79735 / 79735.dat  Minifig Chopsticks
  • 79766 / 79766.dat  Technic Beam 15 x 7 with Open Center and 3 Truss Bars
  • 79767 / 79767.dat  Technic Beam 15 x 5 with Open Center and 3 Truss Bars
  • 79808 / 79808.dat  Minifig Whisk with Notch in Handle
  • 80295 / 80295.dat  Technic Reel 4 x 3
  • 80835 / 80835.dat  Container Treasure Chest Lid with Flat Top
  • 100942 / 100942.dat  Wheel 37 x 45 Hard-Plastic with 6 Curved Spokes
md5sum: 91c6fddb739e1933d31ce922d285baea
  • 3 months later...
Update 2024-07-04
New Colours.  Some clean up.
Added Parts:
  • 11129 / 11129.dat  Minifig Mask Lion
  • 12607 / 12607.dat  Minifig Head Ninja Turtle
  • 14225 / 14225.dat  String Braided 31L with End Studs
  • 21968 / 21968.dat  Minifig Body Ghost
  • 21969 / 21969.dat  Minifig Arm Ghost
  • 21970 / 21970.dat  Minifig Head Robot
  • 22380 / 22380.dat  Minifig Helmet Space with Air Intakes and Top Pin Hole
  • 25972 / 25972.dat  Minifig Hair Swept Back with Slight Widow's Peak and Short Sideburns
  • 26049 / 26049.dat  Minifig Head Jake the Dog
  • 26057 / 26057.dat  Minifig Hair Swept Forward with Ears
  • 27955 / 27955.dat  Minifig Hat with Folder Brim and Bob Cut Hair
  • 63142 / 14225.dat  String Braided 31L with End Studs
  • 87788 / 87788.dat  Bionicle Mask Hau
  • 87996 / 87996.dat  Minifig Horn
  • 90396 / 90396.dat  Minifig Hair Mid-Length Wavy with Centre Part
  • 90538 / 90538.dat  Minifig Hat Fedora with Wide Brim
  • 90539 / 90539.dat  Minifig Breathing Apparatus
  • 93224 / 93224.dat  Minifig Helmet Hazmat Suit with Trans Clear Visor
  • 93225 / 93225.dat  Minifig Spray Gun with Hose
Added Custom Parts:
  • 4190 / 4190.dat  Plate  2 x  2 Slope Inverted Corner
  • 44740 / 44740.dat  Minifig Hair Decoration Plume Ribbon
  • 67649 / 67649.dat  Minifig Head Minion  2 x  2 x  1.667 with Mono-Goggles
  • 80394 / 80394a.dat  Cockpit  6 x  4 x  4.667
md5sum: e892fe5e624f272540e8f90f4b5ef615
Update 2024-07-05
Parts Added:
  • 88964 / 88964.dat  Bar  0.5L with Curved Leaf 2L
Custom Parts Added:
  • 1997 / 1997.dat  Plant Vine Curled with Bar
  • 2229 / 2229.dat  Tile  2 x  2 with Rounded Slab
  • 2514 / 2514.dat  Minifig Hat Newsboy Cap
  • 3417 / 3417.dat  Door Frame  3 x  6 x  6 with Inside Grooves
  • 3571 / 3571.dat  Windscreen  4 x 12 x  3 Curved
  • 3628 / 3628.dat  Bar  2L with Three Clips
  • 3863 / 3863.dat  Brick  2 x  4 x  5 with Hole for Worm Screw  6L, Runners for Channels and Elevator Platform
  • 4367 / 4367.dat  Plant Flower with  7 Alternate Petals with Centre Ring with Bar and Pin Hole
  • 4368 / 4368.dat  Technic Engine Crank Disk
  • 4369 / 4369.dat  Technic Engine Piston with Stud
  • 4410 / 4410.dat  Tyre 44 x 32 / 56 Smooth Racing
  • 4412 / 4412.dat  Technic Dome  5 x  5 x  2.5
  • 4413 / 4413.dat  Technic Dome 11 x 11 x  5.5
  • 4472 / 4472.dat  Wheel Cover Smooth for Wheel 34 x 56
  • 4500 / 4500.dat  Technic Panel Smooth Inverted  7 x  3 x  2
  • 4527 / 4527.dat  Technic Panel  3 x 13 Curved #52 Tapered Left
  • 4920 / 4920.dat  Brick 1 x 2 with Click Rotation Pin
  • 4974 / 4974.dat  =Tile  8 x 16 Type 2
  • 5032 / 5032.dat  Door  1 x  4 x  6 Fence
