Posted July 11, 20168 yr This is another version of khatmorg's great design. I pretty much only changed the wings and when I was about to start ordering the parts I realized, that this brick is not available in dark red, so I had to change the way the wings connected to the body. This turned out to be more difficult than I thought and in the end I settled for some two studs connections with the idea that it will only be a display model and I could sacrifice durability. After receiving the parts I found a few more weaknesses and overall the transition between the wings and the body has too many gaps. I'm uploading the .lxf file and would greatly appreciate it if anybody could offer any suggestions how to improve the model. Thank you! D-7 Jedi Starfighter.lxf
July 11, 20168 yr This is my opinion but using bricks to build the 'wings' in the wedge doesn't work as well as an assembly of plates
