SylvainLS Posted October 3, 2016 Author Posted October 3, 2016 (edited) Update 2016-10-03 Added (new parts in 4.3.10): 23443 / 23443.dat Bar Tube with Handle 24599 / 24599.dat Brick 5 x 5 Corner Round 25214 / 25214.dat Cylinder 2 x 2 Elbow with Axle Holes 24947 / 24947.dat Dome 2 x 2 Inverted Ovoid with Studs 23950 / 23950.dat Panel 1 x 3 x 1 with Rounded Corners 25893 / 25893.dat Plate 1 x 1 Round with Horizontal Handle Below 26047 / 26047.dat Plate 1 x 1 Round with Horizontal Handle on Side 26287 / 26287.dat Technic Axle Joiner 3L 24121 / 24121.dat Technic Gear Ring Quarter 11 x 11 with 35 Teeth 24119 / 24119.dat Technic Panel Smooth 7 x 2 x 3 25269 / 25269.dat Tile 1 x 1 Corner Round 19071 / 19071c01.dat Electric Power Functions 2.0 Hub with Battery Also added: all the parts (1068 parts + 42 subparts for assemblies) available at digital-bricks.de that are not yet in LDraw. I didn’t test them all yet, but as they are a direct conversion from LDD, they shouldn’t need a transformation (other than identity). I will replace them as soon as they are available in LDraw. I also updated these files if you want to help: The assemblies for which parts are missing (dark grey are missing, white is the rest of the parts of the assembly we already have the LDraw parts for). The list of LDD parts that I know no LDraw equivalent for: CSV (columns: LDD ID, LDD name, guessed BrickLink ID, BrickLink name). Edited October 3, 2016 by SylvainLS Added assemblies’ subparts from d-b.de Quote
SylvainLS Posted October 4, 2016 Author Posted October 4, 2016 (edited) Update 2016-10-04 Added: 13392 / 13392.dat Animal Dolphin Jumping 96491 / 96491.dat Minifig Crown Tiara Flat Edited October 4, 2016 by SylvainLS Added tiara Quote
SylvainLS Posted October 6, 2016 Author Posted October 6, 2016 Update 2016-10-06 Added: 18854 / 18854.dat Figure Friends Sunglasses with Pin 96488 / 96488.dat Figure Friends Hand Mirror with Heart on Reverse All 4.3.10–2248 parts are now available from Digital Bricks. Every part is (again) exportable/importable. (To be clear, transformations are for the (un)official LDraw versions, when they exist. The Digital Bricks parts are a workaround solution, a “second choice.” Transformations may not work for the DB versions when the parts are in LDraw Official and Unofficial Parts Libraries as I adjust the transformations for the LDraw versions as soon as I’m aware of their existence (a few hours).) Quote
SylvainLS Posted October 9, 2016 Author Posted October 9, 2016 Update 2016-10-10 Added: 20841 (assembly) / (20841.dat + 23816.dat) Electric Power Functions 2.0 Tilt Sensor 20844 (assembly) / (20844.dat + 23816.dat) Electric Power Functions 2.0 IR Distance Sensor 21980 (assembly) / (59146.dat + u9327c01 + 23816.dat) Electric Power Functions 2.0 Medium Motor Quote
SylvainLS Posted October 10, 2016 Author Posted October 10, 2016 Update 2016-10-10b Added: 23444 / 23444.dat Bar 6 x 3 with 4 Studs 24482 / 24482.dat Spike 2.4L with 4 Fins with Bar 0.4L Quote
Philo Posted October 10, 2016 Posted October 10, 2016 (edited) Impressive response time between Parts Tracker submit and xml update ;) Edited October 10, 2016 by Philo Quote
SylvainLS Posted October 10, 2016 Author Posted October 10, 2016 Just a well oiled machine now, and less impressive than your part thoughput By the way, your version of the tassel has been added too: 25375 / 25375-f1.dat Tassel Hanging from Top Quote
