stevenhalim Posted November 20, 2016 Posted November 20, 2016 The cabin on 42061 telehandler uses a new? halfbeam curve 5x7 (to make a bigger cabin). What I have since collecting Technic sets since 2013 is this halfbeam curve 5x3 frame http://brickset.com/parts/4128554, I am not sure if this part has appeared in other sets outside Technic. Quote
Maaboo the Witch Posted November 20, 2016 Posted November 20, 2016 Just now, stevenhalim said: The cabin on 42061 telehandler uses a new? halfbeam curve 5x7 (to make a bigger cabin). What I have since collecting Technic sets since 2013 is this halfbeam curve 5x3 frame http://brickset.com/parts/4128554, I am not sure if this part has appeared in other sets outside Technic. Yeah, it's been around since 2000. It first appeared in the 4WD X-Track set, and it's been in two seasonal sets and one or two BIONICLE sets as well. Quote
MajklSpajkl Posted November 20, 2016 Posted November 20, 2016 The wheels on the jet are not new, maybe a new colour, but the mould is used in Speed Champions series. Quote
legotechnicisawesome Posted November 20, 2016 Posted November 20, 2016 23 hours ago, Nequmodiva said: Even if they did a last minute redesign and release it in pink? cool idea! we need some pink! :D purple came out this year so i hope pink comes out next year! Quote
efferman Posted November 20, 2016 Posted November 20, 2016 Axle 5m with endstop now in reddish brown? Quote
Kaanere Posted November 20, 2016 Posted November 20, 2016 31 minutes ago, legotechnicisawesome said: cool idea! we need some pink! :D purple came out this year so i hope pink comes out next year! I'm not sure if it would sell. Purple stands out, but pink doesn't. It's also stereotypically associated as a girly colour. Also, the AFOLs on this site seem to hate both new colour shades and red. Quote
Nequmodiva Posted November 20, 2016 Posted November 20, 2016 (edited) 57 minutes ago, stevenhalim said: The cabin on 42061 telehandler uses a new? halfbeam curve 5x7 (to make a bigger cabin). What I have since collecting Technic sets since 2013 is this halfbeam curve 5x3 frame http://brickset.com/parts/4128554, I am not sure if this part has appeared in other sets outside Technic. No, like Maaboo35 said not new, here is the Bricklink link: http://www.bricklink.com/catalogItemIn.asp?P=32251&in=S (in 10 sets already) 58 minutes ago, Maaboo35 said: Funny you should say that. The quarter ellipse liftarms making up the cab were black in the prelim image, and they're now dark bluish grey on the genuine article. Foreshadowing! I checked that too, and no, they weren't black in the prelim images either. Compare it to the black liftarm below. Although I see why one could be fooled to think its lighter color is just the result of light reflection. So in 42061 there is: New 2017 worm gear New Pinhole with two axles connector Previously rare gear rack with housing New Bucket mold, so far exclusive in this set (?). At least in Technic. Correct me if I'm wrong. Mini Linear Actuator. The by far smallest set it has yet appeared in. As I guess 42061 will have less than 300 pieces. Next for that mini actuator was 8069 with 609 pieces. (As long as you don't count the excavator in 42023 as a separate set.) Axle with stop 5 in brown color (new color, in several 2017 sets) The aforementioned not so common 5x7 curved half beam lift arm Black rims, always good 2017 commemorative brick of course Wow! Edited November 20, 2016 by Nequmodiva Quote
HallBricks Posted November 20, 2016 Posted November 20, 2016 So axle 5 with stop is now molded in reddish brown instead, I think it looks way worse than dark tan. We have seen many useful axles and connectors appearing in new colors, most of them look fairly good and are quite easy to blend into models. I am not a big fan of the reddish brown color though, it doesn't look to belong in a technic model. It looks like wood or someting... Quote
M_longer Posted November 20, 2016 Posted November 20, 2016 5 minutes ago, HallBricks said: So axle 5 with stop is now molded in reddish brown instead, I think it looks way worse than dark tan. We have seen many useful axles and connectors appearing in new colors, most of them look fairly good and are quite easy to blend into models. I am not a big fan of the reddish brown color though, it doesn't look to belong in a technic model. It looks like wood or someting... More like model that began to corrode ;) Quote
