technic_addict Posted November 19, 2016 Posted November 19, 2016 Medium blue is slowing filling in with more and more parts. I don't see any #21 / #22 panels which is unfortunate. Quote
HallBricks Posted November 19, 2016 Posted November 19, 2016 Found some more pictures: Isn't this a new rim? Quote
Ngoc Nguyen Posted November 19, 2016 Posted November 19, 2016 (edited) Deleted Edited November 19, 2016 by nguyengiangoc Quote
HallBricks Posted November 19, 2016 Posted November 19, 2016 1 minute ago, nguyengiangoc said: New connector in white: Pin hole with vertical pin hole I think it's the regular pin with pinhole recolored into light bluish gray connected to a light bluish gray beam... You can see them in light bluish gray on the A-model where the tail rudders are connected as well. Quote
Ngoc Nguyen Posted November 19, 2016 Posted November 19, 2016 7 minutes ago, HallBricks said: I think it's the regular pin with pinhole recolored into light bluish gray connected to a light bluish gray beam... You can see them in light bluish gray on the A-model where the tail rudders are connected as well. Thanks. That sounds more reasonable than the idea of pin with vertical pin hole. Quote
HallBricks Posted November 19, 2016 Posted November 19, 2016 41 minutes ago, nguyengiangoc said: - Axle hole with pin got recolored into LBG Which part did you refer to here? Don't really understand what you meant, sorry Just now, nguyengiangoc said: Thanks. That sounds more reasonable than the idea of pin with vertical pin hole. Maybe, but it would be nice to have such a connector :) Quote
Ngoc Nguyen Posted November 19, 2016 Posted November 19, 2016 6 minutes ago, HallBricks said: Which part did you refer to here? Don't really understand what you meant, sorry Sorry I meant pin hole with pin recolored into LBG. The same as what you said earlier. Quote
HallBricks Posted November 19, 2016 Posted November 19, 2016 3 minutes ago, nguyengiangoc said: Sorry I meant pin hole with pin recolored into LBG. The same as what you said earlier. Aha, okay thank you Quote
Banana92 Posted November 19, 2016 Posted November 19, 2016 It seems the small helicopter could be fairly easily modified so that the rear wheels drive the propellers and engine. Quote
JJ2 Posted November 19, 2016 Posted November 19, 2016 1 hour ago, nguyengiangoc said: - Any jet enthusiast can enlighten me on what that motorized wheel rim is? I believe its modeled off a F35, it is used to hover the plane, the F35 has an opening hull to stabilize the front though. Quote
J_C Posted November 19, 2016 Posted November 19, 2016 (edited) watch and learn : however central fan is missing (in F35 dorsal and belly opennings) and they are crutial for VTOL functions. So there is main part of F35 design missing, without it rear thrust vectoring is sort of pointless - or wrong if it should represent some technical feature of real plane edit: actually it looks like there is dorsal opening. my bad. Edited November 19, 2016 by J_C I added last 2 sentences under videos Quote
Ngoc Nguyen Posted November 19, 2016 Posted November 19, 2016 (edited) Since the hull can be opened manually, I guess there's another wheel rim inside it to serve as the front stabilizer. On another note, it seems like the jet has rudders, elevators, but no ailerons. Is it realistic for jets like this to not have ailerons? Edited November 19, 2016 by nguyengiangoc Quote
mutaling Posted November 19, 2016 Posted November 19, 2016 Looks like 42061 will release as well: Front Back source: http://kockashop.hu/lego/teleszkopos-markologep-42061 Quote
Ngoc Nguyen Posted November 19, 2016 Posted November 19, 2016 Four wheel steering using liftarms, no gear rack: Soo, pin hole with pin in LBG in the jet, but in DBG in the ocean explorer. Let the rage of recoloring begins. Quote
paul_delahaye Posted November 19, 2016 Posted November 19, 2016 Looks like another attempt from Lego to redesign the worm gear after the failure the other year. Can be seen at the front of the Boom on the telehandler Quote
1gor Posted November 19, 2016 Posted November 19, 2016 Looks like this part in yellow on plane B model https://www.bricklink.com/v2/catalog/catalogitem.page?P=87408&idColor=11#T=C&C=11 And worm gear was noticed on 42060 and 42062 Quote
kuja2015 Posted November 19, 2016 Posted November 19, 2016 I'm anxious for the 2H sets. We're having news just in January? Really? Quote
GoldVillage Posted November 19, 2016 Posted November 19, 2016 Ty nice set of pictures! Telehandler and jet plane looks even better than expected and FINALLY black triangular panels Quote
Thirdwigg Posted November 19, 2016 Posted November 19, 2016 I'm liking that telehandler. Perfect size, and great use of parts. That new worm gear is great. Quote
M_longer Posted November 19, 2016 Posted November 19, 2016 2 minutes ago, GoldVillage said: Ty nice set of pictures! Telehandler and jet plane looks even better than expected and FINALLY black triangular panels Finally worm gear that is just ONE STUD LONG! AT LAST! Now I have to figure out where and when I needed that thing... Quote
Ngoc Nguyen Posted November 19, 2016 Posted November 19, 2016 I'd let my dream go wild and wish that in the jet, the propeller + the upper doors + the belly doors simultaneously, because that's the way the F 35 works. Quote
Thirdwigg Posted November 19, 2016 Posted November 19, 2016 Remind me of Lego gear geometry, this new worm gear will have to have a larger diameter than the old one to meet that rack, right? Quote
M_longer Posted November 19, 2016 Posted November 19, 2016 Just now, Thirdwigg said: Remind me of Lego gear geometry, this new worm gear will have to have a larger diameter than the old one to meet that rack, right? Seems so. Also, it means that we will have a worm gear that works with bevel gears. Quote
jorgeopesi Posted November 19, 2016 Posted November 19, 2016 Most of new technic parts can be done cutting old ones, it is everything invented or there is no imagination?, 11 studs axle, 3 studs axle without head and even the new small worm gear and I am not talking about colors yet . Quote
Boulderer Posted November 19, 2016 Posted November 19, 2016 1 hour ago, jorgeopesi said: Most of new technic parts can be done cutting old ones, it is everything invented or there is no imagination?, 11 studs axle, 3 studs axle without head and even the new small worm gear and I am not talking about colors yet . Interesting line of thought. Following it further, which piece would you consider the last inventive piece to be launched in Technic? Quote
