7 minutes ago, Goonmo said:
I think Lego said this is the biggest Minecraft set they've ever produced, so probably $200 or more at least.
Probably 250 or so. This looks like it would use up more parts then the village and that was 200
  • Replies 301
So price wise I am think over $250 USD. 3.36kg and D2C.
I am itching to see the back. It would be great if it looked good from all angles rather than the 'shop front' style that LEGO has used in the past for a lot if sets. I don't like ugly techpin visible open backs.
Fingers crossed.
Wow decent set, seems to have a lot of different mobs. I'm pretty disappointed with that charged creeper though.
So in the set we will get 2 little slimes, 1 giant slime(fingers crossed he has the hopping feature), Steve, Alex, a baby angry wolf, another wolf, Enderman, Bat, cave spider, Black sheep, and a zombie. Also a shield.
Though what is that brown block above the chest in the charged creeper picture?
2 minutes ago, LegoMonorailFan said:
Oops, sorry. I meant to say top right corner. Referring to the mountain.
I think it's a trigger for the mine cart. Pushing/turning it will probably push the cart
I wonder where the pearl gold spiral pole and the light brick fit in, both position- and play feature-wise :classic: The pole obviously has to be inside the structure to the right somewhere but the light brick's position is less clear :wacko:
Light is probably inside to make a torch light or furnace light or something
I don't think the giant slime has any mechanics to it- its hopping doesn't separate it like a magma cube, so there's no need to add an action within the model, and it doesn't seem to have anything inside it, either.
The spiral pole must be a play feature coming from the top to take advantage of the sets height. A lift? No lifts in Minecraft.... a mystery. The area inside under the snow biome however has another level of height so I am thinking the pole comes down from the 'icehouse' up on top.
There must be a good sized space inside the mountain. The mine runs along the inside from the front to the 'left; where the cave spider is, maybe the tracks do to. There is a play feature knob/wheel on the bottom left that might do something inside as well. It has a little fence there inside which you can see behind the big slime. As for the light brick I am thinking behind the torch maybe light comes through a brick with a technic pin hole? This would also double for a light source for the a glowing lava pool?
I am itching to see the back/interior.
