Seasider Posted July 19, 2016 Posted July 19, 2016 anyone know about replacing friction pins with non-friction pins ? I was thinking when i get my Claas to perhaps do an exercise and swap out the blue pins for black or grey equivalents, depending upon what colour beams they are seen through, but i know the grey are non-friction pins so i was wondering what that would mean to model stability. Any thoughts ? Quote
Seasider Posted July 20, 2016 Posted July 20, 2016 I don't have the set or instructions yet so I don't know which pins. Most probably just whatever blue pins end up being visible and then change to black or grey depending upon what colour beam they are visible through. Just wondered what the general opinion was Quote
JBTechnic Posted July 20, 2016 Posted July 20, 2016 (edited) In my opinion you can swap the blue ones with black ones. I wouldn't swap a blue one with a gray one...on my Xerion I swapped a gray one from the steering with a black one just to have a more rigid set up. Tolerances add up, leading to a wiggly set up. Unfortunately the 2L black pin with pin&cross axle is friggn expensive. JB Edited July 20, 2016 by JBTechnic Quote
Imanol BB Posted July 20, 2016 Posted July 20, 2016 I don't have the set or instructions yet so I don't know which pins. Most probably just whatever blue pins end up being visible and then change to black or grey depending upon what colour beam they are visible through. Just wondered what the general opinion was In that case i think it is a great option Quote
BrickWild Posted July 21, 2016 Author Posted July 21, 2016 Is anyone going to switch out the Medium Motor for the Large Motor? Quote
Emmi Posted July 23, 2016 Posted July 23, 2016 Can someone try to mod the cabin - so it can be moved/turned manually (like the turning at the Volvo EW160E) instead of automatically - also would be nice to have a easy to activate fix that the cabin is fixed in place once you have finished manual turning. Like axles that come in place when finished? Quote
Imanol BB Posted July 23, 2016 Posted July 23, 2016 Can someone try to mod the cabin - so it can be moved/turned manually (like the turning at the Volvo EW160E) instead of automatically - also would be nice to have a easy to activate fix that the cabin is fixed in place once you have finished manual turning. Like axles that come in place when finished? This would be a nice mod, and i am thinking that this could give enough space for some other functions inside the model, maybe a PTO selector, or even a pneumatic pump, another nice mod could be a suspension, not sure if there could fit a drivetrain, maybe if the steering system is improved and reduced. Quote
Husky Posted July 24, 2016 Posted July 24, 2016 There is enough space on the left side behind the stair for a motorized pneumatic pump. There is nothing, and you dont have to remove automatic cabin turning. But if you remove it too, you will have a lot of space. A lot of wheel used to slow down the motor rpm. Perhaps I dont know why didnt they make a manual cabin locking mechanism like they did with the attachments. If i want to turn right I need a lot of force for steering and cabin starts to turn instead of the wheels. Quote
Seasider Posted July 24, 2016 Posted July 24, 2016 (edited) This would be a nice mod, and i am thinking that this could give enough space for some other functions inside the model, maybe a PTO selector, or even a pneumatic pump, another nice mod could be a suspension, not sure if there could fit a drivetrain, maybe if the steering system is improved and reduced. The Claas doesn't have suspension. It only has a rear PTO too Here's the brochure and it has a ghosted images of its chassis and drive train which could be very useful when modding. http://www.claas.co.uk/blueprint/servlet/blob/479972/401984dc421b5335e4c2e9d7263e3cf0/237852-dataRaw.pdf Edited July 24, 2016 by Seasider Quote
agrof Posted July 24, 2016 Posted July 24, 2016 (edited) Sorry, if the pictures are too big: http://kockashop.hu/...054/large/6.jpg http://kockashop.hu/...054/large/7.jpg Edited July 24, 2016 by agrof Quote
Imanol BB Posted July 24, 2016 Posted July 24, 2016 If the Xerion has no suspension, how does it performs in rough terrain, is does it like a skid steer loader? Quote
andrewganschow Posted July 24, 2016 Posted July 24, 2016 If the Xerion has no suspension, how does it performs in rough terrain, is does it like a skid steer loader? my guess would be really low tire pressure so they deform nicely? Quote
kisper Posted July 24, 2016 Posted July 24, 2016 Is it possible to motorize and add servo to this baby ? Quote
Siegfried Meyer Posted July 24, 2016 Posted July 24, 2016 Is it possible to motorize and add servo to this baby ? Anything is possible but there will always be some kind of compromise Quote
Joost Bronkhorst Posted July 24, 2016 Posted July 24, 2016 Most tracktors have no suspension at all, large tirres and low tire presure helps a lott and tracktors dont have to able to climb mountains or something like that. Quote
Dafgek81 Posted July 24, 2016 Posted July 24, 2016 Most tractors have pendular front axles, so somewhat of a suspension, most earth moving equipment does to. Quote
efferman Posted July 24, 2016 Posted July 24, 2016 (edited) the claas has a damped pendular suspension in front Edited July 24, 2016 by efferman Quote
Dafgek81 Posted July 24, 2016 Posted July 24, 2016 Yes effe, exactly what I meant to say, thank you. Quote
M_longer Posted July 24, 2016 Posted July 24, 2016 So far most interesting MOD for me would be rebuilding TRAC VC version into SADDLE TRAC: Quote
Imanol BB Posted July 24, 2016 Posted July 24, 2016 Thanks to Dafgek and Effe for the information, by the way, i am not sure, but what do you think of modding the tractor like the Saddle Trac version that M_Longer showed, and putting the crane behind the cab? Quote
ctx1769 Posted July 24, 2016 Posted July 24, 2016 Gonna get of these so i can build the 8 tyre version of it 2 sets sorry Quote
2LegoOrNot2Lego... Posted July 25, 2016 Posted July 25, 2016 @agrof: Would be awesome! It makes it even more impressive and it already is...!!! @Dafgek81 and @efferman: It's true about suspension, impressive this Claas has it damped! Looking at the way this model is build, that won't be easy to implement though... @M_longer: Very cool, looking forward to how you would manage that! @ctx1769: About the 8 tyre version, that's so cool, thought of that myself too...! Quote
Seasider Posted July 25, 2016 Posted July 25, 2016 Wonder if there is another (not horrendously expensive) way of getting a second set of wheels and tyres to do a double wheel mod. Quote
TomOOO Posted July 25, 2016 Posted July 25, 2016 the claas has a damped pendular suspension in front Just adding a little to this correct comment - sorry for the boring engineering : All machinery that is required to maximise the traction and have wheels use pendulum suspension on the non-loaded end of the machine. In tractors that will be the front wheels (though in this claas that is ambiguous) but also includes front end loaders, back-hoe etc. Suspension results in some wheels having less axle weight going over bumps - which means they will slip first. Pendulum suspension guarantees : All wheels have the same traction all the time regardless of terrain - unless they reach their limits - hence diff locks That heavily loading (ie tractors with heavy attachments) are solid to the ground via the fixed axle and do not swing on the suspension as they drive. That as a driver you can predict when there will be dangerous swing movement when using heavy attachments as it will be when the fixed axle goes over rough terrain (ie a ditch) Heavy loads that swing out (like ditch cutters and excavators) do not effect the tractor/excavator angle sideways as they are solid to the ground with the fixed axle - except for tire compression. Heavy loading of the floating axle (ie front) is bad practice and should be driven with care. Quote