SylvainLS Posted October 12, 2016 Author Posted October 12, 2016 Update 2016-10-12 Added: 26556 / 24581.dat Minifig Baby Head 25126 / 25126.dat Minifig Baby Body with Yellow Hands Pattern Quote
SylvainLS Posted October 19, 2016 Author Posted October 19, 2016 Update 2016-10-19 Added: 24131 / 24131.dat Figure Friends Party Hat Quote
SylvainLS Posted October 31, 2016 Author Posted October 31, 2016 Update 2016-10-31 Added: 23949 / 23949.dat Slope Brick 2 x 6 Quote
SylvainLS Posted November 4, 2016 Author Posted November 4, 2016 Update 2016-11-04 Added: 22390 / 22390.dat Wedge 6 x 8 Double with Cutout Quote
SylvainLS Posted November 5, 2016 Author Posted November 5, 2016 Update 2016-11-05 Little update due to changes in LDraw Unofficial parts (subparts for 58123 and 11767). Quote
SylvainLS Posted November 7, 2016 Author Posted November 7, 2016 Update 2016-11-07 Added: 93089 / 93089.dat Animal Cat Standing Looking Left And some assemblies have been reorganized (one subpart is beam and screw, the other is the magnet case): 64414 (and variant 91992) Train Buffer Beam with Plow and Sealed Magnet (Complete) 64422 (and variant 91994) Train Buffer Beam with Sealed Magnet (Complete) Quote
SylvainLS Posted November 7, 2016 Author Posted November 7, 2016 Update 2016-11-07 bis Added: 95827 / 95827.dat Animal Beetle with Stud Tube and Pin Hole 95828 / 95828.dat Animal Butterfly with Stud Tube and Pin Hole Quote
SylvainLS Posted November 14, 2016 Author Posted November 14, 2016 Update 2016-11-14 Rematched: 4479 / 4479a.dat Minifig Metal Detector (4479.dat obsoleted, 4479a.dat more accurate) Quote
SylvainLS Posted November 16, 2016 Author Posted November 16, 2016 Update 2016-11-16 Renumbered: 42114 / 42114.dat Minifig Tool Light Sabre Hilt with Bend Quote
Philo Posted November 16, 2016 Posted November 16, 2016 3 hours ago, SylvainLS said: 42114 / 42114.dat Minifig Tool Light Sabre Hilt with Bend Note that I also modified the part (angle between stud and bar) to better fit LDD shape. Quote
SylvainLS Posted November 16, 2016 Author Posted November 16, 2016 2 hours ago, Philo said: Note that I also modified the part (angle between stud and bar) to better fit LDD shape. Thanks, corrected (2016-11-16b) Quote
SylvainLS Posted November 17, 2016 Author Posted November 17, 2016 Update 2016-11-17 Added: 15396 / 15396.dat Minifig Scooter Body Quote
SylvainLS Posted November 19, 2016 Author Posted November 19, 2016 Update 2016-11-19 Added: 76764 / 76764.dat Minifig Sword Shortsword with Elaborate Hilt 94531 / 95431.dat Windscreen 12 x 6 x 6 Curved without Pin Holes Quote
Philo Posted November 19, 2016 Posted November 19, 2016 Sorry, just changed origin/orientation of the sword to better match other LDraw swords. You're too fast ;) Quote
SylvainLS Posted November 19, 2016 Author Posted November 19, 2016 And lowered it a bit. Corrected. Quote
SylvainLS Posted November 22, 2016 Author Posted November 22, 2016 Update 2016-11-23 Corrected: 2542 / 2542.dat Minifig Tool Oar Added: 10170 /10170.dat Minifig Food Pretzel 22410 / 22410.dat Wheel 21 x 37 Hard-Plastic with 7 Pin Holes 87585 / 87585.dat Minifig Tool Oar Reinforced Quote
SylvainLS Posted November 24, 2016 Author Posted November 24, 2016 Update 2016-11-24 Added: 22411 / 22411.dat Minifig Plume Horsetail Quote
SylvainLS Posted November 25, 2016 Author Posted November 25, 2016 Update 2016-11-25 Added: 22408 / 22408.dat Minifig Shield Pentagonal 47507 / 47507.dat Cockpit 6 x 6 x 2 Cabin Base with Pin Holes Quote