  • 5090 / 5090.dat  Bracket  1 x  6 with  1 x  4 Cutout -  2x  6 Up
  • 5091 / 5091.dat  Tile  1 x  2 Cut Left 45 Degree
  • 5092 / 5092.dat  Tile  1 x  2 Cut Right 45 Degree
  • 5151 / 5151.dat  Plant Serrated Leaf with  1 x  2 Rounded Plate
  • 5175 / 5175.dat  Bracket  2 x  4 -  1 x  4 Down
  • 5240 / 5240.dat  Technic Rotor Blade 40L with Beam  3L
  • 5258 / 5258.dat  Door Frame  1 x  6 x  6.333 with Rounded Top and Front Right Clips
  • 5259 / 5259.dat  Window  1 x  4 x  3 Square Top with 4 Panes and Sill
  • 5260 / 5260.dat  Window  1 x  4 x  3 Curved Top with  4 Panes and Sill
  • 5294 / 5294.dat  Technic Suspension Arm  4 x  6 Triangular
  • 5401 / 5401.dat  Windscreen  7 x  6.5 x  2 Motorcycle with Beam  3L
  • 5404 / 5404.dat  Slope Brick 18  2 x  1 x  0.667
  • 5426 / 5426.dat  Technic Panel  3 x 13 Curved #53 Tapered Right
  • 5466 / 5466.dat  Door  1 x  4 x  6 with Window and Wood Structure
  • 5520 / 5520.dat  Tile  2 x  2 with Rounded End
  • 18034 / 18034.dat  Minifig Sword Roman Gladius with Thick Crossguard
  • 49699 / 49699.dat  Panel  1 x  6 x  4.333 with  4 x  3 Opening and 4 Pin Holes
  • 54568 / 54568.dat  Propeller Two-Blades Twisted Cap
  • 59276 / 59276.dat  Minifig Hood Long Angular
  • 62469 / 62469.dat  ~Electric Power Functions Pole Reverser Top (Needs Work)
  • 62473 / 62473.dat  ~Electric Power Functions Pole Reverser Lever
  • 62875 / 62875.dat  ~Electric Power Functions Pole Reverser Slider
  • 77263 / 77263.dat  Minifig Tail Mouse
  • 80910 / 80910.dat  Technic Cross Block  2 x  4 Split (Pin/Axle/Axle/Pin)
  • 105162 / 105162.dat  Wheel 13.4 x 24 with Integral Smooth Racing Tyre
  • 105645 / 105645.dat  Wheel 22 x 50 with Integral Smooth Racing Tyre
  • 106700 / 106700.dat  Minifig Robe Cloth 13L Tall
Custom Assembly added:
  • 61929  Electric Power Functions Pole Reverser / Polarity Switch   (incomplete: missing bottom)
  • 619291  Electric Power Functions Pole Reverser / Polarity Switch without Secondary Inverter   (incomplete: missing bottom)
md5sum: fc27b241e61abf5d611a787849be7627
  • 2 months later...
Update 2024-09-30
Added parts:
  • 10168 / 10168.dat  Minifig Hat Cowboy with Hair in Braid
  • 11261 / 11261.dat  Minifig Hair Long with Braided Front
  • 12609 / 12609.dat  Minifig Ninja Turtle Shell with Horizontal Belt
  • 12890 / 12890.dat  Minifig Hair Female Long Straight
  • 13746 / 13746.dat  Minifig Hat with Small Pin, Women's Fedora with Large Bow and Feather
  • 13750 / 13750.dat  Minifig Hair Female Long, Braided on Right, Hole on Top
  • 13766 / 13766.dat  Minifig Hair Long Wavy with Braid and Elf Ears
  • 19206 / 19206.dat  Figure Elves Hair Long Tapered in Back with Braids and Elves Ears
  • 20905 / 20905.dat  Minifig Helmet SW Flametrooper Episode  7 and Walker Driver Episode 8
  • 21561 / 21561.dat  Constraction Torso
  • 87777 / 87777.dat  Minifig Helmet Visor Shielded
  • 89079 / 89079.dat  Bar 0.5L with Flat Shell with Scales 3.2L
Rematched:
  • 90396 / 86398.dat  Minifig Hair Mid-Length Wavy with Centre Part
md5sum: 8109fa3efed16641558dc1b7dcd73551
Edited by SylvainLS