Lox Lego Posted November 20, 2016 Posted November 20, 2016 7 minutes ago, HallBricks said: So axle 5 with stop is now molded in reddish brown instead, I think it looks way worse than dark tan. We have seen many useful axles and connectors appearing in new colors, most of them look fairly good and are quite easy to blend into models. I am not a big fan of the reddish brown color though, it doesn't look to belong in a technic model. It looks like wood or someting... +1.... I am not a fan at all of all this colour puke. Lol yes it does looks like wood! Quote
Ngoc Nguyen Posted November 20, 2016 Posted November 20, 2016 TLG heard you guys don't like recoloring, so TLG brings you pin hole with pin recolored into not just one, but two different colors Quote
Gnac Posted November 20, 2016 Posted November 20, 2016 5 minutes ago, nguyengiangoc said: TLG heard you guys don't like recoloring, so TLG brings you pin hole with pin recolored into not just one, but two different colors Oh you noticed the Dark Stone Grey on the Ocean Explorer too Quote
HallBricks Posted November 20, 2016 Posted November 20, 2016 3 minutes ago, nguyengiangoc said: TLG heard you guys don't like recoloring, so TLG brings you pin hole with pin recolored into not just one, but two different colors Yeah they must have heard that. Fortunately it was recolored into two useful colors... Quote
Ngoc Nguyen Posted November 20, 2016 Posted November 20, 2016 (edited) Then TLG says, let's screw the fans and recolor not just 5L axle with stop, but also the new pin hole with axle, into reddish brown.. Because reddish brown blends best into models! Edited November 20, 2016 by nguyengiangoc Quote
Gnac Posted November 20, 2016 Posted November 20, 2016 That's actually this thing; either they made far too many for the Star Wars bonkles, or someone at TLG likes them very much. Quote
Ngoc Nguyen Posted November 20, 2016 Posted November 20, 2016 (edited) 2017 - The recoloring awakens? Edited November 20, 2016 by nguyengiangoc Quote
Gnac Posted November 20, 2016 Posted November 20, 2016 9 minutes ago, nguyengiangoc said: 2017 - The recoloring awakens? yeah Quote
Banana92 Posted November 20, 2016 Posted November 20, 2016 2017 has me so excited, I do think though that dark tan is better suited for that 5 axle with stop, it just doesn't pull your eye toward it like brown, and also with tan gears it seems more like it belongs then the reddish brown :/ Quote
Technivor Posted November 20, 2016 Posted November 20, 2016 8 hours ago, efferman said: Axle 5m with endstop now in reddish brown? Yes and in the tracked racer we can see that there's a lot of red 5 axle with stop to! Quote
HallBricks Posted November 20, 2016 Posted November 20, 2016 6 minutes ago, Technivor said: Yes and in the tracked racer we can see that there's a lot of red 5 axle with stop to! They're actually reddish brown in the tracked racer too Quote
Technivor Posted November 20, 2016 Posted November 20, 2016 7 minutes ago, HallBricks said: They're actually reddish brown in the tracked racer too But when we look at the picture they look the same color as the bush! Quote
marder Posted November 21, 2016 Posted November 21, 2016 (edited) Edited November 21, 2016 by marder Quote
mattthewise Posted November 21, 2016 Posted November 21, 2016 (edited) On 11/19/2016 at 0:03 PM, nguyengiangoc said: - Any jet enthusiast can enlighten me on what that motorized wheel rim is? I'm not sure of the proper terminology, but I'm pretty sure it's a jet nozzle that can vector, directing force downwards. Combined with a fan near the front, jets can VTOL with that. Here's an image: Edited November 21, 2016 by mattthewise Quote
Samer Posted November 21, 2016 Posted November 21, 2016 (edited) 42066 will break the sound barrier of sales! I wonder could it have been better if they used for the front a light blue version of the red part of the front of the 42064 ship? Edited November 21, 2016 by Samer Quote
