Thanks for the very useful work.
What do you think about adding a link to the xml file in the update post too?
It would be comfortable, I shouldn't load the first page of the topic every time to get the link.
Edited by Calabar
  • Replies 325
Posted Images
You’re welcome :classic:
A link would be useful indeed. Will do!
Update 2017-05-12
Verified/Corrected (still aren’t exported/imported by LDD but transformations are now correct):
  • 64230 / 73590a.dat  Hose Flexible  8.5L without Tabs
  • 57539 / 57539.dat  Hose Flexible 19M
  • 92338 / 92338c01.dat  Minifig Chain  5L (Complete)
  • 63141 / 572c01.dat String Braided 21L with End Studs and Minifig Grips (Complete)
  • 32580 / 32580.dat  Technic Axle Flexible  7
  • 32199 / 32199.dat  Technic Axle Flexible 11
  • 32200 / 32200.dat  Technic Axle Flexible 12
  • 76279 / 76279.dat  Technic Flex-System Hose  6L (120LDU)
  • 60166 / 76289.dat  Technic Flex-System Hose  7L (140LDU)
  • 55668 / 76260.dat  Technic Flex-System Hose  8L (160LDU)
  • 76324 / 76324.dat  Technic Flex-System Hose  9L (180LDU)
  • 76302 / 76348.dat  Technic Flex-System Hose 10L (200LDU)
  • 63037 / 71505.dat  Technic Flex-System Hose 11L (220LDU)
  • 60676 / 71175.dat  Technic Flex-System Hose 12L (240LDU)
  • 76255|85532 / 71192.dat  Technic Flex-System Hose 16L (320LDU)
  • 76270 / 76270.dat  Technic Flex-System Hose 17L (340LDU)
  • 76275|61356 / 71582.dat Technic Flex-System Hose 18L (360LDU)
  • 76257 / 22463.dat  Technic Flex-System Hose 19L (380LDU)
  • 55676 / 76276.dat  Technic Flex-System Hose 20L (400LDU)
  • 62530 / 76252.dat  Technic Flex-System Hose 22L (440LDU)
  • 76254 / 76254.dat  Technic Flex-System Hose 23L (460LDU)
  • 76277 / 76277.dat  Technic Flex-System Hose 24L (480LDU)
  • 57274 / 57274.dat  Technic Flex-System Hose 32L (640LDU)
  • 71984 / 71952.dat  Technic Ribbed Hose  4L
  • 71944 / 71944.dat  Technic Ribbed Hose  6L
  • 71985 / 57719.dat  Technic Ribbed Hose  7L
  • 71917 / 71917.dat  Technic Ribbed Hose  9L
  • 71986 / 71986.dat  Technic Ribbed Hose 11L
  • 71923 / 71923.dat  Technic Ribbed Hose 14L
  • 72039 / 72039.dat  Technic Ribbed Hose 18L
  • 43675 / 43675.dat  Technic Ribbed Hose 19L
  • 98567 / 98567.dat  Tool Belt 17M
md5sum: fdc070a421e58f3a871f88e2d28562e2
Update 2017-06-04
Rematched (to correct variant):
  • 59426 / 59426.dat  Technic Axle  5.5 with Stop Type 2
  • 61252 / 61252.dat  Plate  1 x  1 with Clip Horizontal (Thick C-Clip)
  • 74967 / 74967.dat  Wheel Rim  8 x  8 Notched Hole, Reinforced Back
Rematched (just to the same ID):
  • 12818 / 12818.dat  =Panel  3 x  3 x  6 Corner Round
  • 32531 / 32531.dat  Technic Brick  4 x  6 with Open Center  2 x  4
  • 41763 / 41763.dat  =Slope Brick Curved  6 x  1 Inverted
  • 44237 / 44237.dat  =Brick  2 x  6
md5sum: 1897a31613d3009d9f84c8959179326e
